Part No: EPA090100-S/T-SZ
Date: 5/11/2007
Unit: mm
Description: linear power supply
Page No: 1 of 7
Specifications
Output voltage
Rated input voltage
Primary rated voltage
Primary exciting current
Secondary rated voltage & current
Temperature rise of primary winding (full load)
Insulation resistance
HI-POT test
Safety standards
RoHS compliant
No load power consumption
Efficiency
Test conditions
Adapter color
Phone: 800.275.4899
9 V ac at 1000 mA
120 V ac
120 V ac 60 Hz 9 W
30 mA rms max.
no load voltage (max.)
11.8 V ref
full load voltage (1000 mA)
9 V ±5%
70°C max. using resistance method
>= 100 M Ohm at 500 V dc
from input to output for 1 min.
1240 V ac at 2 mA
from input to output for 1 sec.
1600 V ac at 2 mA
from primary to secondary winding for 1 sec.
1600 V ac at 2 mA
from primary winding to core for 1 sec.
1600 V ac at 2 mA
from secondary winding to core for 1 sec.
750 V ac at 2 mA
UL/cUL
yes
0.5 W max.
Energy Star Compliant - Efficiency Level IV
Ambient temp
40°C ±2°C
Humidity
90-95% 96 hours at Full Load
Rated voltage
8 hours at full load
Case
black
Cord
black
Fax: 503.612.2383
www.cui.com
20050 SW 112th Ave.
Tualatin, OR 97062
Date: 5/11/2007
Unit: mm
Page No: 2 of 7
Label
C2*45
31.5+0/-0.2
AC ADAPT OR
CLASS 2 TRANSFORMER
INPUT : AC 120V 6 0Hz 9W
OUTPUT : AC 9V 1000mA
P/N:EPA090100-S/T-SZ
FOR VERTICAL OR FLOOR
MOUNT USE ONLY
EFFICIENCY LEVEL
E140898
88Y3
Adhesive tape: 3m #44 tape 18 width
Thickness: 0.2mm
Material: PVC Polyester
Color: black on silver base
1.6 MIN
R2.5*3
IV
RoHS
Remarks: YYWW X
YY=production year
WW=production week
X=production location
MODEL : 41A-9-1000
EIA 363 YYWW X
MADE IN CHINA
29.5+0/-0.2
Phone: 800.275.4899
Fax: 503.612.2383
www.cui.com
20050 SW 112th Ave.
Tualatin, OR 97062
Date: 5/11/2007
Unit: mm
Page No: 3 of 7
Mechanical Drawing
Tolerance: ±1
Weight
Phone: 800.275.4899
Fax: 503.612.2383
www.cui.com
330 g
20050 SW 112th Ave.
Tualatin, OR 97062
Date: 5/11/2007
Unit: mm
Page No: 4 of 7
DC Cord
Phone: 800.275.4899
Fax: 503.612.2383
www.cui.com
20050 SW 112th Ave.
Tualatin, OR 97062
Date: 5/11/2007
Unit: mm
Page No: 5 of 7
Circuit Diagrams
Test Diagram
Phone: 800.275.4899
Fax: 503.612.2383
www.cui.com
20050 SW 112th Ave.
Tualatin, OR 97062
Date: 5/11/2007
Unit: mm
Page No: 6 of 7
Individual Packaging
Tolerance: ±1
Phone: 800.275.4899
Fax: 503.612.2383
www.cui.com
20050 SW 112th Ave.
Tualatin, OR 97062
Date: 5/11/2007
Unit: mm
Page No: 7 of 7
Packaging
Tolerance: +7/-0
Phone: 800.275.4899
Fax: 503.612.2383
www.cui.com
20050 SW 112th Ave.
Tualatin, OR 97062
很抱歉,暂时无法提供与“EPA090100-S/T-SZ”相匹配的价格&库存,您可以联系我们找货
