XFBS01
XFBS01
    EXCELSYSTECHNOLOGIESLTD
    700W 6 Slot AC DC Configurable Power Supply Chassis
XFBS01 数据手册
Hi-Rel COTS AC/DC Plug & Play Power Supply 400W-1000W Hi-Rel COTS F Ruggedised COTS AC/DC Power Supply Ultra-high efficiency 1U size FEATURES • • • • • • • • • • • • • • • • • MIL-STD-810G: Shock & Vibration MIL-STD-461F: EMC Conformal Coated & Ruggedised as standard Operating temperature range of -55 to 70°C 47-440Hz input frequency Anti-Vibration Compound 1.5V to 58V standard output voltages All outputs fully floating Extra low profile: 1U height (40mm) Ultra high efficiency, up to 91% Plug & Play Power - allows fast custom configuration - Outputs completely field configurable with option to factory fix Series / Parallel outputs for higher voltages and currents Parallel powerpacs for higher power OVP, OTP, OCP as standard 5V/250mA bias standby voltage provided Individual output control 3 Year Warranty APPLICATIONS INCLUDE • • • • Harsh Industrial Electronics Radar (Naval, Ground Based) Communications Test & Measurement EFFICIENCY (typical) The XF family of power supplies provides up to an incredible 1000W in an extremely compact 1U x 268 x 127mm package. Employing an innovative plug & play architecture the XF family brings unprecedented flexibility that allows users to instantly configure a custom power solution in less than 5 minutes. Designed for use in harsh operating environments, the XF family is conformal coated and ruggedised to withstand extremes in shock and vibration as well as operation over a wide temperature range of -55 to 70°C. Applications include Harsh Industrial, Test and Measurement, Communications, Fixed and Mobile Radar and Military Electronics which require COTS solutions. All configurations carry full safety agency approvals, including UL60950 and EN60950 and are fully characterised for EMC according to MIL-STD-461F. All configurations meet the MIL-STD810G standard for shock and vibration. EMC characterisation, Shock and Vibration and Thermal Stress reports are available. For further details please contact support@excelsys.com. powerMods MODEL powerPacs Vmin Vnom Vmax Imax Watts MODEL Vtrim Xg1 1.0 1.5 2.5 3.6 50A 125W Xg2 1.5 3.2 5.0 6.0 40A 200W Xg3 4.0 6.0 12.0 15.0 20A 240W Xg4 8.0 12.0 24.0 28.0 10A 240W Xg5 8.0 24.0 48.0 53.0 6A 288W Xg7 5.0 5.0 24.0 28.0 5A 120W 5.0 5.0 5.0 5.0 24.0 24.0 28.0 28.0 2.5A 2.5A 48W 48W Xg8 V1 V2 COTS next generation power source Hi-Rel PLUG & PLAY POWER Watts XFA 400W XFB 700W XFC 1000W MECHANICAL SPECIFICATIONS XFA, XFB, XFC Third angle projection 54.00 97.75 122.00 92.00 23.50 SLOT F J1 TOP VIEW 80.00 19.00 127.00 J2 INPUT AC 100V-240V 50/60Hz SEE INSTRUCTION MANUAL 70C MAX OPERATING TEMPERATURE SLOT E 19.00 19.00 SLOT D SLOT C SLOT B SLOT A 23.50 40.40 29.50 All dimensions in mm. Mounting Holes 4 M4 threaded holes on Base. Max screw penetration is 6mm from Base. Fleximount Side Mounting Slots Use with self-clinching studs type FH-M4-X or FH-832-X (X= stud length) from PEM, or equivalent Alternatively, use Xgen Side Clamps from Excelsys. Part No. Z165 (drawing 61401) 1 Hi-Rel COTS AC/DC Plug & Play Power Supply 400W-1000W SPECIFICATION applies to configured units consisting of powerMods modules plugged into the appropriate powerPac INPUT Parameter Input Voltage Range Hi-Rel COTS Power Rating Input Current XFA XFB XFC Inrush Current Undervoltage Lockout Fusing XFA XFB XFC Conditions/Decription Universal Input 47 - 63Hz. Input: 390 - 440Hz. XFA XFB XFC 85VAC in 400W out 85VAC in 700W out 85VAC in 765W out 230VAC @ 25°C Shutdown 250V 250V 250V Min 85 90 Conditions/Description As per powerMod table Manual or Electronic As per powerMod Table Min Nom Max 264 120 400 700 1000 25 74 Units VAC VAC W W W A A A A VAC Max Units ±0.1 ±0.2 10 250 A % % % µs 7.5 9.5 11.5 65 F8A HRC F10A HRC F12A HRC OUTPUT Parameter powerMod Power Output Adjustment Range Minimum Load Line Regulation Load & Cross Regulation Transient Response Ripple and Noise Overvoltage Protection Overcurrent Protection Remote Sense Overshoot Turn-on Delay Rise Time Hold-up Time Output Isolation Nom 0 For ±10% change from nominal line For 25% to 75% load change For 25% to 75% load change Voltage Deviation Settling Time 20MHz Bandwidth100mv or 1.0% pk-pk Two-Level: 1st Level: Vset Tracking. 2nd Level: Vmax (Latching) Straight line with hiccup activation at
XFBS01 价格&库存
很抱歉,暂时无法提供与“XFBS01”相匹配的价格&库存,您可以联系我们找货
