SWI24-24-N-P5R
SWI24-24-N-P5R
    CUIDEVICES
    AC/DCWALLMOUNTADAPTER24V24W
SWI24-24-N-P5R 数据手册
Additional Resources: Product Page | 3D Model date 04/29/2022 page 1 of 5 SERIES: SWI24-N │ DESCRIPTION: AC-DC POWER SUPPLY FEATURES • • • • • • • • up to 24 W continuous power DOE Level VI, CEC, ErP Stage 2 no load power consumption < 0.1 W compact size universal input voltage range over voltage, over current, and short circuit protections UL/cUL, PSE safety approvals certified to 60950-1 and 62368-1 standards MODEL output voltage output current output power ripple and noise1 (Vdc) max (A) max (W) max (mVp-p) SWI24-12-N 12 2 24 120 VI SWI24-15-N 15 1.6 24 150 VI SWI24-24-N 24 1 24 240 VI Notes: efficiency level 1. At full load, nominal input, 20 MHz bandwidth oscilloscope, each output terminated with 0.1 μF multilayer ceramic and 10 μF low ESR electrolytic capacitors. PART NUMBER KEY SWI24 - XX - N - XXX - CXX Reserved for Custom Configurations Base Number Output Voltage AC Input Type: North America cui.com DC Plug Type: XXX = See output plug options on page 4 for more details Additional Resources: Product Page | 3D Model CUI Inc │ SERIES: SWI24-N │ DESCRIPTION: AC-DC POWER SUPPLY date 04/29/2022 │ page 2 of 5 INPUT parameter conditions/description min voltage 90 frequency 47 typ current inrush current at 230 Vac, full load, 25°C, cold start leakage current no load power consumption max units 264 Vac 63 Hz 0.58 A 60 A 0.25 mA 0.1 W max units OUTPUT parameter conditions/description min regulation hold-up time typ ±5 at full load % 10 ms PROTECTIONS parameter conditions/description over voltage protection min typ max units output shut down 12 Vdc output model 15 Vdc output model 24 Vdc output model 22 32 45 Vdc Vdc Vdc over current protection output shut down, auto recovery 12 Vdc output model 15 Vdc output model 24 Vdc output model 5 4 2.5 A A A short circuit protection output shut down, auto recovery max units SAFETY & COMPLIANCE parameter conditions/description isolation voltage input to output at 10 mA for 1 minute min isolation resistance input to output at 500 Vdc safety approvals UL/cUL (60950-1, 62368-1), PSE EMI/EMC FCC Part 15B Class B MTBF as per Telcordia SR-332, 25°C RoHS yes typ 3,000 Vac 10 MΩ 300,000 hours ENVIRONMENTAL parameter conditions/description min operating temperature storage temperature max units 0 typ 40 °C -20 80 °C operating humidity non-condensing 20 80 % storage humidity non-condensing 10 90 % cui.com Additional Resources: Product Page | 3D Model CUI Inc │ SERIES: SWI24-N │ DESCRIPTION: AC-DC POWER SUPPLY date 04/29/2022 │ page 3 of 5 MECHANICAL parameter conditions/description dimensions 72 x 34 x 69 inlet plug North America, 2-pin min typ max units mm weight 148 MECHANICAL DRAWING units: mm tolerance: ±1.0 mm DC CORD units: mm Table 1 MODEL NO. CABLE CORD LENGTH SWI24-12-N UL2468, 20 AWG 1,500 mm ±30 SWI24-15-N UL2468, 20 AWG 1,500 mm ±30 SWI24-24-N UL2468, 22 AWG 1,500 mm ±30 cui.com g Additional Resources: Product Page | 3D Model CUI Inc │ SERIES: SWI24-N │ DESCRIPTION: AC-DC POWER SUPPLY date 04/29/2022 │ page 4 of 5 DC PLUG TYPE PART NUMBER KEY XXX Plug Polarity: P = Center Positive Plug Code: X = Choose a code from the options below Plug Angle: “blank” = Straight R = Right Angle N = Center Negative Plug Polarity Code Dimensions (mm) Plug Angle Center Pos. Center Neg. Option Type A B C Straight Right ● ● 5 Standard 5.5 2.1 9.5 ● ● ● ● 6 Standard 5.5 2.5 9.5 ● ● ● ● 7 Standard 3.5 1.35 9.5 ● ● ● ● 8 Standard 3.8 1.35 9.5 ● ● ● ● 9 Standard 3.8 1.05 9.5 ● ● ● ● 10 Locking2 5.5 2.1 9.5 ● N/A ● ● 11 Locking2 5.5 2.5 9.5 ● N/A ● ● 12 EIAJ-1 2.35 0.7 9.5 ● ● ● ● 13 EIAJ-2 4.0 1.7 9.5 ● ● ● ● 14 EIAJ-3 4.75 1.7 9.5 ● ● N/A N/A ST N/A N/A Stripped & Tinned Note: 1. Contact CUI for additional plug options 2. Maximum insertion depth is 10mm EIAJ Straight C C Straight Locking Right Angle (R) Stripped & Tinned 25±5 2.5±0.3 5±5 A B C A A Right Angle (R) C B B A A B C B Standard cui.com 10±2 Additional Resources: Product Page | 3D Model CUI Inc │ SERIES: SWI24-N │ DESCRIPTION: AC-DC POWER SUPPLY date 04/29/2022 │ page 5 of 5 REVISION HISTORY rev. description date 1.0 initial release 08/07/2015 1.01 added 62368-1 standard 08/31/2018 1.02 company logo updated 09/18/2020 1.03 safety marks updated 04/26/2021 1.04 plug polarity symbols updated 09/16/2021 1.05 dc plugs updated 04/29/2022 The revision history provided is for informational purposes only and is believed to be accurate. Headquarters 20050 SW 112th Ave. Tualatin, OR 97062 800.275.4899 Fax 503.612.2383 cui.com techsupport@cui.com This device complies with part 15 of the FCC Rules. Operation is subject to the following two conditions: (1) This device may not cause harmful interference, and (2) this device must accept any interference received, including interference that may cause undesired operation. CUI offers a one (1) year limited warranty. Complete warranty information is listed on our website. CUI reserves the right to make changes to the product at any time without notice. Information provided by CUI is believed to be accurate and reliable. However, no responsibility is assumed by CUI for its use, nor for any infringements of patents or other rights of third parties which may result from its use. CUI products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness.
SWI24-24-N-P5R 价格&库存
很抱歉,暂时无法提供与“SWI24-24-N-P5R”相匹配的价格&库存,您可以联系我们找货
SWI24-24-N-P5R
    • 1+113.83306
    库存:95
