Additional Resources:
Product Page
date
06/20/2017
page
1 of 4
SERIES: EMMA 15W │ DESCRIPTION: MEDICAL AC-DC POWER SUPPLY
FEATURES
up to 15 W power
interchangeable AC blades
universal input (90~264 Vac)
single regulated output from 5~24 Vdc
over voltage and short circuit protections
UL/cUL, CE safety approvals
medical 60601-1 4th edition safety approvals
designed for 2 x MOPP applications
level V efficiency
MODEL
IEC
60601-1
EN
60601-1
output
voltage
output
current
output
power
ripple
and noise1
(Vdc)
max
(A)
max
(W)
max
(mVp-p)
EMMA050200
5
2
10
50
V
EMMA120110
12
1.1
13.2
120
V
EMMA150100
15
1.0
15
150
V
EMMA240063
24
0.625
15
240
V
1. at full load, 100 ~ 240 Vac input, 20 MHz bandwidth oscilloscope, each output terminated with a 10 µF aluminum electrolytic and 0.1 µF ceramic capacitors.
PART NUMBER KEY
EMMA120110 X - XX - IC - CXX
Base Number
example of 12 Vdc, 1.1 A
DC Plug Type:
See output plug options
on page 3 for more details
Blades:
“blank” = North American, European, United Kingdom,
Australian
N = North American blade included
E = European blade included
B = United Kingdom blade included
A = Australian blade included
K = No blades included
cui.com
Factory
Designation
Reserved for Custom
Configurations
efficiency
level
Product Page
CUI Inc │ SERIES: EMMA 15W │ DESCRIPTION: MEDICAL AC-DC POWER SUPPLY
date 06/20/2017│ page 2 of 4
INPUT
parameter
conditions/description
min
voltage
frequency
inrush current
max
units
90
typ
264
Vac
47
63
Hz
50
A
0.3
W
max
units
at 240 V ac
no load power consumption
OUTPUT
parameter
min
line regulation
typ
±1
load regulation2
5 Vdc output
all other outputs
±4
±2
voltage accuracy
5 Vdc output
all other outputs
±3
±2
hold-up time
at 115 Vac
10
ms
1
switching frequency
temperature coefficient
Note:
95
kHz
±0.05
%/°C
1. measured from 100 ~ 240 Vac, full load
2. measured from 60% to full load and from 60 ~ 20% load (60% ±40% load)
PROTECTIONS
parameter
over voltage protection
TVS component to clamp
continuous, auto restart
SAFETY & COMPLIANCE
parameter
isolation voltage
input to output
min
typ
safety approvals
medical IEC 60601-1, EN 60601-1, UL 60601-1 4th edition
EMI/EMC
EN5 5011 Class B, FCC Part 15 Class B, EN 60601-1-2, EN 61000-3-(2,3)
leakage current
max
units
5,656
Vdc
0.1
MTBF
as per MIL-HDBK-217F, 115 Vac, 25 °C
RoHS
2011/65/EU
200,000
mA
hours
ENVIRONMENTAL
parameter
min
operating temperature
storage temperature
humidity
non-condensing
cui.com
typ
max
units
°C
-20
85
°C
93
Product Page
date 06/20/2017│ page 3 of 4
ø3.5 +0/-0.1
MECHANICAL
parameter
dimensions
80.60 x 47.90 x 43.30 (3.173 x 1.886 x 1.705 inch)
min
input plug
interchangeable blades (US, Europe, UK, Australia)
typ
max
units
mm
weight
130
14±0.5
g
MECHANICAL DRAWING
*Tip positive
units: mm [inches]
tolerance: ±0.5[0.02]
P1R
43.30 1.705
47.90 1.886
B
A
C
80.60 3.173
Right Angle PXR
EMM-US
EMM-AU
EMM-EU
B
A
EMM-UK
DC OUTPUT PLUG OPTIONS / DC CORD
C
Right Angle PXXR
D
P6/P6R
Ń
ł
Ń
ł
25±5
9±2 Standard PX
P5/P5R
cord length
ń
ń
Right Angle PXR
A
B
C
Unit
MODEL NO.
CABLE GAUGE
CORD LENGTH
5.5
2.1
9.5
mm
EMMA050200
18 AWG
1,800 mm ±50
mm
EMMA120110
18 AWG
1,800 mm ±50
EMMA150100
18 AWG
1,800 mm ±50
EMMA240063
18 AWG
1,800 mm ±50
5.5
2.5
9.5
PXX X X
Plug Type
Plug Angle:
“Blank” = Standard
R = Right Angle
act CUI for additional output plug options.
Plug Polarity:
“Blank” = N/A
P = Center Positive
N = Center Negative
cui.com
Product Page
date 06/20/2017│ page 4 of 4
REVISION HISTORY
rev.
description
date
1.0
initial release
12/16/2011
1.01
updated P7/P7R B dimension
03/23/2012
1.02
V-Infinity branding removed
08/21/2012
1.03
updated safety approvals
04/29/2013
1.04
updated datasheet
07/17/2015
1.05
updated to medical 60601-1 4th edition
06/20/2017
The revision history provided is for informational purposes only and is believed to be accurate.
Headquarters
20050 SW 112th Ave.
Tualatin, OR 97062
800.275.4899
Fax 503.612.2383
cui.com
techsupport@cui.com
This device complies with part 15 of the FCC Rules. Operation is subject to the following two conditions:
(1) This device may not cause harmful interference, and
(2) this device must accept any interference received, including interference that may cause undesired operation.
CUI offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI reserves the right to make changes to the product at any time without notice. Information provided by CUI is believed to be accurate and reliable. However, no responsibility is
assumed by CUI for its use, nor for any infringements of patents or other rights of third parties which may result from its use.
CUI products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical
component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to
affect its safety or effectiveness.
很抱歉,暂时无法提供与“EMMA120110-P5P-IC”相匹配的价格&库存,您可以联系我们找货
