T5989DV
T5989DV
    RASPBERRYPI(树莓派)
    T5989DVMICROUSBPOWERSUPPLY5
T5989DV 数据手册
T5989DV-RS Raspberry Pi Power Supply Features: •Official Raspberry Pi Power Supply • 1.5M Micro USB B Lead •ErP Level 6 Efficiency Rating •50,000 Hour MTBF •1 Years Warranty 1 Year Warranty Input Output Output Voltage +5.1Vdc Input Voltage Range 90-264VAC Minimum Load Current 0A Input Frequency 47-63Hz Nominal Load Current 2.5A Input Current 0.5A Max Nominal Output Power 13W Inrush Current No damage and IP fuse will not blow Output Regulation +/-5% AC Inlet UK, Euro, Aus & US changeable heads Line Regulation +/-2% Ripple & Noise 120mVp-p Maximum Dimensions 73.2 (L) * 45.1 (W) * 35.1 (H) mm Rise Time 100mS Maximum at nominal input Weight Approx 150g Turn-on Delay 3 Seconds Maximum at nominal input Operating Temp. 0 °C to 40 °C Protection Short circuit, over current, over voltage Storage Temp. -20 °C to +60 °C Efficiency 80.86% Opertating Humidity 20 ~ 85 % RH. Non-Condesning Output Cable 1500mm Micro USB B 5 Pin MTBF 50,000 Hours Other Diagrams Chancerygate Business Centre, Cradock Road, Reading, Berkshire, RG2 0AH. Tel: +44 (0) 118 931 1199 • Fax: +44 (0) 118 931 1145 • Email: info@stontronics.co.uk • Web: www.stontronics.co.uk Please Note: Image shown is representative of entire range. Individual PSU image &/or drawings or data sheets available on request. Stontronics Ltd accepts no responsibility for typographical errors in the production of this leaflet. Product specifications are subject to change without notice.
T5989DV 价格&库存
很抱歉,暂时无法提供与“T5989DV”相匹配的价格&库存,您可以联系我们找货
