TE240A1251F01
TE240A1251F01
    SLPOWER
    ITE,SWITCHINGEXTERNALPSU,200
TE240A1251F01 数据手册
240W Single Output External Power Industrial Grade TE240 Family FEATURES AND BENEFITS Industrial Meets DoE efficiency level VI requirements No load input power Average efficiency Meets EN55011/CISPR11, FCC Part 15.109 Class B conducted & radiated emissions, with 6db margin Up to 240W of AC-DC power Approved to EN/IEC/UL62368-1 Universal input 90-264VAC input range E-cap life of >7 years IP22 rated enclosure 3 years warranty Meets “Heavy Industrial” levels of EN61000 EMC requirements Optional AC input on/off switch MODEL SELECTION Model Number4 Volts Output Current Output Power Ripple & Noise1 Line Regulation Load Regulation TE240A1251F01 12.0V 16.6A 200W 120mV pk-pk ±1% ±5% TE240A1551F01 15.0V 13.3A 200W 150mV pk-pk ±1% ±5% 8)%* 18.0V 11.1A 200W 180mV pk-pk ±1% ±5% TE240A2451F01 24.0V 10.0A 240W 240mV pk-pk ±1% ±5% TE240A2851F01 28.0V 8.60A 240W 280mV pk-pk ±1% ±5% TE240A4851F01 48.0V 5.00A 240W 480mV pk-pk ±1% ±5% Output Cable & Connector Input Configuration 6 pin Molex type, p/n 39-01-2060 or equivalent See outline drawing for pinout information Class I Desktop, IEC60320 C14 receptacle Notes : 1. Measured at the output connector, with noise probe directly across output and load, terminated with 0.1μF ceramic and 47μF low ESR capacitors. 2. The DC output is floating. For Input Class I models, AC GND is connected to output common (-), on models with the letter “B” inserted in the model number where the “A” is located:(TE240B1251F01). 3. All specifications are typical at nominal input, full load, at 25°C ambient unless noted. 4. Consult factory for availability of 28V output model. OUTPUT INPUT AC Input 100-240VAC, ±10%, 47-63Hz, 1Ø Hold-Up Time 20ms at full load, 100VAC input Input Current 115VAC: 2.4A, 230VAC: 1.2A Turn On Time Less than 1 sec @115VAC, Full load Inrush Current 264VAC, Cold start: will not exceed 60A Output Power Input Fuses F1, F2: 3.15A, 250VAC fuses (line & neutral lines) provided on all models 240W continuous – See models chart for specific voltage model ratings Output Voltage See models chart on pg 1 Earth Leakage Current Input-GND:
TE240A1251F01 价格&库存
很抱歉,暂时无法提供与“TE240A1251F01”相匹配的价格&库存,您可以联系我们找货
