Additional Resources:
Product Page
date
04/18/2013
page
1 of 5
SERIES: EPS 6W │ DESCRIPTION: AC-DC POWER SUPPLY
up to 6 W power
compact size
single output from 3~24 V
over voltage and short circuit protections
custom designs available
U
ED
FEATURES
output
voltage
output
current
output
power
ripple
and noise1
(Vdc)
max
(A)
max
(W)
max
(mVp-p)
1
3
100
IV
1
3.3
100
IV
1
4.5
100
V
1
5
100
V
1
6
100
V
7.5
0.8
6
100
IV
9
0.66
6
100
V
12
0.5
6
120
V
15
0.4
6
150
V
18
0.33
6
180
V
24
0.25
6
240
IV
3
EPS033100
3.3
EPS045100
4.5
EPS050100
5
EPS060100
6
N
EPS030100
EPS075080
EPS090066
EPS180033
EPS240025
efficiency
level
1. At full load, 100 ~ 132 Vac input, 20 MHz bandwidth oscilloscope, each output terminated with 10 µF aluminum electrolytic and 0.1 µF ceramic capacitors.
IS
C
Notes:
O
EPS120050
EPS150040
TI
MODEL
N
RoHS
D
PART NUMBER KEY
Base Number
example of 3 Vdc, 1 A
EPS030100 - PXXXX - CXX
DC Plug Type
cui.com
Reserved for Custom
Configurations
Product Page
CUI Inc │ SERIES: EPS 6W │ DESCRIPTION: AC-DC POWER SUPPLY
date 04/18/2013 │ page 2 of 5
INPUT
parameter
conditions/description
min
voltage
47
current
inrush current1
no load power consumption
15V, 18V and 24V model
at 100 Vac
at 132 Vac
all other models
at 132 Vac
level IV models
level V models
1. inrush lasts no longer than 0.5 ms before settling to steady state current
line regulation
all other models
7.5V model
min
load regulation
N
parameter
U
OUTPUT
temperature coefficient
0 ~ 40°C, full load, after initial 1 hour warm-up
start-up
time needed to reach regulation
hold-up
at 115 Vac, full load
clamped by internal protection zener
continuous, auto-recovery upon removal of short
isolation voltage
isolation resistance
safety approvals
EMI/EMC
typ
63
Hz
0.15
A
15
30
A
A
40
A
0.5
0.3
W
W
max
units
±5
±0.02
%/°C
3
input to output at 500 Vdc
s
ms
min
typ
min
typ
max
units
max
units
3,000
4,242
Vdc
Vdc
100
MΩ
UL 1310
class II
FCC Part 15 Class B
leakage current
RoHS compliant
Vac
±1
±2
input to output at 10 mA for 1 minute
IS
C
safety
O
parameter
N
parameter
over voltage protection
SAFETY & COMPLIANCE
units
132
10
TI
PROTECTIONS
max
ED
frequency
Notes:
typ
100
0.25
mA
max
units
yes
ENVIRONMENTAL
parameter
min
°C
storage temperature
-10
70
°C
operating humidity
10
90
D
operating temperature
typ
storage humidity
cui.com
Product Page
date 04/18/2013 │ page 3 of 5
MECHANICAL
min
input plug
fixed US
MECHANICAL DRAWING
units: mm
tolerance: X.X ±0.5
X.XX ±0.03
42
1.0
26.8
1.0
12.7
62.33
1.0
IS
C
O
N
TI
22.3X18.0
1830 100
6.3
D
3.0
(TYP)
cui.com
max
units
mm
N
17.06
1.18
typ
ED
62.33 x 26.8 x 42 (2.454 x 1.055 x 1.654 inch)
U
parameter
dimensions
Product Page
date 04/18/2013 │ page 4 of 5
OUTPUT PLUG OPTIONS
IJĵġƲıįĶ
ED
ǹĴįĶġĬıİĮıįIJ
ǹĴįĶġĬıİĮıįIJ
3.5 mm Phono Plug
IJĵġƲıįĶ
P1
P1R
ń
Standard PXX
C
Unit
121
mm
5.5
2.5
12
mm
P7/P7R
3.5
1.35
9.5
mm
P8/P8R
3.8
1.35
9.5
mm
3.8
1.05
9.5
mm
P9/P9R
N
ł
O
IS
C
Ń
ń
B
2.1
P6/P6R
Notes:
Ń
ł
Ń
ń
A
5.5
N
Right Angle PXR
Locking DC Plug
EIAJ Plugs
P5/P5R
TI
Standard PX
Ń
ł
Ń
ł
ń
ł
U
Standard DC Plug
1. EPS050100-P5P has a 9.5mm dc plug length
A
B
5.5
2.1
9.5
mm
P11
5.5
2.5
9.5
mm
EIAJ
A
B
C
D
Unit
P12/P12R
EIAJ-1
2.35
0.7
9.5
NA
mm
P13/P13R
EIAJ-2
4.0
1.7
9.5
5.0
mm
P14/P14R
EIAJ-3
4.75
1.7
9.5
5.0
mm
Right Angle PXXR
Ņ
D
Stripped and Tinned
ijĶƲĶ
DC PLUG TYPE
stripped and tinned
PXX X X
Plug type
Plug angle:
“blank” = standard
R = right angle
Plug polarity:
“blank” = N/A
P = center positive
N = center negative
cui.com
Unit
P10
ń
ST
C
Product Page
date 04/18/2013 │ page 5 of 5
REVISION HISTORY
rev.
description
date
initial release
applied new spec template
06/29/2006
1.02
removed multiple models, applied new spec template
1.03
updated P7/P7R B dimension
1.04
V-Infinity branding removed, safety and EMI/EMC data updated
08/16/2012
1.05
added 7.5V model
09/24/2012
1.06
updated P5 & P6 plug lengths
ED
1.0
1.01
12/28/2010
05/26/2011
04/13/2012
U
04/18/2013
D
IS
C
O
N
TI
N
The revision history provided is for informational purposes only and is believed to be accurate.
Headquarters
20050 SW 112th Ave.
Tualatin, OR 97062
800.275.4899
Fax 503.612.2383
cui.com
techsupport@cui.com
This device complies with part 15 of the FCC Rules. Operation is subject to the following two conditions:
(1) This device may not cause harmful interference, and
(2) this device must accept any interference received, including interference that may cause undesired operation.
CUI offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI reserves the right to make changes to the product at any time without notice. Information provided by CUI is believed to be accurate and reliable. However, no responsibility is
assumed by CUI for its use, nor for any infringements of patents or other rights of third parties which may result from its use.
CUI products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical
component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to
affect its safety or effectiveness.
很抱歉,暂时无法提供与“EPS050100-P5RP”相匹配的价格&库存,您可以联系我们找货
