Additional Resources:
Product Page
date
08/21/2012
page
1 of 5
SERIES: EMSA 6W │ DESCRIPTION: AC-DC POWER SUPPLY
up to 6 W power
interchangeable AC blades
universal input (90~264 Vac)
single regulated output from 5~15 V
over voltage and short circuit protections
UL/cUL, GS, RCM, CCC, PSE safety approvals
level V efficiency
custom designs available
U
ED
FEATURES
EMSA050120
output
voltage
output
current
output
power
ripple
and noise1
(Vdc)
max
(A)
max
(W)
max
(mVp-p)
1.2
6
150
V
0.67
6
150
V
0.50
6
120
V
0.40
6
150
V
5
9
EMSA120050
12
EMSA150040
15
Notes:
N
EMSA090067
TI
MODEL
N
RoHS
efficiency
level
1. At full load, 100 ~ 240 Vac input, 20 MHz bandwidth oscilloscope, each output terminated with 10 μF aluminum electrolytic and 0.1 μF ceramic capacitors.
O
PART NUMBER KEY
D
IS
C
EMSA120050 X - XX - SZ - CXX
Base Number
example of 12 Vdc, 0.5 A
DC Plug Type
Blades:
“blank” = North American, European, United Kingdom,
Australian, and China blades included
N = North American blade included
E = European blade included
B = United Kingdom blade included
A = Australian blade included
C = China blade included
K = No blades included
cui.com
Factory
Designation
Reserved for Custom
Configurations
Product Page
CUI Inc │ SERIES: EMSA 6W │ DESCRIPTION: AC-DC POWER SUPPLY
date 08/21/2012 │ page 2 of 5
INPUT
parameter
conditions/description
min
90
frequency
47
current
9 V output at 115 V ac, cold start
9 V output at 230 V ac, cold start
all other outputs: 115 V ac, cold start
all other outputs: 230 V ac, cold start
inrush current
no load power consumption
min
line regulation
PROTECTIONS
parameter
protect through primary circuit IC
output shut down and auto restart
TI
over voltage protection
SAFETY & COMPLIANCE
parameter
min
input to output at 10 mA for 1 minute
isolation resistance
input to output at 500 V dc
N
isolation voltage
UL 60950-1, EN 60950-1/IEC 60950-1, RCM, CCC, PSE
EMI/EMC
FCC Part 15B, EN 55022B, CE
leakage current
9 V output
all other outputs
O
safety approvals
RoHS compliant
units
264
Vac
Hz
typ
0.3
A RMS
15
30
30
60
A
A
A
A
0.3
W
max
units
±3
±5
N
load regulation
max
63
U
OUTPUT
parameter
typ
ED
voltage
typ
max
units
3,000
4,242
Vac
Vdc
100
MΩ
0.25
0.1
mA
mA
max
units
yes
ENVIRONMENTAL
min
IS
C
parameter
°C
storage temperature
-10
70
°C
operating humidity
storage humidity
10
90
D
operating temperature
typ
cui.com
Product Page
date 08/21/2012 │ page 3 of 5
MECHANICAL
dimensions
2.520 x 1.594 x 1.181 (64 x 40.5 x 30 mm)
min
input plug
multi-blade (US, UK, Europe, Australia, China)
typ
max
units
inch
ED
parameter
MECHANICAL DRAWING
units: mm
30±1.0
U
40.5±1
62±1.0
O
N
TI
N
64±1.0
IS
C
EMS-US
EMS-UK
EMS-EU
EMS-AU
EMS-CC
D
DC CORD
21±3
cord length
100±20
2.8~4.0mm
100±20
S&T
35B
70±10
Black wire, white stripe: Positive
cui.com
MODEL NO.
CABLE GAUGE
CORD LENGTH
EMSA050120
20 AWG
1530 ± 100
EMSA090067
22 AWG
1530 ± 100
EMSA120050
22 AWG
1530 ± 100
EMSA150040
22 AWG
1530 ± 100
Product Page
date 08/21/2012 │ page 4 of 5
OUTPUT PLUG OPTIONS
14±0.5
ED
ø3.5 +0/-0.1
ø3.5 +0/-0.1
3.5 mm Phono Plug
14±0.5
*Tip positive
P1
P1R
C
A
B
C
Unit
5.5
2.1
9.5
mm
P6/P6R
5.5
2.5
9.5
mm
P7/P7R
3.5
1.35
9.5
mm
P8/P8R
3.8
1.35
9.5
mm
P9/P9R
3.8
1.05
9.5
mm
N
O
B
N
B
A
C
C
B
Right Angle PXR
Locking DC Plug
EIAJ Plugs
A
TI
Standard PX
P5/P5R
B
A
B
A
C
A
U
Standard DC Plug
A
B
C
Unit
P10
5.5
2.1
9.5
mm
P11
5.5
2.5
9.5
mm
EIAJ
A
P12/P12R
EIAJ-1
2.35
0.7
9.5
NA
mm
P13/P13R
EIAJ-2
4.0
1.7
9.5
5.0
mm
P14/P14R
EIAJ-3
4.75
1.7
9.5
5.0
mm
IS
C
C
Standard PXX
Right Angle PXXR
D
Stripped and Tinned
25±5
9±2
D
DC PLUG TYPE
ST
Stripped and Tinned
PXX X X
Plug Type
Plug Angle:
“Blank” = Standard
R = Right Angle
Plug Polarity:
“Blank” = N/A
P = Center Positive
N = Center Negative
*Contact CUI for additional output plug options.
cui.com
B
C
D
Unit
Product Page
date 08/21/2012 │ page 5 of 5
REVISION HISTORY
description
date
07/28/2010
1.0
initial release
1.01
new template applied
1.02
PSE safety approval added
1.03
updated P7/P7R B dimension
1.04
ED
rev.
08/08/2011
09/07/2011
03/23/2012
V-Infinity branding removed, safety data updated
08/21/2012
D
IS
C
O
N
TI
N
U
The revision history provided is for informational purposes only and is believed to be accurate.
Headquarters
20050 SW 112th Ave.
Tualatin, OR 97062
800.275.4899
Fax 503.612.2383
cui.com
techsupport@cui.com
This device complies with part 15 of the FCC Rules. Operation is subject to the following two conditions:
(1) This device may not cause harmful interference, and
(2) this device must accept any interference received, including interference that may cause undesired operation.
CUI offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI reserves the right to make changes to the product at any time without notice. Information provided by CUI is believed to be accurate and reliable. However, no responsibility is
assumed by CUI for its use, nor for any infringements of patents or other rights of third parties which may result from its use.
CUI products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical
component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to
affect its safety or effectiveness.
很抱歉,暂时无法提供与“EMSA120050-P6P-SZ”相匹配的价格&库存,您可以联系我们找货
