EMSA200200K-P5P-SZ
EMSA200200K-P5P-SZ
    CUIDEVICES
    AC/DC WALL MOUNT ADAPTER 20V 40W
EMSA200200K-P5P-SZ 数据手册
Additional Resources: Product Page date 08/21/2012 page 1 of 5 SERIES: EMSA 40W │ DESCRIPTION: AC-DC POWER SUPPLY up to 40 W power interchangeable AC blades universal input (90~264 Vac) single regulated output from 12~24 V over voltage and short circuit protection UL/cUL, GS, RCM, CCC, PSE safety approvals level V efficiency custom designs available U • • • • • • • • ED FEATURES output voltage output current (Vdc) max (A) EMSA120300 12 EMSA200200 20 EMSA240167 24 ripple and noise1 max (W) max (mVp-p) 3.0 36 300 efficiency level V 2.0 40 300 V 1.67 40 300 V 1. At full load, 100 ~ 240 Vac input, 20 MHz bandwidth oscilloscope, each output terminated with 10 μF aluminum electrolytic and 0.1 μF ceramic capacitors. O PART NUMBER KEY N Notes: output power TI MODEL N RoHS D IS C EMSA120300 X - XX - SZ - CXX Base Number example of 12 Vdc, 3 A DC Plug Type Blades: “blank” = North American, European, United Kingdom, Australian, and China blades included N = North American blade included E = European blade included B = United Kingdom blade included A = Australian blade included C = China blade included K = No blades included cui.com Factory Designation Reserved for Custom Configurations Additional Resources: Product Page CUI Inc │ SERIES: EMSA 40W │ DESCRIPTION: AC-DC POWER SUPPLY date 08/21/2012 │ page 2 of 5 INPUT conditions/description min voltage 90 frequency 47 current no load power consumption OUTPUT parameter conditions/description min line regulation PROTECTIONS conditions/description over voltage protection output voltage clamped by internal protection zener short circuit protection output shut down and auto restart Vac 63 TI parameter units 264 Hz typ 1.0 A RMS 0.3 W max units ±1 % ±5 % N parameter SAFETY & COMPLIANCE max U load regulation typ ED parameter conditions/description min isolation voltage input to output at 10 mA for 1 minute isolation resistance input to output at 500 V dc typ max units 3,000 4,242 Vac Vdc 100 MΩ UL 60950-1, EN 60950-1/IEC 60950-1, RCM, CCC, PSE EMI/EMC FCC part 15B, CISPR 22 Class B, EN 61204-3, EN 55022 Class B, EN 55024, EN 61000-3-(2, 3), IEC 6100-3-(2, 3), IEC 6100-4-(2, 3, 4, 5, 6, 11), CE leakage current yes O RoHS compliant N safety approvals 0.25 mA max units ENVIRONMENTAL parameter operating temperature conditions/description min typ 0 40 °C -10 70 °C operating humidity 20 80 % storage humidity 10 90 % D IS C storage temperature cui.com Additional Resources: Product Page CUI Inc │ SERIES: EMSA 40W │ DESCRIPTION: AC-DC POWER SUPPLY date 08/21/2012 │ page 3 of 5 MECHANICAL parameter conditions/description dimensions 2.913 x 1.713 x 1.390 (74 x 43.5 x 35.3 mm) min input plug multi-blade (US, UK, Europe, Australia, China) max units ED inch MECHANICAL DRAWING units: mm typ 43.5±1.0 U 35.3±1.0 O N TI N 74±1.0 EMS-US IS C DC CORD EMS-UK EMS-EU 10±3 D cord length Black wire, white stripe: Positive EMS-CC EMS-AU 2.8~4.0mm 50±10 S&T 48B 70±10 Ferrite core with one turns wire 12x20x7.3(018) cui.com MODEL NO. CABLE GAUGE CORD LENGTH EMSA120300 18 AWG 1530 ± 100 EMSA200200 20 AWG 1530 ± 100 EMSA240167 20 AWG 1530 ± 100 Additional Resources: Product Page CUI Inc │ SERIES: EMSA 40W │ DESCRIPTION: AC-DC POWER SUPPLY date 08/21/2012 │ page 4 of 5 OUTPUT PLUG OPTIONS ED 14±0.5 14±0.5 *Tip positive P1 P1R C C Unit 9.5 mm N B 2.1 P6/P6R 5.5 2.5 9.5 mm P7/P7R 3.5 1.35 9.5 mm P8/P8R 3.8 1.35 9.5 mm P9/P9R 3.8 1.05 9.5 mm A B C Unit P10 5.5 2.1 9.5 mm P11 5.5 2.5 9.5 mm B A O N B A C C B Right Angle PXR Locking DC Plug EIAJ Plugs A 5.5 TI Standard PX P5/P5R Standard PXX B A B A C A U Standard DC Plug IS C D ø3.5 +0/-0.1 ø3.5 +0/-0.1 3.5 mm Phono Plug EIAJ A B C D Unit P12/P12R EIAJ-1 2.35 0.7 9.5 NA mm P13/P13R EIAJ-2 4.0 1.7 9.5 5.0 mm P14/P14R EIAJ-3 4.75 1.7 9.5 5.0 mm C Right Angle PXXR D Stripped and Tinned 25±5 9±2 DC PLUG TYPE ST Stripped and Tinned PXX X X Plug Type Plug Angle: “Blank” = Standard R = Right Angle Plug Polarity: “Blank” = N/A P = Center Positive N = Center Negative *Contact CUI for additional output plug options. cui.com Additional Resources: Product Page CUI Inc │ SERIES: EMSA 40W │ DESCRIPTION: AC-DC POWER SUPPLY date 08/21/2012 │ page 5 of 5 REVISION HISTORY description date 06/21/2010 1.0 initial release 1.01 new template applied 1.02 PSE safety approval added 1.03 updated P7/P7R B dimension 1.04 ED rev. 08/08/2011 09/07/2011 03/23/2012 V-Infinity branding removed, safety and EMI/EMC data updated 08/21/2012 D IS C O N TI N U The revision history provided is for informational purposes only and is believed to be accurate. Headquarters 20050 SW 112th Ave. Tualatin, OR 97062 800.275.4899 Fax 503.612.2383 cui.com techsupport@cui.com This device complies with part 15 of the FCC Rules. Operation is subject to the following two conditions: (1) This device may not cause harmful interference, and (2) this device must accept any interference received, including interference that may cause undesired operation. CUI offers a one (1) year limited warranty. Complete warranty information is listed on our website. CUI reserves the right to make changes to the product at any time without notice. Information provided by CUI is believed to be accurate and reliable. However, no responsibility is assumed by CUI for its use, nor for any infringements of patents or other rights of third parties which may result from its use. CUI products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness.
EMSA200200K-P5P-SZ 价格&库存
很抱歉,暂时无法提供与“EMSA200200K-P5P-SZ”相匹配的价格&库存,您可以联系我们找货
