PW170KB
Universal 10 – 15 Watt Series
ITE Switch-Mode Power Supply
3 Year Warranty
•100-240VAC Universal Input
•Desktop and Wall-Plug Style with either fixed blades, or
Interchangeable Blades* ( Kit sold separately)
•5V to 48V Single Output Models, up to 15W
•Modified and Custom Designs Available
•Regulated Output with Low Ripple
•Impact-Resistant Polycarbonate Enclosure
•No load Power Consumption < 0.5W
•Meets EISA Requirements (see next page for details).
•Meets Energy Star Level IV
Specifications
All Specifications are typical at nominal input, full load at 25°C unless otherwise stated.
AC Input
100-240VAC, -/-10% (class I), +6%, -10% (class II), 47-63 Hz, 1∅.
Input Current
90VAC: 0.4A
Inrush Current
Inrush limiting provided.
Input Fuses
Internal Primary Current Fuse is provided.
Efficiency
Meet EISA Requirements – see page 2
Output Voltage
See chart.
Output Power
See chart
Ripple and Noise
1% pk-pk max., 20MHz BW
Line & Load Voltage Regulation
Excluding Cord: Line: +/- 1%, Load: +/-5%.
Transient Response
500µs max., 50% load step, typical
Minimum Load
Not required.
Case Material:
Black 94V0 Polycarbonate
Case Dimensions:
See outline drawing.
MTBF
>100,000 hours (calculated)
Hold-up Time
18 ms min. @ 115VAC
Overvoltage Protection
Built-in
Overload Protection
Hiccup Mode
Short Circuit Protection
Hiccup Mode
Topology
Switching – Fixed Frequency Flyback
Approvals and Safety Standards
EN/IEC/CSA/UL60950-1, EMC: EN55022/55024/61000
Dielectric Withstand
Input-Output: 3000VAC, Input-GND: 1500VAC, Output-GND: 500VDC
Operating Temperature
0° to 40°C, no derating
Storage Temperature
-30 to +85°C.
Relative Humidity
5% to 95%, non-condensing
Altitude
0 to 10,000 ft.
Output Connections:
Cable: 18AWG, 1800mm (5V & 6V models: 1500mm), 2 conductor.
Connector: 2.5mm barrel type (Ault #3) connector, center contact (+).
Other connector options are available.
Model Number Key
PW170 K B 05 03 F 01
Modification Designator. "01" is standared part, "02" and higher denotes a modified model.
Input Receptacle. See Below for options. "F" receptacle (IEC320, C14 type, grounded) noted above.
Output Connector. "03" connector is standard. Other output connectors available. Contact the factory for more details
Output Voltage
Design Revision Changes
Manufacturing Location
Product Family
______________________________________________________________________________________________________________________________
SL Power Electronics Corp • 6050 King Drive Ventura, CA 93003 • Phone 805.486.4565 • Fax 858.712.2040 • Email: info@slpower.com • www.slpower.com
1 of 3
PW170KB
Universal 10-15 Watt Series
ITE Switch Mode Power Supply
3 Year Warranty
Model Number
Volts (V)
Output Current (max)
Max Watts
Ripple (Vp-p max)
PW170KB0503F01
5V
2.00 A
10.0 W
50mV
PW170KB0603F01
6V
1.67 A
12.0 W
60mV
PW170KB0903F01
9V
1.50 A
13.5 W
90mV
PW170KB1203F01
12 V
1.20 A
15.0 W
120mV
PW170KB1503F01
15 V
1.00 A
15.0 W
150mV
PW170KB1803F01
18 V
0.84 A
15.0 W
180mV
PW170KB2403F01
24 V
0.63 A
15.12 W
240mV
PW170KB4803F01
48 V
0.32 A
14.88 W
480mV
Note: Part numbers above include #3 output connector and IEC320 C14 grounded input receptacle. See below for other options.
Input Receptacle Options
DESKTOP OPTIONS
WALL-PLUG OPTIONS
IEC320
C14
Grounded
IEC320
C18
Ungrounded
IEC320
C8
"Shaver"
(F)
(Q)
(N)
Notes:
Output Connector
N. America
Japan
Europe
Interchangeable
N. America
Japan
Fixed
Australia
Fixed
United
Kingdom
Fixed
(B)
(C)
(M)
(G)
(H)
Fixed
1. For Desktop options, choose the applicable letter above.
2. For Wall-plug options, choose the applicable letter above. The model will then be fitted only with the
receptacle chosen. The North American blade version (B) will be an interchangeable blade. The other
options (C), (M), (G), and (H), will be fixed blades molded in the case.
3. Blade Kit is available which will include one each of a EU, UK, and Aust blade. Kit part number is
KT1027K . Can be used with (B) version only, to allow blades to be interchanged.
Notes:
1 Ault #3 Connector
2. Center Contact = Positive
3. Connector is Switchcraft 760 plug or equivalent.
4. Suggested Mating Connector is Switchcraft 712A jack or
equivalent.
5. Other output connector options are available. Contact your
local representative for details.
2007 Energy Independence and Security Act - EISA
The Energy Independence and Security Act of 2007 was passed in December of 2007 and addresses minimum efficiency standards and standby
levels for Class A external power supplies that are 250 Watts and under. This law stipulates that external power supplies manufactured on July 1,
2008 and beyond meet certain minimum efficiency and standby criteria as defined below.
Minimum Efficiency Criteria:
Active mode is defined as when a power supply’s input is connected to a line voltage AC and it’s output is connected to a DC or AC load, drawing a
portion of the product’s power output. Depending upon the power rating for the power supply, it must meet the minimum efficiency criteria outlined
below.
Energy-Efficiency Criteria for Active Mode:
Output Power on Adapter Label
0 to < 1 Watt
> 1 watt to ≤ 51 watts
> 51 watts
Minimum Average Efficiency Percentage
≥ 0.50 * output power on the label
≥ [0.09 * Ln (output power on adapter label)] + 0.50
≥ 0.85
Energy Consumption Criteria for No Load Mode:
The power supply must also meet a requirement for when its input is connected to line voltage AC but its output is not connected to a load.
Depending upon the power output of the supply, it must keep its energy consumption below the following values:
Maximum Power Consumption in No-Load Mode
0 to < 250 Watts
≤ 0.50 watts
2 of 3
PW170KB
3 Year Warranty
Outline Drawings
Dimensions are in mm
Desktop Style (Option “F” shown)
Wallplug Style (Option “B” shown)
Data Sheet © 2008 SL Power Electronics Corp. The information and specifications contained herein are believed to be correct at the time of publication.
Rev. 8-10-2009
However, SL Power accepts no responsibility for consequences arising from reproduction errors or inaccuracies. Specifications are subject to change without notice.
3 of 3
很抱歉,暂时无法提供与“PW170KB0903F01”相匹配的价格&库存,您可以联系我们找货
