MENB1060A1203F01
MENB1060A1203F01
    SLPOWER
    AC/DC DESKTOP ADAPTER 12V 60W
MENB1060A1203F01 数据手册
MENB1060 Universal Input 60 Watt Series Medical Switch-Mode Power Supply 3 Year Warranty •100-240VAC Universal Input •Meets EISA2007, CEC Efficiency Level V, EU (EC) No 278/2009 Phase II •Certified to UL/EN60601-1 •Desktop Style •5V to 24V Single Output Models, up to 60W •Modified and Custom Designs Available •Regulated Output with Low Ripple •Impact-Resistant Polycarbonate Enclosure •No Load Power Consumption 100,000 hours (calculated) 18 ms min. @ 115Vac, 60 ms min. @ 240 Vac Overload Protection Hiccup Mode Short Circuit Protection Hiccup Mode Topology Switching – Fixed Frequency Flyback Safety Standards EN/IEC/CSA/UL60601-1 EMC Dielectric Withstand Operating Temperature See chart below Input-Output: 5,656Vdc, Input-GND: 1,500 Vac, Output-GND: 500Vdc 0° to 40°C, no derating Storage Temperature Relative Humidity -30 to +85°C 5% to 95%, non-condensing Altitude 0 to 10,000 ft Output Cable 5V – 9V models: #18AWG (UL2464), 1,200mm, 4 conductor 12V – 15V models: #18AWG (UL2464), 1,500mm, 4 conductor 18V – 24V models: #18AWG (UL2464), 1,500mm, 2 conductor Output Connector 5V model: Molex 39-01-2060 or equiv. (Ault #51) Other models: 2.5mm barrel type (Ault #3), center contact positive (+) EMC Specifications Conducted Emissions EN55011 Class B, FCC Part 15, Class B. Radiated Emissions EN55011 Class B, FCC Part 15, Class B. Line Frequency Harmonics EN61000-3-2, Class A Voltage Fluctuations/Flicker EN61000-3-3 Static Discharge Immunity EN61000-4-2, 6kV Contact Discharge, 8kV air discharge Radiated RF Immunity EN61000-4-3, 3V/m. EFT/Burst Immunity EN61000-4-4, 2kV/5kHz. Line Surge Immunity EN61000-4-5, 1kV differential, 2kV common-mode Conducted RF Immunity EN61000-4-6, 3Vrms Power Frequency Magnetic Field Immunity EN61000-4-8, 3A/m Voltage Dip Immunity EN61000-4-11, Criteria A ______________________________________________________________________________________________________________________________ 1 of 2 SL Power Electronics Corp • 6050 King Drive Ventura, CA 93003 • Phone 805.486.4565 • Fax 858.712.2040 • Email: info@slpower.com • www.slpower.com MENB1060 Universal 60 Watt Series Medical Switch Mode Power Supply Model Number 3 Year Warranty Volts (V) Output Current (max) Max Watts Ripple (Vp-p max) 5V 7.00 A 35.0 W 50mV MENB1060A0903F01 9V 6.00 A 54.0 W 90mV MENB1060A1203F01 12 V 5.00 A 60.0 W 120mV MENB1060A1503F01 15 V 4.00 A 60.0 W 150mV MENB1060A1803F01 18 V 3.40 A 61.2 W 180mV MENB1060A2403F01 24 V 2.70 A 64.8 W 240mV MENB1060A0551F01 Model Number Key MENB 1 060 A VV 03 F 01 Model Input Connector: Output Connector: Output Voltage: Model Output Pow er: # of Outputs Product Fam ily: Input Receptacle Options IEC320 C14 IEC320 C18 Grounded Ungrounded (F) (Q) "01" = Standard. "02" and higher indicates a m odified m odel. "F" = IEC320 C14 grounded, Other options available, see next page. "03" = 2.5m m Barrel Type Connector. Other options available, contact factory. "05" = 5Vdc, "12" = 12Vdc, "24" = 24Vdc, etc. "A" = Original Configuration "060" = 60 Watts "1" = Single Output "M" = Medical, "E" = External, "NB" = Model Series Designator Output Connector Output Connector (5V Model) IEC320 C8 "Shaver" (N) Pins 1,4 = (+), Pins 3,6 = (-) Outline Drawing DATE CODE Dimensions are in mm (Cable length is 1200mm on 5V thru 12V models) Data Sheet © 2010 SL Power Electronics Corp. The information and specifications contained herein are believed to be correct at the time of publication. Rev. 12-22-2010 However, SL Power accepts no responsibility for consequences arising from reproduction errors or inaccuracies. Specifications are subject to change without notice. ______________________________________________________________________________________________________________________________ 2 of 2 SL Power Electronics Corp • 6050 King Drive Ventura, CA 93003 • Phone 805.486.4565 • Fax 858.712.2040 • Email: info@slpower.com • www.slpower.com
MENB1060A1203F01
物料型号:MENB1060系列
器件简介:这是一款通用输入60瓦的医疗开关电源,具有3年保修期,符合EISA2007、CEC效率等级V和EU (EC) No 278/2009第二阶段的能效标准,并通过UL/EN60601-1认证。
引脚分配:文档中未明确提供引脚分配信息,但提到了输入连接器和输出连接器的配置。
参数特性: - AC输入电压:100-240Vac,频率47-63 Hz - 输入电流:在100Vac时最大1.5A - 效率:满足EISA2007、CEC效率等级V和EU (EC) No 278/2009第二阶段标准 - 输出电压和功率:根据不同型号,提供5V至24V的单输出,功率最高60W - 纹波和噪声:最大1%峰-峰值 - 线路/负载电压调节:线路±1%,负载±5% - 操作温度:0°至40°C,无需降额 - 存储温度:-30至+85°C
功能详解:电源具有过载保护和短路保护,均采用Hiccup模式。瞬态响应时间最大为500ms,50%负载步变。
应用信息:适用于需要医疗级电源的应用场合,如医疗设备。
封装信息:电源采用抗冲击聚碳酸酯外壳,具体尺寸见轮廓图。重量为400克。
EMC规格:包括传导发射、辐射发射、线路频率谐波、电压波动/闪烁、静电放电抗扰度、辐射射频抗扰度等。
输出连接器:5V型号使用Molex 39-01-2060或等效连接器,其他型号使用2.5mm筒型连接器,中心接触为正(+)。
MENB1060A1203F01 价格&库存
很抱歉,暂时无法提供与“MENB1060A1203F01”相匹配的价格&库存,您可以联系我们找货
