ETMA360166UD-P5P-IC
ETMA360166UD-P5P-IC
    CUIDEVICES
    AC/DC DESKTOP ADAPTER 36V 60W
ETMA360166UD-P5P-IC 数据手册
Additional Resources: Product Page | 3D Model date 06/20/2017 page 1 of 4 SERIES: ETMA 60W UD │ DESCRIPTION: MEDICAL AC-DC POWER SUPPLY FEATURES • • • • • • • • up to 60 W power universal input (90~264 Vac) single regulated output from 12~48 Vdc over voltage and short circuit protections medical 60601-1 4th edition safety approvals designed for 2 x MOPP applications level V efficiency custom designs available IEC 60601-1 EN 60601-1 ® MODEL output voltage output current output power ripple and noise1 (Vdc) max (A) max (W) max (mVp-p) ETMA120500UD 12 5 60 120 V ETMA150400UD 15 4 60 150 V ETMA180333UD 18 3.33 60 180 V ETMA240250UD 24 2.5 60 240 V ETMA360166UD 36 1.66 60 360 V ETMA480125UD 48 1.25 60 480 V Notes: efficiency level 1. At full load, 100 ~ 240 Vac input, 20 MHz bandwidth oscilloscope, each output terminated with 10 µF aluminum electrolytic and 0.1 µF ceramic capacitors. PART NUMBER KEY ETMA120500UD - XX - IC - CXX Base Number example of 12 Vdc, 5 A DC Plug Type: See output plug options on page 3 for more details cui.com Factory Designation Reserved for Custom Configurations Additional Resources: Product Page | 3D Model CUI Inc │ SERIES: ETMA 60W UD│ DESCRIPTION: MEDICAL AC-DC POWER SUPPLY date 06/20/2017 │ page 2 of 4 INPUT parameter conditions/description min voltage frequency inrush current max units 90 typ 264 Vac 47 63 Hz 80 A 0.3 W max units at 240 Vac no load power consumption OUTPUT parameter conditions/description min line regulation 1 load regulation2 12 Vdc output 15 Vdc output all other outputs voltage accuracy hold-up time at 115 Vac switching frequency temperature coefficient Note: typ ±1 % ±5 ±3 ±2 % % % ±2 % 8 ms 100 kHz ±0.05 %/°C 1. measured from 100 ~ 240 Vac, full load 2. measured from 60% to full load and from 60 ~ 20% load (60% ±40% load) PROTECTIONS parameter conditions/description over voltage protection TVS component to clamp short circuit protection continuous, auto restart min typ min typ max units max units 5,656 Vdc SAFETY & COMPLIANCE parameter conditions/description isolation voltage input to output safety approvals medical IEC 60601-1, EN 60601-1, UL 60601-1 4th edition EMI/EMC EN 55011, EN 60601-1-2, EN 61000-3-(2,3) leakage current 0.1 MTBF as per MIL-HDBK-217F, 115 Vac, 25 °C RoHS 2011/65/EU 200,000 mA hours ENVIRONMENTAL parameter conditions/description min operating temperature storage temperature humidity non-condensing cui.com typ max units 0 40 °C -20 85 °C 93 % Additional Resources: Product Page | 3D Model CUI Inc │ SERIES: ETMA 60W UD│ DESCRIPTION: MEDICAL AC-DC POWER SUPPLY date 06/20/2017 │ page 3 of 4 ø3.5 +0/-0.1 MECHANICAL parameter conditions/description dimensions 132 x 58 x 30.5 (5.2 x 2.28 x 1.2 inch) min input plug IEC320 / C8 typ max units mm weight 345 g 14±0.5 MECHANICAL DRAWING *Tip positive units: mm 58 0.5 P1R B A C 30.5 0.5 Right Angle PXR 132 0.5 B A LED DC OUTPUT PLUG OPTIONS / DC CORD C Right Angle PXXR D ń 25±5 9±2 Standard PX cord length Ń ł Ń ł ń Right Angle PXR A B C Unit P5/P5R 5.5 2.1 9.5 mm P6/P6R 5.5 2.5 9.5 mm PXX X X Plug Type Plug Angle: “Blank” = Standard R = Right Angle act CUI for additional output plug options. Plug Polarity: “Blank” = N/A P = Center Positive N = Center Negative cui.com MODEL NO. CABLE GAUGE CORD LENGTH ETMA120500UD 16 AWG 720 mm ±50 ETMA150400UD 16 AWG 1,220 mm ±50 ETMA180333UD 16 AWG 1,500 mm ±50 ETMA240250UD 16 AWG 1,800 mm ±50 ETMA360166UD 16 AWG 1,800 mm ±50 ETMA480125UD 16 AWG 1,800 mm ±50 Additional Resources: Product Page | 3D Model CUI Inc │ SERIES: ETMA 60W UD│ DESCRIPTION: MEDICAL AC-DC POWER SUPPLY date 06/20/2017 │ page 4 of 4 REVISION HISTORY rev. description date 1.0 initial release 12/16/2011 1.01 updated P7/P7R B dimension 03/23/2012 1.02 V-Infinity branding removed 08/21/2012 1.03 updated datasheet 10/31/2012 1.04 corrected dc cord table 07/02/2013 1.05 updated datasheet 07/10/2015 1.06 updated to medical 60601-1 4th edition 06/20/2017 The revision history provided is for informational purposes only and is believed to be accurate. Headquarters 20050 SW 112th Ave. Tualatin, OR 97062 800.275.4899 Fax 503.612.2383 cui.com techsupport@cui.com This device complies with part 15 of the FCC Rules. Operation is subject to the following two conditions: (1) This device may not cause harmful interference, and (2) this device must accept any interference received, including interference that may cause undesired operation. CUI offers a one (1) year limited warranty. Complete warranty information is listed on our website. CUI reserves the right to make changes to the product at any time without notice. Information provided by CUI is believed to be accurate and reliable. However, no responsibility is assumed by CUI for its use, nor for any infringements of patents or other rights of third parties which may result from its use. CUI products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness.
ETMA360166UD-P5P-IC 价格&库存
很抱歉,暂时无法提供与“ETMA360166UD-P5P-IC”相匹配的价格&库存,您可以联系我们找货
