T5875DV
T5875DV
    RASPBERRYPI(树莓派)
    T5875DVMICROUSBPOWERSUPPLY5
T5875DV 数据手册
T5875DV Raspberry Pi Power Supply Features: •Official Raspberry Pi Power Supply • 1.5M Micro USB B Lead •ErP Level 6 Efficiency Rating •50,000 Hour MTBF •1 Years Warranty 1 Year Warranty Input Output Output Voltage +5.1Vdc Input Voltage Range 90-264VAC Minimum Load Current 0A Input Frequency 47-63Hz Nominal Load Current 2.5A Input Current 0.5A Max Nominal Output Power 13W Inrush Current No damage and IP fuse will not blow Output Regulation +/-5% AC Inlet UK, Euro, Aus & US changeable heads Line Regulation +/-2% Ripple & Noise 120mVp-p Maximum Dimensions 73.2 (L) * 45.1 (W) * 35.1 (H) mm Rise Time 100mS Maximum at nominal input Weight Approx 150g Turn-on Delay 3 Seconds Maximum at nominal input Operating Temp. 0 °C to 40 °C Protection Short circuit, over current, over voltage Storage Temp. -20 °C to +60 °C Efficiency 80.86% Opertating Humidity 20 ~ 85 % RH. Non-Condesning Output Cable 1500mm Micro USB B 5 Pin MTBF 50,000 Hours Other Diagrams Chancerygate Business Centre, Cradock Road, Reading, Berkshire, RG2 0AH. Tel: +44 (0) 118 931 1199 • Fax: +44 (0) 118 931 1145 • Email: info@stontronics.co.uk • Web: www.stontronics.co.uk Please Note: Image shown is representative of entire range. Individual PSU image &/or drawings or data sheets available on request. Stontronics Ltd accepts no responsibility for typographical errors in the production of this leaflet. Product specifications are subject to change without notice.
T5875DV
物料型号:Raspberry Pi T5875DV
器件简介:这是官方Raspberry Pi电源适配器,具有1.5米的Micro USB B线缆和ErP 6级能效等级。
引脚分配:文档中提到了PIN1和PIN5,但具体的引脚功能没有详细说明。
参数特性: - 输出电压:+5.1V直流 - 最小负载电流:0A - 额定负载电流:2.5A - 额定输出功率:13W - 输出电压调整率:±5% - 线路调整率:±2% - 纹波和噪声:最大120mV峰峰值 - 上升时间:在额定输入下最大100毫秒 - 通电延迟:在额定输入下最大3秒 - 保护:短路、过流、过压 - 效率:80.86%
功能详解:电源适配器提供稳定的5.1V直流输出,具有过流、短路和过压保护功能,符合ErP 6级能效标准。
应用信息:适用于Raspberry Pi设备。
封装信息: - 输入电压范围:90-264VAC - 输入频率:47-63Hz - 最大输入电流:0.5A - AC插座:可更换的UK、Euro、Aus和US插头 - 尺寸:73.2(L)45.1(W)35.1(H)mm - 重量:大约150克 - 工作温度:0°C至40°C - 存储温度:-20°C至+60°C - 工作湿度:20~85%RH,非凝结 - 平均无故障时间(MTBF):50,000小时
T5875DV 价格&库存
很抱歉,暂时无法提供与“T5875DV”相匹配的价格&库存,您可以联系我们找货
T5875DV
库存:54
