MENB1080A2403F01
MENB1080A2403F01
    SLPOWER
    AC/DC DESKTOP ADAPTER 24V 80W
MENB1080A2403F01 数据手册
MENB1080 Universal Input 80 Watt Series Medical Switch-Mode Power Supply 3 Year Warranty •100-240VAC Universal Input •Meets EISA2007, CEC Efficiency Level V, EU (EC) No 278/2009 Phase II •Desktop Style •12V to 24V Single Output Models, up to 80W •Modified and Custom Designs Available •Regulated Output with Low Ripple •Impact-Resistant Polycarbonate Enclosure •No Load Power Consumption 100,000 hours calculated 18 ms min. @ 115Vac, 60 ms min. @ 230 Vac Operating Temperature Storage Temperature Relative Humidity Hiccup Mode Switching – Fixed Frequency Flyback EN/IEC/CSA/UL60601-1, 3rd Edition EMC: See chart Input-Output: 2 MOOP Input-GND: 1 MOOP, Output-GND: 500Vdc 0° to 40°C, no derating -30 to +85°C 5% to 95%, non-condensing Altitude 0 to 10,000 ft Output Connections Cable: 20AWG, 1,800mm, 4 conductor Connector: Ault #3, 2.5mm barrel or #51, 6-pin Molex (12V model) Weight 500g EMI/EMC Compliance Conducted Emissions FCC Part 15, Class B, EN55011 Class B, EN55024 Radiated Emissions FCC Part 15, Class B, EN55011 Class B, EN55024 Voltage Fluctuations EN61000-3-3, Line Flicker Static Discharge Immunity EN61000-4-2, 6kV Contact Discharge, 8kV air discharge Radiated RF Immunity EN61000-4-3, 3V/m. EFT/Burst Immunity EN61000-4-4, 2kV/5kHz.. Line Surge Immunity EN61000-4-5, 1kV differential, 2kV common-mode Conducted RF Immunity EN61000-4-6, 3Vrms Power Frequency Magnetic Field Immunity EN61000-4-8, 3A/m Voltage Dip Immunity EN61000-4-11 crit. A, 100Vac 60Hz, 40%/5 cycles with 70% full load. Line Frequency Harmonics EN61000-3-2, Class A ______________________________________________________________________________________________________________________________ 1 of 2 SL Power Electronics Corp • 6050 King Drive Ventura, CA 93003 • Phone 805.486.4565 • Fax 858.712.2040 • Email: info@slpower.com • www.slpower.com MENB1080 Universal Input 80 Watt Series Medical Switch-Mode Power Supply Model Number 3 Year Warranty Volts (V) Output Current (max) Max Watts Ripple (Vp-p max) MENB1080A1251F01 12 V 6.5 A 78.0 W 120mV MENB1080A1503F01 15 V 5.2 A 78.0 W 150mV MENB1080A1803F01 18 V 4.33 A 78.0 W 180mV MENB1080A2403F01 24 V 3.25 A 78.0 W 240mV Model Number Key MENB 1 080 A VV 03 F 01 Model Input Connector: Output Connector: Output Voltage: Model Output Pow er: # of Outputs Product Fam ily: "01" = Standard. "02" and higher indicates a m odified m odel. "F" = IEC320 C14 grounded, Other options available, see below "03" = 2.5m m Barrel Type Connector, "51" = 6 pin Molex. Other options available. "05" = 5Vdc, "12" = 12Vdc, "24" = 24Vdc, etc. "A" = Original Configuration "080" = 80 Watts "1" = Single Output "M" = Medical, "E" = External, "NB" = Model Series Designator Output Connector Output Connector (12V Model) “#3” Connector is 2.5mm barrel type, center (+) “#51” Connector is Molex 39-01-2060 or equivalent. Input Receptacle IEC320 C14 - Class I Grounded (F) "51" Connector Pinout: Pins 1, 4: (+), Pins 3, 6: (-). Mate = Molex 39-01-2061 or equiv. Outline Drawing Ault #3 connector shown. Dimensions are in mm Data Sheet © 2015 SL Power Electronics Corp. The information and specifications contained herein are believed to be correct at the time of publication. Rev. 8-11-2015 However, SL Power accepts no responsibility for consequences arising from reproduction errors or inaccuracies. Specifications are subject to change without notice. ______________________________________________________________________________________________________________________________ 2 of 2 SL Power Electronics Corp • 6050 King Drive Ventura, CA 93003 • Phone 805.486.4565 • Fax 858.712.2040 • Email: info@slpower.com • www.slpower.com
MENB1080A2403F01 价格&库存
很抱歉,暂时无法提供与“MENB1080A2403F01”相匹配的价格&库存,您可以联系我们找货
