CENB1080A2403F01
CENB1080A2403F01
    SLPOWER
    AC/DCDESKTOPADAPTER24V80W
CENB1080A2403F01 数据手册
CENB1080 Universal Input 80 Watt Series ITE Switch-Mode Power Supply 3 Year Warranty •100-240VAC Universal Input •Meets EISA2007, CEC Efficiency Level V, EU (EC) No 278/2009 Phase II •Desktop Style •12V to 48V Single Output Models, up to 80W •Modified and Custom Designs Available •Regulated Output with Low Ripple •Impact-Resistant Polycarbonate Enclosure •No Load Power Consumption 100,000 hours calculated 18 ms min. @ 115Vac, 60 ms min. @ 230 Vac Operating Temperature Storage Temperature Relative Humidity Altitude Switching – Fixed Frequency Flyback EN/IEC/CSA/UL60950-1, 2nd Edition EMC: See chart Input-Output: 4,242Vdc Input-GND: 1,500 Vac, Output-GND: 500Vdc 0° to 40°C, no derating -30 to +85°C 5% to 95%, non-condensing 0 to 10,000 ft Output Connections Cable: See outline drawing Connector: Ault #3, 2.5mm barrel or #51, 6-pin Molex (12V model) Weight 500g EMI/EMC Compliance Conducted Emissions Radiated Emissions Voltage Fluctuations Static Discharge Immunity Radiated RF Immunity EFT/Burst Immunity Line Surge Immunity Conducted RF Immunity Power Frequency Magnetic Field Immunity Voltage Dip Immunity Line Frequency Harmonics FCC Part 15, Class B, EN55022 Class B, EN55024 FCC Part 15, Class B, EN55022 Class B, EN55024 EN61000-3-3, Line Flicker EN61000-4-2, 6kV Contact Discharge, 8kV air discharge EN61000-4-3, 3V/m. EN61000-4-4, 2kV/5kHz.. EN61000-4-5, 1kV differential, 2kV common-mode EN61000-4-6, 3Vrms EN61000-4-8, 3A/m EN61000-4-11 crit. A, 100Vac 60Hz, 40%/5 cycles with 70% full load. EN61000-3-2, Class A ______________________________________________________________________________________________________________________________ 1 of 2 SL Power Electronics Corp • 6050 King Drive Ventura, CA 93003 • Phone 805.486.4565 • Fax 858.712.2040 • Email: info@slpower.com • www.slpower.com CENB1080 Universal Input 80 Watt Series ITE Switch-Mode Power Supply Model Number Volts (V) Output Current (max) Max Watts Ripple (Vp-p max) CENB1080A1251F01 12 V 6.5 A 78.0 W 120mV CENB1080A1503F01 15 V 5.2 A 78.0 W 150mV CENB1080A1803F01 18 V 4.33 A 78.0 W 180mV CENB1080A2403F01 24 V 3.25 A 78.0 W 240mV CENB1080A4803F01 48 V 1.65 A 79.2 W 480mV Mode l Number Key CENB 1 080 A VV 03 F 01 M ode l Input Conne ctor: Output Conne ctor: Output V oltage : M ode l Output Pow e r: # of Outputs Product Fam ily: "01" = Standard. "02" and highe r indicate s a m odifie d m ode l. "F" = IEC320 C14 grounde d, Othe r options available , s e e ne xt page . "03" = Ault #3, 2.5m m barre l conne ctor or #51, 6-pin M ole x. Othe r options available , "12" = 12Vdc, "15" = 15Vdc, "18" = 18Vdc, "24" = 24Vdc, "48" = 48Vdc "A" = Original Configuration "080" = 80 Watts "1" = Single Output "C" = Com m e rcial/ITE/Indus trial, "E" = Exte rnal, "NB" = M ode l Se rie s De s ignator 12V Model Outline Drawing 15V-48V Model Outline Drawing Dimensions are in mm Data Sheet © 2015 SL Power Electronics Corp. The information and specifications contained herein are believed to be correct at the time of publication. Rev. 8-10-2015 However, SL Power accepts no responsibility for consequences arising from reproduction errors or inaccuracies. Specifications are subject to change without notice. ______________________________________________________________________________________________________________________________ 2 of 2 SL Power Electronics Corp • 6050 King Drive Ventura, CA 93003 • Phone 805.486.4565 • Fax 858.712.2040 • Email: info@slpower.com • www.slpower.com
CENB1080A2403F01 价格&库存
很抱歉,暂时无法提供与“CENB1080A2403F01”相匹配的价格&库存,您可以联系我们找货
