FWC080015A-12B
FWC080015A-12B
    INVENTUSPOWER
    15V 80W AC/DC External Desktop (Class I) Adapter Cord Input
FWC080015A-12B 数据手册
FWC080 Series 80 Watt ITE Desktop Power Supply High Efficiency: Level V High Power Density 4.2W/in3 Lifetime Expectation >5 years Hold­up Time >48ms at full load Power Factor Correction EISA and CEC Compliant LED Indicator Class I Overview Over the later part of 2015, we will be changing the way we sell ITE power supplies thru distribution to no longer include AC cords with the units.  During this time of transition you find both versions available for sale.  They can be distinguished by the part number, parts ending in ­10B will include a cord in the box, parts ending in ­10A will not include a cord.  If you distributor has not already made a recommendation on a cord, please do not hesitate to ask us for assistance The FWC080 series is an external, switch mode power supply that offers leading edge converter efficiencies of up to 90% at 115 VAC.  This high efficiency results in a compact size, lower internal temperature, and enhanced reliability.  The FWC080 offers a power density of 4.2 watts per cubic inch and is ideal for applications requiring high power in a lightweight package.  The FWC080 is well suited for IT, data, and telecom equipment and meets IEC 60950­1 standards. The convection cooled FWC080 series measures 7.09" x 2.27" x 1.52"  (180.2mm x 57.5mm x 38.6mm), weighs 1.52 lbs. (0.69kg), comes standard with an LED indicator, and has power factor correction. The 100 watt desktop power supply is available in models ranging from 12VDC to 48VDC.  It is comprehensively protected against over­voltage, over­temperature, and short circuit conditions, and its demonstrated mean time between failure exceeds 200,000 hours.  Designing with a FWC080 ensures a highly efficient, highly reliable power solution that reduces operating cost and ensures silent, maintenance­free operation. Elpac Part Number Output Voltage Output Current Peak FWC080012A­12A 12.0V 6.6A FWC080012A­12B 12.0V FWC080015A­12B Total Typical Regulation Efficiency3 8.0A ±5% 88% 6.6A 8.0A ±5% 88% 15.0V 5.3A 6.4A ±5% 88% FWC080015A­12A 15.0V 5.3A 6.4A ±5% 88% FWC080018A­11B 18.0V 4.4A 5.3A ±5% 88% FWC080018A­11A 18.0V 4.4A 5.3A ±5% 88% FWC080024A­11A 24.0V 3.3A 4.0A ±5% 89% FWC080024A­11B 24.0V 3.3A 4.0A ±5% 89% FWC080048A­11B 48.0V 1.7A 2.0A ±5% 90% FWC080048A­11A 48.0V 1.7A 2.0A ±5% 90% Current 1 2 Notes 1 Maximum peak load (120W) lasting 500ms with a maximum 10% duty cycle. 2 Includes initial setting, line regulation, load regulation, and thermal drift. 3 Typical at 115VAC (including output cable). Input Input Voltage 85 ­ 264VAC 100 ­ 240VAC Nominal Input Frequency 47 ­ 63Hz Input Current
FWC080015A-12B 价格&库存
很抱歉,暂时无法提供与“FWC080015A-12B”相匹配的价格&库存,您可以联系我们找货
