MENT1220A4851F01
MENT1220A4851F01
    SLPOWER
    AC/DC DESKTOP ADAPTER 48V 220W
MENT1220A4851F01 数据手册
MENT1220 Universal 220 Watt Series Medical Switch-Mode Power Supply 3Year Warranty •Universal Input 100Vac – 240Vac •12V to 48V Single Output Models up to 220W •Desktop Style/Non-vented case - No internal fan! •Ribbed Case Surface to improve cooling •Energy Star 2.0, Level V •Certified to Medical (UL/IEC/EN60601-1) and ITE (UL/IEC/EN60950-1) Standards •IPX1 Rated Enclosure •Class I and Class II input versions available. •Modified and Custom Designs Specifications All Specifications are typical at nominal input, full load at 25°C unless otherwise stated. AC Input 100-240VAC, +/-10%, 47-63 Hz single phase Input Current 115VAC: 4A max, 230VAC: 1.5A max Inrush Current Input Fuses 75A max. @ 264VAC, Cold Start Internal 6.3A Primary Current Fuses are provided PFC, Harmonics Earth Leakage Current Efficiency No Load Power Transient Response Output Voltage IEC61000-3-2
MENT1220A4851F01 价格&库存
很抱歉,暂时无法提供与“MENT1220A4851F01”相匹配的价格&库存,您可以联系我们找货
