Additional Resources:
Product Page
date
12/11/2020
page
1 of 5
SERIES: SMI6 │ DESCRIPTION: AC-DC POWER SUPPLY
FEATURES
DoE Level VI, CoC Tier 2 efficiency
up to 6 W power
interchangeable AC blades
universal input (90~264 Vac)
single regulated output from 5~15 Vdc
over voltage and short circuit protections
UL/cUL, RCM, CCC, PSE safety approvals
custom designs available
MODEL
output
voltage
output
current
output
power
ripple
and noise1
(Vdc)
max
(A)
max
(W)
max
(mVp-p)
5
1.2
6
150
VI
5.95
1
6
150
VI
9
0.67
6
150
VI
SMI6-12
12
0.5
6
200
VI
SMI6-15
15
0.4
6
200
VI
SMI6-5
SMI6-5.95
SMI6-9
Notes:
efficiency
level2
1. At full load, 100-240 Vac input, 20 MHz bandwidth oscilloscope, output terminated with 0.1 μF ceramic and 10 μF electrolytic capacitors.
2. CoC Tier 2 compliant
PART NUMBER KEY
SMI6 - XX - X - XXX - CXX
Base Number
Reserved for Custom
Configurations
Output Voltage
Blades:
V = North America, Europe, United Kingdom,
Australia, and China blade included
N = North America blade included
E = Europe blade included
B = United Kingdom blade included
A = Australia blade included
C = China blade included
K = No blades included
cui.com
DC Plug Type:
XXX = See output plug options
on page 4 for more details
ST = Stripped and Tinned
Product Page
CUI Inc │ SERIES: SMI6 │ DESCRIPTION: AC-DC POWER SUPPLY
date 12/11/2020 │ page 2 of 5
INPUT
parameter
conditions/description
min
voltage
90
frequency
47
typ
current
leakage current
no load power consumption
max
units
264
Vac
63
Hz
0.3
A
0.25
mA
0.075
W
max
units
OUTPUT
parameter
min
line regulation
load regulation
5 Vdc output model
all other models
typ
±1
±6
±5
PROTECTIONS
parameter
over voltage protection
output shut down, auto recovery
min
typ
max
units
min
typ
max
units
SAFETY & COMPLIANCE
parameter
isolation voltage
input to output at 10 mA for 1 minute
isolation resistance
input to output at 500 Vdc
safety approvals
EMI/EMC
FCC Part 15B Class B
RoHS
yes
3,000
4,242
Vac
Vdc
100
MΩ
ENVIRONMENTAL
parameter
min
operating temperature
storage temperature
max
units
typ
40
°C
-10
70
°C
operating humidity
non-condensing
storage humidity
non-condensing
10
90
cui.com
Product Page
date 12/11/2020 │ page 3 of 5
MECHANICAL
parameter
dimensions
64 x 40.5 x 30
min
typ
inlet plug
interchangeable blades (North America, Europe, UK, Australia, China)
weight
5.95 Vdc model (without interchangeable blades)
all other models (without interchangeable blades)
max
units
mm
69
68.5
g
g
MECHANICAL DRAWING
units: mm
tolerance: ±1 mm
ĵıįĶƲIJ
ķĵƲIJįı
ķijƲIJįı
ĴıƲIJįı
INTERCHANGEABLE BLADES
BLADE
DESIGNATOR
N
E
B
A
C
REGION
North
America
Europe
UK
Australia
China
BLADE
ACCESSORY
SMI-US-1
SMI-EU-1
SMI-UK-1
SMI-AU-1
SMI-CN-1
BLADE
DC CORD
units: mm
cord length
70±10
Table 1
MODEL NO.
CABLE
CORD LENGTH
SMI6-5
UL2468, 20 AWG
1,530 mm ±100
SMI6-5.95
UL2468, 20 AWG
1,530 mm ±100
SMI6-9
UL2468, 22 AWG
1,530 mm ±100
SMI6-12
UL2468, 22 AWG
1,530 mm ±100
SMI6-15
UL2468, 22 AWG
1,530 mm ±100
cui.com
Product Page
date 12/11/2020 │ page 4 of 5
OUTPUT PLUG OPTIONS
Standard DC Plug
C
Straight Plug
Size
A
B
C
Unit
5
5.5
2.1
9.5
mm
6
5.5
2.5
9.5
mm
7
3.5
1.35
9.5
mm
8
3.8
1.35
9.5
mm
9
3.8
1.05
9.5
mm
B
A
B
A
C
Right Angle Plug
Locking DC Plug
A
B
C
Size
A
B
C
Unit
10
5.5
2.1
9.5
mm
11
5.5
2.5
9.5
mm
EIAJ DC Plug
B
A
B
A
C
Size
EIAJ
A
B
C
Unit
12
EIAJ-1
2.35
0.7
9.5
mm
13
EIAJ-2
4.0
1.7
9.5
mm
14
EIAJ-3
4.75
1.7
9.5
mm
C
Straight Plug
Right Angle Plug
Stripped and Tinned
20±5
9±2
DC Plug Type
XXX
Plug Polarity:
P = Center Positive
N = Center Negative
Plug Size:
X = See above plug options
*Contact CUI for additional plug options
cui.com
Plug Angle:
“blank” = Straight
R = Right Angle
Product Page
date 12/11/2020 │ page 5 of 5
REVISION HISTORY
rev.
description
date
1.0
initial release
07/01/2015
1.01
updated datasheet
02/08/2016
1.02
updated datasheet
09/14/2016
1.03
Australia blade housing changed, and blade orientation rotated 90
degrees
10/02/2018
1.04
company logo updated
09/30/2020
1.05
safeties updated
12/11/2020
The revision history provided is for informational purposes only and is believed to be accurate.
Headquarters
20050 SW 112th Ave.
Tualatin, OR 97062
800.275.4899
Fax 503.612.2383
cui.com
techsupport@cui.com
This device complies with part 15 of the FCC Rules. Operation is subject to the following two conditions:
(1) This device may not cause harmful interference, and
(2) this device must accept any interference received, including interference that may cause undesired operation.
CUI offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI reserves the right to make changes to the product at any time without notice. Information provided by CUI is believed to be accurate and reliable. However, no responsibility is
assumed by CUI for its use, nor for any infringements of patents or other rights of third parties which may result from its use.
CUI products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical
component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to
affect its safety or effectiveness.
很抱歉,暂时无法提供与“SMI6-15-V-P5”相匹配的价格&库存,您可以联系我们找货
