Additional Resources:
Product Page
3D Model
date
04/24/2022
page
1 of 5
SERIES: SWI6-N │ DESCRIPTION: AC-DC POWER SUPPLY
FEATURES
up to 6 W continuous power
DoE Level VI efficiency
no load power consumption < 0.1 W
compact size
universal input voltage range
over voltage, over current, and short circuit protections
UL/cUL, PSE safety approvals
certified to 60950-1 and 62368-1 standards
MODEL
SWI6-3.3-N
SWI6-5-N
output
voltage
output
current
output
power
ripple
and noise1
efficiency
level
(Vdc)
max
(A)
max
(W)
max
(mVp-p)
3.3
1.5
4.95
100
VI
5
1.5
7.5
100
VI
SWI6-5.9-N
5.9
1.2
7.08
100
VI
SWI6-7.5-N
7.5
1.0
7.5
100
VI
9
0.67
6.03
100
VI
SWI6-12-N
12
0.6
7.2
120
VI
SWI6-15-N
15
0.5
7.5
150
VI
SWI6-9-N
Notes:
1. At full load, nominal input, 20 MHz bandwidth oscilloscope, output terminated with 0.1 μF multilayer ceramic and 47 μF low ESR electrolytic capacitors.
PART NUMBER KEY
SWI6 - XX - N - XXX - CXX
Reserved for Custom
Configurations
Base Number
Output Voltage
AC Input Type:
North America
cui.com
DC Plug Type:
XXX = See output plug options
on page 4 for more details
Product Page
3D Model
CUI Inc │ SERIES: SWI6-N │ DESCRIPTION: AC-DC POWER SUPPLY
date 04/24/2022 │ page 2 of 5
INPUT
parameter
conditions/description
min
voltage
90
frequency
47
typ
current
inrush current
at 240 Vac, full load, 25°C, cold start
leakage current
at 115/230 Vac
max
units
264
Vac
63
Hz
0.19
A
60
A
0.25
mA
0.1
W
max
units
OUTPUT
parameter
regulation
3.3 Vdc output model
all other models
hold-up time
at full load
min
typ
±10
±5
10
ms
PROTECTIONS
parameter
max
units
over voltage protection
output shut down
min
typ
180
over current protection
output shut down, auto recovery
5 Vdc output model
5.9 Vdc output model
7.5 Vdc output model
9 Vdc output model
12 Vdc output model
15 Vdc output model
3.5
3.5
3
2.5
1.5
1.5
1.3
A
A
A
A
A
A
A
max
units
SAFETY & COMPLIANCE
parameter
min
isolation voltage
input to output at 10 mA for 1 minute
isolation resistance
input to output at 500 Vdc
safety approvals
UL/cUL (60950-1, 62368-1), PSE
EMI/EMC
FCC Part 15B Class B
MTBF
as per Telcordia SR-332, 25°C
RoHS
yes
typ
3,000
Vac
10
MΩ
300,000
hours
ENVIRONMENTAL
parameter
min
operating temperature
storage temperature
max
units
typ
40
°C
-20
60
°C
operating humidity
non-condensing
storage humidity
non-condensing
10
90
cui.com
Product Page
3D Model
date 04/24/2022 │ page 3 of 5
MECHANICAL
parameter
dimensions
56 x 28 x 42
inlet plug
North America, 2-pin
min
typ
78
MECHANICAL DRAWING
units: mm
tolerance: ±1.0 mm
DC CORD
cord length
80±5
units
mm
weight
units: mm
max
Table 1
MODEL NO.
CABLE
CORD LENGTH
SWI6-3.3-N
UL2468, 20 AWG
1,500 mm ±30
SWI6-5-N
UL2468, 20 AWG
1,500 mm ±30
SWI6-5.9-N
UL2468, 20 AWG
1,500 mm ±30
SWI6-7.5-N
UL2468, 22 AWG
1,500 mm ±30
SWI6-9-N
UL2468, 22 AWG
1,500 mm ±30
SWI6-12-N
UL2468, 22 AWG
1,500 mm ±30
SWI6-15-N
UL2468, 22 AWG
1,500 mm ±30
cui.com
g
Product Page
3D Model
date 04/24/2022 │ page 4 of 5
DC PLUG TYPE PART NUMBER KEY
XXX
Plug Polarity:
P = Center Positive
Plug Code:
X = Choose a code from the
options below
Plug Angle:
“blank” = Straight
R = Right Angle
N = Center Negative
Plug Polarity
Code
Center Pos.
Center Neg.
Option
N/A
N/A
Dimensions (mm)
Type
A
B
P1
Audio
3.5
5
Standard
5.5
6
Standard
7
Standard
8
9
Plug Angle
C
Straight
Right
N/A
14
N/A
2.1
9.5
5.5
2.5
9.5
3.5
1.35
9.5
Standard
3.8
1.35
9.5
Standard
3.8
1.05
9.5
10
2
Locking
5.5
2.1
9.5
N/A
11
Locking2
5.5
2.5
9.5
N/A
12
EIAJ-1
2.35
0.7
9.5
13
EIAJ-2
4.0
1.7
9.5
14
EIAJ-3
4.75
1.7
9.5
N/A
N/A
ST
N/A
N/A
N/A
N/A
MUB
USB
Micro USB Type B
N/A
N/A
N/A
CUB
USB
USB Type C
N/A
1
Stripped and Tinned
Note: 1. Tip positive
2. Maximum insertion depth is 10mm
3. Contact CUI for additional plug options
cui.com
Product Page
3D Model
date 04/24/2022 │ page 5 of 5
REVISION HISTORY
rev.
description
date
1.0
initial release
08/07/2015
1.01
added models
08/12/2015
1.02
updated drawing
11/10/2015
1.03
added micro USB Type B plug option
06/30/2016
1.04
added audio plug option
11/07/2016
1.05
added 62368-1 standard
08/31/2018
1.06
company logo updated
09/21/2020
1.07
updated dc plug options
11/19/2020
1.08
safety marks updated
04/22/2021
1.09
plug polarity symbols updated
09/16/2021
dc plugs updated
04/24/2022
1.10
The revision history provided is for informational purposes only and is believed to be accurate.
Headquarters
20050 SW 112th Ave.
Tualatin, OR 97062
800.275.4899
Fax 503.612.2383
cui.com
techsupport@cui.com
This device complies with part 15 of the FCC Rules. Operation is subject to the following two conditions:
(1) This device may not cause harmful interference, and
(2) this device must accept any interference received, including interference that may cause undesired operation.
CUI offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI reserves the right to make changes to the product at any time without notice. Information provided by CUI is believed to be accurate and reliable. However, no responsibility is
assumed by CUI for its use, nor for any infringements of patents or other rights of third parties which may result from its use.
CUI products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a
life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness.
很抱歉,暂时无法提供与“SWI6-15-N-P6R”相匹配的价格&库存,您可以联系我们找货
