Additional Resources:
Product Page
3D Model
date
04/29/2022
page
1 of 5
SERIES: SWI18-E │ DESCRIPTION: AC-DC POWER SUPPLY
FEATURES
up to 18 W continuous power
DoE Level VI, CoC Tier 2 efficiency
no load power consumption < 0.075 W
compact size
universal input voltage range
over voltage, over current, and short circuit protections
CE safety approvals
EN 62368 certified
MODEL
input
voltage
input
frequency
output
voltage
output
current
output
power
ripple
and
noise1
range
(Vac)
range
(Hz)
nom
(Vdc)
max
(A)
max
(W)
max
(mVp-p)
average3
10%
typ
(W)
SWI18-5-E
90 ~ 264
47 ~ 63
5
3.0
15.0
100
82.2
79.0
0.07
SWI18-9-E
90 ~ 264
47 ~ 63
9
2.2
19.8
100
86.5
80.7
0.07
SWI18-12-E
90 ~ 264
47 ~ 63
12
1.6
19.2
120
85.8
80.5
0.06
SWI18-24-E
90 ~ 264
47 ~ 63
24
0.8
19.2
240
87.9
82.0
0.07
Notes:
efficiency
level2
no load power
consumption
1. At full load, nominal AC input voltage, 25°C, 20 MHz bandwidth oscilloscope, output terminated with 0.1 µF and 10 µF capacitors to ground.
2. CoC Tier 2 compliant.
3. Average efficiency is measured at 25%, 50%, 75%, and 100% load.
PART NUMBER KEY
SWI18 - XX - E - XXX - CXX
Reserved for Custom
Configurations
Base Number
Output Voltage
AC Input Type:
Europe
cui.com
DC Plug Type:
XXX = See output plug options
on page 4 for more details
ST = Stripped and Tinned
Product Page
3D Model
CUI Inc │ SERIES: SWI18-E │ DESCRIPTION: AC-DC POWER SUPPLY
date 04/29/2022 │ page 2 of 5
INPUT
parameter
conditions/description
min
voltage
90
frequency
47
typ
current
inrush current
at 100 Vac, full load, 25°C, cold start
at 230 Vac, full load, 25°C, cold start
leakage current
at 230 Vac
Level VI
CoC Tier 2
max
units
264
Vac
63
Hz
0.48
A
50
60
A
A
0.25
mA
0.1
0.075
W
W
max
units
OUTPUT
parameter
regulation
5 Vdc output model
all other models
hold-up time
at full load
min
typ
±6
±5
10
ms
PROTECTIONS
parameter
max
units
over voltage protection
output shut down
5 Vdc output model
9 Vdc output model
12 Vdc output model
24 Vdc output model
min
typ
12
16
22
45
Vdc
Vdc
Vdc
Vdc
over current protection
output shut down, auto recovery
5 Vdc output model
9 Vdc output model
12 Vdc output model
24 Vdc output model
7
5
5
2.5
A
A
A
A
max
units
SAFETY & COMPLIANCE
parameter
isolation voltage
input to output at 10 mA for 1 minute
min
isolation resistance
input to output at 500 Vdc
safety approvals
certified to
EMI/EMC
CE
MTBF
as per Telcordia SR-332, 25°C
RoHS
2011/65/EU
typ
3,000
Vac
10
MΩ
300,000
hours
62368: EN
ENVIRONMENTAL
parameter
min
operating temperature
storage temperature
typ
max
units
°C
-20
80
°C
operating humidity
non-condensing
storage humidity
non-condensing
10
90
cui.com
Product Page
3D Model
date 04/29/2022 │ page 3 of 5
MECHANICAL
parameter
dimensions
72 x 34 x 88.5
inlet plug
Europe
min
typ
max
units
mm
weight
170
MECHANICAL DRAWING
units: mm
DC CORD
units: mm
Table 1
MODEL NO.
CABLE
CORD LENGTH
SWI18-5-E
UL2468, 16 AWG
1,500 mm ±30
SWI18-9-E
UL2468, 18 AWG
1,500 mm ±30
SWI18-12-E
UL2468, 20 AWG
1,500 mm ±30
SWI18-24-E
UL2468, 22 AWG
1,500 mm ±30
cui.com
g
Product Page
3D Model
date 04/29/2022 │ page 4 of 5
OUTPUT PLUG OPTIONS
Standard DC Plug
C
Straight Plug
Size
A
B
C
Unit
5
5.5
2.1
9.5
mm
6
5.5
2.5
9.5
mm
7
3.5
1.35
9.5
mm
8
3.8
1.35
9.5
mm
9
3.8
1.05
9.5
mm
B
A
B
A
C
Right Angle Plug
Locking DC Plug
C
A
B
2.5±0.3
A
B
C
Unit
10
5.5
2.1
9.5
mm
11
5.5
2.5
9.5
mm
Note: Maximum insertion depth is 10mm
EIAJ DC Plug
Size
EIAJ
A
B
C
Unit
12
EIAJ-1
2.35
0.7
9.5
mm
13
EIAJ-2
4.0
1.7
9.5
mm
14
EIAJ-3
4.75
1.7
9.5
mm
B
B
A
C
A
Size
C
Straight Plug
Right Angle Plug
Stripped and Tinned
25±5
5±5
10±2
DC Plug Type
XXX
Plug Polarity:
P = Center Positive
N = Center Negative
Plug Size:
X = See above plug options
*Contact CUI for additional plug options
cui.com
Plug Angle:
“blank” = Straight
R = Right Angle
Product Page
3D Model
date 04/29/2022│ page 5 of 5
REVISION HISTORY
rev.
description
date
1.0
initial release
08/07/2015
1.01
updated datasheet
05/18/2016
1.02
changed wire gauge on 5 Vdc models, updated datasheet
09/15/2016
1.03
drawing update
07/13/2020
1.04
62368 added to safety approvals
09/09/2020
1.05
model table updated
11/27/2020
1.06
plug polarity symbols updated
09/16/2021
dc plugs updated
04/29/2022
1.07
The revision history provided is for informational purposes only and is believed to be accurate.
Headquarters
20050 SW 112th Ave.
Tualatin, OR 97062
800.275.4899
Fax 503.612.2383
cui.com
techsupport@cui.com
This device complies with part 15 of the FCC Rules. Operation is subject to the following two conditions:
(1) This device may not cause harmful interference, and
(2) this device must accept any interference received, including interference that may cause undesired operation.
CUI offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI reserves the right to make changes to the product at any time without notice. Information provided by CUI is believed to be accurate and reliable. However, no responsibility is
assumed by CUI for its use, nor for any infringements of patents or other rights of third parties which may result from its use.
CUI products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a
life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness.
很抱歉,暂时无法提供与“SWI18-24-E-P5”相匹配的价格&库存,您可以联系我们找货
