ME10A2403N01
ME10A2403N01
    SLPOWER
    AC/DCDESKTOPADAPTER24V10W
ME10A2403N01 数据手册
ME10 Family 10W-12W Single Output External Power Medical Grade FEATURES AND BENEFITS Meets EN55011/CISPR11, FCC Part 15.109 Class B Conducted & Radiated Emissions, with 6db Margin Meets UL/EN/IEC60601-1-2, 4th Edition for EMC* Medical Approved to EN/IEC/UL60601-1, 3rd Edition Applications with Isolation Levels which Satisfy the 2 MOPP Requirements E-Cap Life of >7 Years >10,00,000 Hours MTBF Meets DoE Efficiency Level VI Requirements No Load Input Power Average Efficiency Up to 12W of AC-DC Power LPS IP22 Rated Enclosure 3 Years Warranty Note: * Consult Factory for Table 9 compliance information. * IP22 does not include interchangeable blade versions. Universal Input 90 - 264VAC Input Range Desktop and Wall-plug Versions MODEL SELECTION Model Number Volts Output Current Output Power Ripple & Noise1 Line Regulation Load Regulation ME10A0503F01 5.0V 2.0A 10W 75mV pk-pk ±1% ±5% ME10A0603F01 5.9V 1.6A 10W 75mV pk-pk ±1% ±5% ME10A0703F01 7.5V 1.3A 10W 75mV pk-pk ±1% ±5% ME10A0903F01 9.0V 1.1A 10W 90mV pk-pk ±1% ±5% ME10A1203F01 12.0V 1.0A 12W 120mV pk-pk ±1% ±5% ME10A1503F01 15.0V 0.8A 12W 150mV pk-pk ±1% ±5% ME10A2403F01 24.0V 0.5A 12W 240mV pk-pk ±1% ±5% ME10A0503N01 5.0V 2.0A 10W 75mV pk-pk ±1% ±5% ME10A0603N01 5.9V 1.6A 10W 75mV pk-pk ±1% ±5% ME10A0703N01 7.5V 1.3A 10W 75mV pk-pk ±1% ±5% ME10A0903N01 9.0V 1.1A 10W 90mV pk-pk ±1% ±5% ME10A1203N01 12.0V 1.0A 12W 120mV pk-pk ±1% ±5% ME10A1503N01 15.0V 0.8A 12W 150mV pk-pk ±1% ±5% ME10A2403N01 24.0V 0.5A 12W 240mV pk-pk ±1% ±5% ME10A0503Q01 5.0V 2.0A 10W 75mV pk-pk ±1% ±5% ME10A0603Q01 5.9V 1.6A 10W 75mV pk-pk ±1% ±5% ME10A0703Q01 7.5V 1.3A 10W 75mV pk-pk ±1% ±5% ME10A0903Q01 9.0V 1.1A 10W 90mV pk-pk ±1% ±5% ME10A1203Q01 12.0V 1.0A 12W 120mV pk-pk ±1% ±5% ME10A1503Q01 15.0V 0.8A 12W 150mV pk-pk ±1% ±5% ME10A2403Q01 24.0V 0.5A 12W 240mV pk-pk ±1% ±5% ME10 Datasheet v1121 Copyright © 2021 SL Power Electronics Corp. All rights reserved. Output Connector Input Configuration 2.5 x 5.5 x 9.5mm Straight barrel type, Center positive Class I Desktop, IEC60320 C14 receptacle 2.5 x 5.5 x 9.5mm Straight barrel type, Center positive Class II Desktop, IEC60320 C8 receptacle 2.5 x 5.5 x 9.5mm Straight barrel type, Center positive Class II Desktop, IEC60320 C18 receptacle Page 1 ME10 Family 10W-12W Single Output External Power Medical Grade MODEL SELECTION Model Number Volts Output Current Output Power Ripple & Noise1 Line Regulation Load Regulation ME10A0503B01 5.0V 2.0A 10W 75mV pk-pk ±1% ±5% ME10A0603B01 5.9V 1.6A 10W 75mV pk-pk ±1% ±5% ME10A0703B01 7.5V 1.3A 10W 75mV pk-pk ±1% ±5% ME10A0903B01 9.0V 1.1A 10W 90mV pk-pk ±1% ±5% ME10A1203B01 12.0V 1.0A 12W 120mV pk-pk ±1% ±5% ME10A1503B01 15.0V 0.8A 12W 150mV pk-pk ±1% ±5% ME10A2403B01 24.0V 0.5A 12W 240mV pk-pk ±1% ±5% ME10A0503C01 5.0V 2.0A 10W 75mV pk-pk ±1% ±5% ME10A0603C01 5.9V 1.6A 10W 75mV pk-pk ±1% ±5% ME10A0703C01 7.5V 1.3A 10W 75mV pk-pk ±1% ±5% ME10A0903C01 9.0V 1.1A 10W 90mV pk-pk ±1% ±5% ME10A1203C01 12.0V 1.0A 12W 120mV pk-pk ±1% ±5% ME10A1503C01 15.0V 0.8A 12W 150mV pk-pk ±1% ±5% ME10A2403C01 24.0V 0.5A 12W 240mV pk-pk ±1% ±5% Output Connector Input Configuration 2.5 x 5.5 x 9.5mm Straight barrel type, Center positive Class II Wall-plug, Interchangeable blades (North American blade included)² 2.5 x 5.5 x 9.5mm Straight barrel type, Center positive Class II Wall-plug, Fixed North American blades³ Note: 1. Measured at the output connector, with noise probe directly across output and load terminated with 0.1μF ceramic and 10μF low ESR capacitors. For 5V and 6V models, values listed are typical, 100mV pk-pk maximum with 0.1μF ceramic and 47μF low ESR capacitors used at measurement point. 2. Order blade kit KT-1027K for other blades (EU. UK, Australia). 3. For EU fixed blades, replace “C” in the model number with “M”, for UK blades, replace “C” with “G”, for Australia blades, replace “C” with “H”. 4. For Input Class I models: For AC GND connected to output common (-), insert a “B” in the part number where the “A” is located (ME10B0503F01). 5. All specifications are typical at nominal input, full load, at 25°C ambient unless noted. INPUT OUTPUT AC Input 100-240VAC, ±10%, 47-63Hz, 1Ø Hold-Up Time 20ms min at full load, 100VAC input Input Current 115VAC: 0.45A, 230VAC: 0.22A Turn On Time Less than 700ms @ 115VAC, Full load Inrush Current 264VAC, cold start: will not exceed 40A Input Fuses F1, F2: 3.15A, 250Vac fuses (line & neutral lines) provided on all models Patient Leakage Current (Output to Earth)
ME10A2403N01 价格&库存
很抱歉,暂时无法提供与“ME10A2403N01”相匹配的价格&库存,您可以联系我们找货
