SDI12-12-UDC-P6
SDI12-12-UDC-P6
    CUIDEVICES
    AC/DCDESKTOPADAPTER12V12W
SDI12-12-UDC-P6 数据手册
Additional Resources: Product Page | 3D Model date 09/16/2021 page 1 of 6 SERIES: SDI12-UD │ DESCRIPTION: AC-DC POWER SUPPLY FEATURES • • • • • • • • up to 12 W continuous power DoE Level VI, CoC Tier 2 efficiency no load power consumption < 0.075 W compact size universal input voltage range over voltage, over current, and short circuit protections UL/cUL, CE safety approvals IEC 62368 MODEL output voltage output current output power ripple and noise1 (Vdc) max (A) max (W) max (mVp-p) 5 2 10 100 VI 5.9 2 11.8 100 VI 9 1.33 12 100 VI SDI12-5-UD SDI12-5.9-UD SDI12-9-UD efficiency level2 SDI12-12-UD 12 1 12 120 VI SDI12-15-UD 15 0.8 12 150 VI SDI12-18-UD 18 0.67 12 180 VI SDI12-24-UD 24 0.5 12 240 VI Notes: 1. At full load, nominal input, 20 MHz bandwidth oscilloscope, each output terminated with 0.1 μF multilayer ceramic and 47 μF low ESR electrolytic capacitors. 2. CoC Tier 2 compliant PART NUMBER KEY SDI12 - XX - UD X - XXX - CXX Base Number Output Voltage AC Inlet Type: IEC320/C8 Input Cable: “Blank” = No Cable C = North America input cable 2 = Europe input cable 3 = United Kingdom input cable 4 = Australia input cable 5 = China input cable 6 = South Korea input cable 7 = Brazil input cable 8 = South Africa input cable 9 = Japan input cable cui.com Reserved for Custom Configurations DC Plug Type: XXX = See output plug options on page 5 for more details ST = Stripped and Tinned Additional Resources: Product Page | 3D Model CUI Inc │ SERIES: SDI12-UD │ DESCRIPTION: AC-DC POWER SUPPLY date 09/16/2021 │ page 2 of 6 INPUT parameter conditions/description min voltage typ 90 frequency 47 current at full load inrush current at 240 Vac, full load, 25°C, cold start leakage current no load power consumption at 115/230 Vac Level VI CoC Tier 2 max units 264 Vac 63 Hz 0.31 A 60 A 0.25 mA 0.1 0.075 W W max units OUTPUT parameter conditions/description min regulation hold-up time typ ±5 at full load % 10 ms PROTECTIONS parameter conditions/description min over voltage protection output shut down 5 Vdc output model 5.9 Vdc output model 9 Vdc output model 12 Vdc output model 15 Vdc output model 18 Vdc output model 24 Vdc output model over current protection output shut down, auto recovery 5 Vdc output model 5.9 Vdc output model 9 Vdc output model 12 Vdc output model 15 Vdc output model 18 Vdc output model 24 Vdc output model short circuit protection output shut down, auto recovery typ max units 9 10.6 16.2 21.6 27 32.4 45 Vdc Vdc Vdc Vdc Vdc Vdc Vdc 5 5 3 2.5 2 2 1.5 A A A A A A A max units SAFETY & COMPLIANCE parameter conditions/description isolation voltage input to output at 10 mA for 1 minute min isolation resistance input to output at 500 Vdc safety approvals 62368: UL/cUL, EN LPS, UKCA EMI/EMC FCC Part 15B Class B, CE MTBF as per Telcordia SR-332, 25°C RoHS 2011/65/EU typ 3,000 Vac 10 MΩ 300,000 hours ENVIRONMENTAL parameter conditions/description min operating temperature storage temperature typ max units 0 40 °C -20 80 °C operating humidity non-condensing 20 80 % storage humidity non-condensing 10 90 % cui.com Additional Resources: Product Page | 3D Model CUI Inc │ SERIES: SDI12-UD │ DESCRIPTION: AC-DC POWER SUPPLY date 09/16/2021 │ page 3 of 6 MECHANICAL parameter conditions/description dimensions 75 x 48 x 30 inlet plug IEC320/C8 weight without ac cord min max units mm 126 MECHANICAL DRAWING units: mm tolerance: ±0.5 mm DC CORD units: mm typ cord length Table 1 MODEL NO. CABLE CORD LENGTH SDI12-5-UD UL2468, 20 AWG 1,500 mm ±30 SDI12-5.9-UD UL2468, 20 AWG 1,500 mm ±30 SDI12-9-UD UL2468, 20 AWG 1,500 mm ±30 SDI12-12-UD UL2468, 22 AWG 1,500 mm ±30 SDI12-15-UD UL2468, 22 AWG 1,500 mm ±30 SDI12-18-UD UL2468, 22 AWG 1,500 mm ±30 SDI12-24-UD UL2468, 22 AWG 1,500 mm ±30 cui.com g Additional Resources: Product Page | 3D Model CUI Inc │ SERIES: SDI12-UD │ DESCRIPTION: AC-DC POWER SUPPLY date 09/16/2021 │ page 4 of 6 AC CORD units: mm cord length NORTH AMERICA EUROPE UNITED KINGDOM AUSTRALIA CHINA SOUTH KOREA BRAZIL SOUTH AFRICA JAPAN Table 2 AC INPUT CORD LENGTH North America 1,830 mm ±50 Europe 1,830 mm ±50 United Kingdom 1,830 mm ±30 Australia 1,830 mm ±30 China 1,830 mm ±30 South Korea 1,830 mm ±50 Brazil 1,830 mm ±30 South Africa 1,830 mm ±50 Japan 1,830 mm ±50 cui.com Additional Resources: Product Page | 3D Model CUI Inc │ SERIES: SDI12-UD │ DESCRIPTION: AC-DC POWER SUPPLY date 09/16/2021 │ page 5 of 6 OUTPUT PLUG OPTIONS Standard DC Plug C Straight Plug Size A B C Unit 5 5.5 2.1 9.5 mm 6 5.5 2.5 9.5 mm 7 3.5 1.35 9.5 mm 8 3.8 1.35 9.5 mm 9 3.8 1.05 9.5 mm B A B A C Right Angle Plug Locking DC Plug A B C Size A B C Unit 10 5.5 2.1 9.5 mm 11 5.5 2.5 9.5 mm EIAJ DC Plug Size EIAJ A B C Unit 12 EIAJ-1 2.35 0.7 9.5 mm 13 EIAJ-2 4.0 1.7 9.5 mm 14 EIAJ-3 4.75 1.7 9.5 mm B A B A C C Straight Plug Right Angle Plug Stripped and Tinned 25±5 5±5 10±2 DC Plug Type XXX Plug Polarity: P = Center Positive N = Center Negative Plug Size: X = See above plug options *Contact CUI for additional plug options cui.com Plug Angle: “blank” = Straight R = Right Angle Additional Resources: Product Page | 3D Model CUI Inc │ SERIES: SDI12-UD │ DESCRIPTION: AC-DC POWER SUPPLY date 09/16/2021 │ page 6 of 6 REVISION HISTORY rev. description date 1.0 initial release 08/21/2015 1.01 updated datasheet 05/18/2016 1.02 updated datasheet 09/15/2016 1.03 removed GS mark as of 5/31/2019 04/10/2019 1.04 company logo updated 06/24/2020 1.05 PSE removed, 62368 added to safety line 07/16/2021 1.06 UKCA added to specification 09/09/2021 plug polarity symbols updated 09/16/2021 1.07 The revision history provided is for informational purposes only and is believed to be accurate. Headquarters 20050 SW 112th Ave. Tualatin, OR 97062 800.275.4899 Fax 503.612.2383 cui.com techsupport@cui.com This device complies with part 15 of the FCC Rules. Operation is subject to the following two conditions: (1) This device may not cause harmful interference, and (2) this device must accept any interference received, including interference that may cause undesired operation. CUI offers a one (1) year limited warranty. Complete warranty information is listed on our website. CUI reserves the right to make changes to the product at any time without notice. Information provided by CUI is believed to be accurate and reliable. However, no responsibility is assumed by CUI for its use, nor for any infringements of patents or other rights of third parties which may result from its use. CUI products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness.
SDI12-12-UDC-P6 价格&库存
很抱歉,暂时无法提供与“SDI12-12-UDC-P6”相匹配的价格&库存,您可以联系我们找货
