SDI18-24-UDC-P6
SDI18-24-UDC-P6
    CUIDEVICES
    AC/DCDESKTOPADAPTER24V18W
SDI18-24-UDC-P6 数据手册
Additional Resources: Product Page | 3D Model date 05/23/2022 page 1 of 6 SERIES: SDI18-UD │ DESCRIPTION: AC-DC POWER SUPPLY FEATURES • • • • • • • • up to 18 W continuous power DoE Level VI, CoC Tier 2 efficiency no load power consumption < 0.075 W compact size universal input voltage range over voltage, over current, and short circuit protections UL/cUL, CE, PSE safety approvals certified to 62368-1 standards MODEL output voltage output current output power ripple and noise1 (Vdc) max (A) max (W) max (mVp-p) 5 3 15 100 VI 5.9 3 17.7 100 VI 9 2.2 19.8 100 VI SDI18-12-UD 12 1.6 19.2 120 VI SDI18-15-UD 15 1.3 19.5 150 VI SDI18-24-UD 24 0.8 19.2 240 VI SDI18-5-UD SDI18-5.9-UD SDI18-9-UD Notes: efficiency level2 1. At full load, nominal input, 20 MHz bandwidth oscilloscope, each output terminated with 0.1 μF multilayer ceramic and 10 μF low ESR electrolytic capacitors. 2. CoC Tier 2 compliant PART NUMBER KEY SDI18 - XX - UDX - XXX - CXX Base Number AC Inlet Type: IEC320/C8 Reserved for Custom Configurations Output Voltage Input Cable: “Blank” = No Cable C = North America input cable 2 = Europe input cable 3 = United Kingdom input cable 4 = Australia input cable 5 = China input cable 6 = South Korea input cable 7 = Brazil input cable 8 = South Africa input cable 9 = Japan input cable cui.com DC Plug Type: XXX = See output plug options on page 5 for more details Additional Resources: Product Page | 3D Model CUI Inc │ SERIES: SDI18-UD │ DESCRIPTION: AC-DC POWER SUPPLY date 05/23/2022 │ page 2 of 6 INPUT parameter conditions/description min voltage typ 90 frequency 47 current at full load inrush current at 100 Vac, full load, 25°C, cold start at 230 Vac, full load, 25°C, cold start leakage current no load power consumption at 230 Vac max units 264 Vac 63 Hz 0.48 A 50 60 A A 0.25 mA 0.075 W max units OUTPUT parameter conditions/description regulation 5 Vdc output model all other models hold-up time at full load min typ ±6 ±5 % % 10 ms PROTECTIONS parameter conditions/description min typ max units over voltage protection output shut down 5 Vdc output model 5.9 Vdc output model 9 Vdc output model 12 Vdc output model 15 Vdc output model 24 Vdc output model 12 12 16 22 32 45 Vdc Vdc Vdc Vdc Vdc Vdc over current protection output shut down, auto recovery 5 Vdc output model 5.9 Vdc output model 9 Vdc output model 12 Vdc output model 15 Vdc output model 24 Vdc output model 7 6 5 5 4 2.5 A A A A A A short circuit protection output shut down, auto recovery max units SAFETY & COMPLIANCE parameter conditions/description isolation voltage input to output at 10 mA for 1 minute min isolation resistance input to output at 500 Vdc safety approvals UL/cUL (62368-1), PSE, UKCA EMI/EMC FCC Part 15B Class B, CE MTBF as per Telcordia SR-332, 25°C RoHS yes typ 3,000 Vac 10 MΩ 300,000 hours ENVIRONMENTAL parameter conditions/description min operating temperature storage temperature typ max units 0 40 °C -20 80 °C operating humidity non-condensing 20 80 % storage humidity non-condensing 10 90 % cui.com Additional Resources: Product Page | 3D Model CUI Inc │ SERIES: SDI18-UD │ DESCRIPTION: AC-DC POWER SUPPLY date 05/23/2022 │ page 3 of 6 MECHANICAL parameter conditions/description dimensions 88.5 x 50 x 34 inlet plug IEC320/C8 weight without ac cord min typ max units mm 170 MECHANICAL DRAWING units: mm tolerance: ±1.0 mm DC CORD units: mm Table 1 MODEL NO. CABLE CORD LENGTH SDI18-5-UD UL2468, 16 AWG 1,500 mm ±30 SDI18-5.9-UD UL2468, 16 AWG 1,200 mm ±30 SDI18-9-UD UL2468, 18 AWG 1,500 mm ±30 SDI18-12-UD UL2468, 20 AWG 1,500 mm ±30 SDI18-15-UD UL2468, 22 AWG 1,500 mm ±30 SDI18-24-UD UL2468, 22 AWG 1,500 mm ±30 cui.com g Additional Resources: Product Page | 3D Model CUI Inc │ SERIES: SDI18-UD │ DESCRIPTION: AC-DC POWER SUPPLY date 05/23/2022 │ page 4 of 6 AC CORD units: mm cord length NORTH AMERICA EUROPE UNITED KINGDOM AUSTRALIA CHINA SOUTH KOREA BRAZIL SOUTH AFRICA JAPAN Table 2 AC INPUT CORD LENGTH North America 1,830 mm ±50 Europe 1,830 mm ±50 United Kingdom 1,830 mm ±30 Australia 1,830 mm ±30 China 1,830 mm ±30 South Korea 1,830 mm ±50 Brazil 1,830 mm ±30 South Africa 1,830 mm ±50 Japan 1,830 mm ±50 cui.com Additional Resources: Product Page | 3D Model CUI Inc │ SERIES: SDI18-UD │ DESCRIPTION: AC-DC POWER SUPPLY date 05/23/2022 │ page 5 of 6 DC PLUG TYPE PART NUMBER KEY XXX Plug Polarity: P = Center Positive Plug Code: X = Choose a code from the options below Plug Angle: “blank” = Straight R = Right Angle N = Center Negative Plug Polarity Code Dimensions (mm) Plug Angle Center Pos. Center Neg. Option Type A B C Straight Right ● ● 5 Standard 5.5 2.1 9.5 ● ● ● ● 6 Standard 5.5 2.5 9.5 ● ● ● ● 7 Standard 3.5 1.35 9.5 ● ● ● ● 8 Standard 3.8 1.35 9.5 ● ● ● ● 9 Standard 3.8 1.05 9.5 ● ● ● ● 10 Locking2 5.5 2.1 9.5 ● N/A ● ● 11 Locking2 5.5 2.5 9.5 ● N/A ● ● 12 EIAJ-1 2.35 0.7 9.5 ● ● ● ● 13 EIAJ-2 4.0 1.7 9.5 ● ● ● ● 14 EIAJ-3 4.75 1.7 9.5 ● ● N/A N/A ST N/A N/A Stripped & Tinned Note: 1. Contact CUI for additional plug options 2. Maximum insertion depth is 10mm EIAJ Straight C C Straight Locking Right Angle (R) Stripped & Tinned 25±5 2.5±0.3 5±5 A B C A A Right Angle (R) C B B A A B C B Standard cui.com 10±2 Additional Resources: Product Page | 3D Model CUI Inc │ SERIES: SDI18-UD │ DESCRIPTION: AC-DC POWER SUPPLY date 05/23/2022 │ page 6 of 6 REVISION HISTORY rev. description date 1.0 initial release 08/07/2015 1.01 updated datasheet 03/16/2016 1.02 changed wire gauge on 5 Vdc & 5.9 Vdc models, updated datasheet 09/16/2016 1.03 added 62368-1 standard 08/31/2018 1.04 company logo update 06/24/2020 1.05 safeties updated 12/11/2020 1.06 UKCA added to specification 08/12/2021 1.07 plug polarity symbols updated 09/16/2021 1.08 dc plugs updated 05/23/2022 The revision history provided is for informational purposes only and is believed to be accurate. Headquarters 20050 SW 112th Ave. Tualatin, OR 97062 800.275.4899 Fax 503.612.2383 cui.com techsupport@cui.com This device complies with part 15 of the FCC Rules. Operation is subject to the following two conditions: (1) This device may not cause harmful interference, and (2) this device must accept any interference received, including interference that may cause undesired operation. CUI offers a one (1) year limited warranty. Complete warranty information is listed on our website. CUI reserves the right to make changes to the product at any time without notice. Information provided by CUI is believed to be accurate and reliable. However, no responsibility is assumed by CUI for its use, nor for any infringements of patents or other rights of third parties which may result from its use. CUI products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness.
SDI18-24-UDC-P6 价格&库存
很抱歉,暂时无法提供与“SDI18-24-UDC-P6”相匹配的价格&库存,您可以联系我们找货
