ME30A4803N01
ME30A4803N01
    SLPOWER
    AC/DCDESKTOPADAPTER48V30W
ME30A4803N01 数据手册
ME30 Family 20W-30W Single Output External Power Medical Grade FEATURES AND BENEFITS Medical Meets EN55011/CISPR11, FCC Part 15.109 Class B Conducted & Radiated Emissions, with >6db margin Meets UL/EN/IEC60601-1-2, 4th edition for EMC* Approved to EN/IEC/UL60601-1, 3rd edition E-cap life of >8 years 2 MOPP input-output isolation >1,000,000 hours MTBF Meets DoE Efficiency Level VI Requirements No load input power Average Efficiency IP22 Rated Enclosure 3 Year Warranty Up to 30W of AC-DC Power * IP22 does not include interchangeable blade versions. * Consult Factory for Table 9 compliance information. Universal Input 90-264Vac Input Range Desktop and Wall-Plug versions MODEL SELECTION Model Number Volts Output Current Output Power Ripple & Noise1 Line Regulation ME30A0503F01 5.0V 4.00A 20W 75mV pk-pk ±1% ±5% 5.75V - 7.75V ME30A0903F01 9.0V 3.00A 27W 90mV pk-pk ±1% ±5% 11.7V - 16.2V ME30A1203F01 12.0V 2.50A 30W 120mV pk-pk ±1% ±5% 14.4V - 16.8V ME30A1503F01 15.0V 2.00A 30W 150mV pk-pk ±1% ±5% 18.0V - 21.0V ME30A1803F01 18.0V 1.67A 30W 180mV pk-pk ±1% ±5% 21.6V - 25.2V ME30A2403F01 24.0V 1.33A 30W 240mV pk-pk ±1% ±5% 28.8V - 33.6V ME30A4803F01 48.0V 0.63A 30W 480mV pk-pk ±1% ±5% 55.0V - 60.0V ME30A0503N01 5.0V 4.00A 20W 75mV pk-pk ±1% ±5% 5.75V - 7.75V ME30A0903N01 9.0V 3.00A 27W 90mV pk-pk ±1% ±5% 11.7V - 16.2V ME30A1203N01 12.0V 2.50A 30W 120mV pk-pk ±1% ±5% 14.4V - 16.8V ME30A1503N01 15.0V 2.00A 30W 150mV pk-pk ±1% ±5% 18.0V - 21.0V ME30A1803N01 18.0V 1.67A 30W 180mV pk-pk ±1% ±5% 21.6V - 25.2V ME30A2403N01 24.0V 1.33A 30W 240mV pk-pk ±1% ±5% 28.8V - 33.6V ME30A4803N01 48.0V 0.63A 30W 480mV pk-pk ±1% ±5% 55.0V - 60.0V ME30A0503Q01 5.0V 4.00A 20W 75mV pk-pk ±1% ±5% 5.75V - 7.75V ME30A0903Q01 9.0V 3.00A 27W 90mV pk-pk ±1% ±5% 11.7V - 16.2V ME30A1203Q01 12.0V 2.50A 30W 120mV pk-pk ±1% ±5% 14.4V - 16.8V ME30A1503Q01 15.0V 2.00A 30W 150mV pk-pk ±1% ±5% 18.0V - 21.0V ME30A1803Q01 18.0V 1.67A 30W 180mV pk-pk ±1% ±5% 21.6V - 25.2V ME30A2403Q01 24.0V 1.33A 30W 240mV pk-pk ±1% ±5% 28.8V - 33.6V ME30A4803Q01 48.0V 0.63A 30W 480mV pk-pk ±1% ±5% 55.0V - 60.0V ME30 Datasheet v1121 Load Overvoltage Regulation Trip Range Copyright © 2021 SL Power Electronics Corp. All rights reserved. Output Connector Input Configuration Class I 2.5 x 5.5 x 9.5mm Desktop, Straight Barrel Type, IEC60320 C14 center positive Receptacle Class II 2.5 x 5.5 x 9.5mm Desktop, Straight Barrel Type, IEC60320 C8 center positive Receptacle Class II 2.5 x 5.5 x 9.5mm Desktop, Straight Barrel Type, IEC60320 C18 center positive Receptacle Page 1 ME30 Family 20W-30W Single Output External Power Medical Grade MODEL SELECTION Line Load Overvoltage Regulation Regulation Trip Range Model Number Volts Output Current Output Power Ripple & Noise1 ME30A0503B01 5.0V 4.00A 20W 75mV pk-pk ±1% ±5% 5.75V - 7.75V ME30A0903B01 9.0V 3.00A 27W 90mV pk-pk ±1% ±5% 11.7V - 16.2V ME30A1203B01 12.0V 2.50A 30W 120mV pk-pk ±1% ±5% 14.4V - 16.8V ME30A1503B01 15.0V 2.00A 30W 150mV pk-pk ±1% ±5% 18.0V - 21.0V ME30A1803B01 18.0V 1.67A 30W 180mV pk-pk ±1% ±5% 21.6V - 25.2V ME30A2403B01 24.0V 1.33A 30W 240mV pk-pk ±1% ±5% 28.8V - 33.6V ME30A4803B01 48.0V 0.63A 30W 480mV pk-pk ±1% ±5% 55.0V - 60.0V ME30A0503C01 5.0V 4.00A 20W 75mV pk-pk ±1% ±5% 5.75V - 7.75V ME30A0903C01 9.0V 3.00A 27W 90mV pk-pk ±1% ±5% 11.7V - 16.2V ME30A1203C01 12.0V 2.50A 30W 120mV pk-pk ±1% ±5% 14.4V - 16.8V ME30A1503C01 15.0V 2.00A 30W 150mV pk-pk ±1% ±5% 18.0V - 21.0V ME30A1803C01 18.0V 1.67A 30W 180mV pk-pk ±1% ±5% 21.6V - 25.2V ME30A2403C01 24.0V 1.33A 30W 240mV pk-pk ±1% ±5% 28.8V - 33.6V ME30A4803C01 48.0V 0.63A 30W 480mV pk-pk ±1% ±5% 55.0V - 60.0V Output Connector Input Configuration Class II WallPlug, 2.5 x 5.5 x 9.5mm Interchangeable Straight Barrel Type, Blades (North center positive American Blade included)² Class II Wall2.5 x 5.5 x 9.5mm Plug, Fixed Straight Barrel Type, North American center positive Blades³ Notes: 1. Measured at the output connector, with noise probe directly across output and load terminated with 0.1μF ceramic and 10μF low ESR capacitors. For 5V and 6V models, values listed are typical, 100mV pk-pk maximum with 0.1μF ceramic and 47μF low ESR capacitors used at measurement point. 2. Order blade kit KT-1027K for other blades (EU. UK, Australia) 3. For EU fixed blades, replace “C” in the model number with “M”, for UK blades, replace “C” with “G”, for Australia blades, replace “C” with “H”. 4. All specifications are typical at nominal input, full load, at 25°C ambient unless noted. 5. For Input Class I models: For AC GND connected to output common (-), insert a “B” in the part number where the “A” is located (ME30B1203F01). INPUT OUTPUT AC Input 100-240Vac, ±10%, 47-63Hz, 1Ø Turn On Time Less than 700mS @115Vac, full load Input Current 115Vac: 1.2A, 230Vac:0.6A Hold-Up Time 20mS min., at full Load, 100Vac input Inrush Current 264Vac, cold start: will not exceed 40A Input Fuses F1, F2: 2.0A, 250Vac fuses (line & neutral lines) provided on all models Patient Leakage Current (Output to Earth)
ME30A4803N01 价格&库存
很抱歉,暂时无法提供与“ME30A4803N01”相匹配的价格&库存,您可以联系我们找货
