MENB1040
Universal 40 Watt Series
Medical Switch-Mode Power Supply
3 Year Warranty
•100-240VAC Universal Input
•Meets EISA2007, CEC Efficiency Level V,
EU (EC) No 278/2009 Phase II
•Desktop Style
•Certified to UL/EN60601-1
•5V to 24V Single Output Models, up to 40W
•Modified and Custom Designs Available
•Regulated Output with Low Ripple
•Impact-Resistant Polycarbonate Enclosure
•No load Power Consumption 100,000 hours (calculated)
18 ms min. @ 115Vac, 60 ms @ 230 Vac
Overload Protection
Hiccup Mode
Short Circuit Protection
Hiccup Mode
Topology
Safety Standards
Switching – Fixed Frequency Flyback
EN/IEC/CSA/UL60601-1
EMC
Dielectric Withstand
Operating Temperature
See chart below
Input-Output: 5,656Vdc
Input-GND: 1,500 Vac, Output-GND: 500Vdc
0° to 40°C, no derating
Storage Temperature
Relative Humidity
-30 to +85°C
5% to 95%, non-condensing
Altitude
Output Cable
Output Connector
0 to 10,000 ft
#18AWG (UL1185), 1,500mm, 2 conductor
2.5mm barrel type (Ault #3), center positive (+)
EMC Specifications
Conducted Emissions
Radiated Emissions
Line Frequency Harmonics
Voltage Fluctuations/Flicker
Static Discharge Immunity
Radiated RF Immunity
EFT/Burst Immunity
Line Surge Immunity
Conducted RF Immunity
Power Frequency Magnetic Field Immunity
Voltage Dip Immunity
EN55011 Class B, FCC Part 15, Class B.
EN61000-3-2, Class A
EN61000-3-3
EN61000-4-2, 6kV Contact Discharge, 8kV air discharge
EN61000-4-3, 3V/m.
EN61000-4-4, 2kV/5kHz.
EN61000-4-5, 1kV differential, 2kV common-mode
EN61000-4-6, 3Vrms
EN61000-4-8, 3A/m
EN61000-4-11, Criteria A
______________________________________________________________________________________________________________________________ 1 of 2
SL Power Electronics Corp • 6050 King Drive Ventura, CA 93003 • Phone 805.486.4565 • Fax 858.712.2040 • Email: info@slpower.com • www.slpower.com
MENB1040
Medical Switch Mode Power Supply
Model Number
Volts (V)
3 Year Warranty
Output Current (max)
Max Watts
Ripple (Vp-p max)
MENB1040A0503F01
5V
5.00 A
25.0 W
50mV
MENB1040A0903F01
9V
4.00 A
36.0 W
90mV
MENB1040A1203F01
12 V
3.40 A
40.8 W
120mV
MENB1040A1503F01
15 V
2.76 A
40.5 W
150mV
MENB1040A1803F01
18 V
2.20 A
39.6 W
180mV
MENB1040A2403F01
24 V
1.70 A
40.8 W
240mV
Notes: Part numbers above include #3 output connector and IEC320 C14 grounded input receptacle. See below for other options.
Model Number Key
MENB 1 040 A VV 03 F 01
Model
Input Connector:
Output Connector:
Output Voltage:
Model
Output Pow er:
# of Outputs
Product Fam ily:
Input Receptacle Options
IEC320 - C14
IEC320 - C18
Class I
Class II
Grounded (F) Ungro unde d ( Q )
"01" = Standard. "02" and higher indicates a m odified m odel.
"F" = IEC320 C14 grounded, Other options available, see next page.
"03" = 2.5m m Barrel Type Connector. Other options available, contact factory.
"05" = 5Vdc, "12" = 12Vdc, "24" = 24Vdc, etc.
"A" = Original Configuration
"040" = 40 Watts
"1" = Single Output
"M" = Medical, "E" = External, "NB" = Model Series Designator
Output Connector
IEC320 - C8
Class II
"Shaver" (N)
Outline Drawing
61
34
101
Dimensions are in mm
Data Sheet © 2010 SL Power Electronics Corp. The information and specifications contained herein are believed to be correct at the time of publication.
Rev. 12-22-2010
However, SL Power accepts no responsibility for consequences arising from reproduction errors or inaccuracies. Specifications are subject to change without notice.
______________________________________________________________________________________________________________________________ 2 of 2
很抱歉,暂时无法提供与“MENB1040A0503N01”相匹配的价格&库存,您可以联系我们找货
