TE40A1202Q01
TE40A1202Q01
    SLPOWER
    AC/DCDESKTOPADAPTER12V40W
TE40A1202Q01 数据手册
40W Single Output External Power Industrial Grade TE40 Family FEATURES AND BENEFITS Industrial Meets DoE efficiency level VI requirements No load input power Average efficiency Meets EN55032/22, CISPR22, and FCC part 15.109 Class B conducted & radiated emissions, with 6db margin Up to 40W of AC-DC power Universal input 90-264Vac input range Desktop and Wall-Plug versions E-cap life of >8 years 3 years warranty Approved to EN/CSA/IEC/UL62368-1 >1,000,000 hours MTBF Meets “Heavy Industrial” levels of EN61000 EMC requirements RoHS compliant Note: * IP22 does not include interchangeable blade versions. MODEL SELECTION Line Load Overvoltage Regulation Regulation Trip Range Model Number Volts Output Current Output Power Ripple & Noise1 TE40A0503F01 5.0V 5.00A 25W 90mV pk-pk ±1% ±5% 120%-150% TE40A1203F01 12.0V 3.40A 40W 120mV pk-pk ±1% ±5% 120%-150% TE40A1503F01 15.0V 2.70A 40W 150mV pk-pk ±1% ±5% 120%-150% TE40A1803F01 18.0V 2.20A 40W 180mV pk-pk ±1% ±5% 120%-150% TE40A2403F01 24.0V 1.70A 40W 240mV pk-pk ±1% ±5% 120%-140% TE40A0503N01 5.0V 5.00A 25W 90mV pk-pk ±1% ±5% 120%-150% TE40A1203N01 12.0V 3.40A 40W 120mV pk-pk ±1% ±5% 120%-150% TE40A1503N01 15.0V 2.70A 40W 150mV pk-pk ±1% ±5% 120%-150% TE40A1803N01 18.0V 2.20A 40W 180mV pk-pk ±1% ±5% 120%-150% TE40A2403N01 24.0V 1.70A 40W 240mV pk-pk ±1% ±5% 120%-140% TE40A0503Q01 5.0V 5.00A 25W 90mV pk-pk ±1% ±5% 120%-150% TE40A1203Q01 12.0V 3.40A 40W 120mV pk-pk ±1% ±5% 120%-150% TE40A1503Q01 15.0V 2.70A 40W 150mV pk-pk ±1% ±5% 120%-150% TE40A1803Q01 18.0V 40W 180mV pk-pk ±1% ±5% 120%-150% TE40A2403Q01 24.0V 1.70A 40W 240mV pk-pk ±1% ±5% 120%-140% TE40A0503B01 5.0V 5.00A 25W 90mV pk-pk ±1% ±5% 120%-150% TE40A1203B01 12.0V 3.40A 40W 120mV pk-pk ±1% ±5% 120%-150% TE40A0503B01 5.0V 2.70A 25W 150mV pk-pk ±1% ±5% 120%-150% TE40A1803B01 18.0V 2.20A 40W 180mV pk-pk ±1% ±5% 120%-150% TE40A2403B01 24.0V 1.70A 40W 240mV pk-pk ±1% ±5% 120%-140% TE40 Datasheet v0920 2.20A Copyright © 2020 SL Power Electronics Corp. All rights reserved. Output Cable & Connector Input Configuration 2.5 x 5.5 x 9.5mm Straight Barrel Type, center positive Class I Desktop, IEC60320 C14 Receptacle 2.5 x 5.5 x 9.5mm Straight Barrel Type, center positive Class I Desktop, IEC60320 C8 Receptacle 2.5 x 5.5 x 9.5mm Straight Barrel Type, center positive Class II Desktop, IEC60320 C18 Receptacle 2.5 x 5.5 x 9.5mm Straight Barrel Type, center positive Class II Wall-Plug, Interchangeable Blades² Page 1 40W Single Output External Power Industrial Grade TE40 Family MODEL SELECTION Line Load Overvoltage Regulation Regulation Trip Range Model Number Volts Output Current Output Power Ripple & Noise1 TE40A0503C01 5.0V 5.00A 25W 90mV pk-pk ±1% ±5% 120%-150% TE40A1203C01 12.0V 3.40A 40W 120mV pk-pk ±1% ±5% 120%-150% TE40A1503C01 15.0V 2.70A 40W 150mV pk-pk ±1% ±5% 120%-150% TE40A1803C01 18.0V 2.20A 40W 180mV pk-pk ±1% ±5% 120%-150% TE40A2403C01 24.0V 1.70A 40W 240mV pk-pk ±1% ±5% 120%-140% Output Cable & Connector Input Configuration 2.5 x 5.5 x 9.5mm Class II Wall-Plug, Straight Barrel Type, Fixed North center positive American Blades³ Notes : 1. Measured at the output connector, with noise probe directly across output and load terminated with 0.1μF ceramic and 10μF low ESR capacitors. 2. 3. 4. 5. Standard models are fitted with North American blades. Order blade kit KT-1027K for other blades (EU. UK, Australia) For EU fixed blades, replace “C” in the model number with “M”, for UK blades, replace “C” with “G”, for Australia blades, replace “C” with “H”. All specifications are typical at nominal input, full load, at 25°C ambient unless noted. For Input Class I models: For AC GND connected to output common (-), insert a “B” in the part number where the “A” is located (TE40B1203F01). OUTPUT INPUT AC Input 100-240Vac, ±10%, 47-63Hz, 1Ø Hold-Up Time 20mS min., at full load, 100Vac input Input Current 115Vac: 1.2A, 230Vac: 0.6A Turn On Time Less than 700mS @115Vac, full load Inrush Current 264Vac, cold start: will not exceed 40A Output Power 40W continuous - See models chart for specific voltage model ratings Input Fuses 2.0A, 250Vac Output Voltage See models chart on pg 1 Leakage Current Input-GND: 250 W Disclaimer : The information and specifications contained herein are believed to be correct at the time of publication. However, SL Power accepts no responsibility for consequences arising from reproduction errors or inaccuracies. Specifications are subject to change without notice. TE40 Datasheet v0920 Copyright © 2020 SL Power Electronics Corp. All rights reserved. Page 6
TE40A1202Q01 价格&库存
很抱歉,暂时无法提供与“TE40A1202Q01”相匹配的价格&库存,您可以联系我们找货
