EMMA150100-P6RP-IC
EMMA150100-P6RP-IC
    CUIDEVICES
    AC/DCWALLMOUNTADAPTER15V15W
EMMA150100-P6RP-IC 数据手册
Additional Resources: Product Page date 06/20/2017 page 1 of 4 SERIES: EMMA 15W │ DESCRIPTION: MEDICAL AC-DC POWER SUPPLY FEATURES • • • • • • • • • up to 15 W power interchangeable AC blades universal input (90~264 Vac) single regulated output from 5~24 Vdc over voltage and short circuit protections UL/cUL, CE safety approvals medical 60601-1 4th edition safety approvals designed for 2 x MOPP applications level V efficiency ® MODEL IEC 60601-1 EN 60601-1 output voltage output current output power ripple and noise1 (Vdc) max (A) max (W) max (mVp-p) EMMA050200 5 2 10 50 V EMMA120110 12 1.1 13.2 120 V EMMA150100 15 1.0 15 150 V EMMA240063 24 0.625 15 240 V 1. at full load, 100 ~ 240 Vac input, 20 MHz bandwidth oscilloscope, each output terminated with a 10 µF aluminum electrolytic and 0.1 µF ceramic capacitors. PART NUMBER KEY EMMA120110 X - XX - IC - CXX Base Number example of 12 Vdc, 1.1 A DC Plug Type: See output plug options on page 3 for more details Blades: “blank” = North American, European, United Kingdom, Australian N = North American blade included E = European blade included B = United Kingdom blade included A = Australian blade included K = No blades included cui.com Factory Designation Reserved for Custom Configurations efficiency level Additional Resources: Product Page CUI Inc │ SERIES: EMMA 15W │ DESCRIPTION: MEDICAL AC-DC POWER SUPPLY date 06/20/2017│ page 2 of 4 INPUT parameter conditions/description min voltage frequency inrush current max units 90 typ 264 Vac 47 63 Hz 50 A 0.3 W max units at 240 V ac no load power consumption OUTPUT parameter conditions/description min line regulation typ ±1 % load regulation2 5 Vdc output all other outputs ±4 ±2 % % voltage accuracy 5 Vdc output all other outputs ±3 ±2 % % hold-up time at 115 Vac 10 ms 1 switching frequency temperature coefficient Note: 95 kHz ±0.05 %/°C 1. measured from 100 ~ 240 Vac, full load 2. measured from 60% to full load and from 60 ~ 20% load (60% ±40% load) PROTECTIONS parameter conditions/description over voltage protection TVS component to clamp short circuit protection continuous, auto restart SAFETY & COMPLIANCE parameter conditions/description isolation voltage input to output min typ safety approvals medical IEC 60601-1, EN 60601-1, UL 60601-1 4th edition EMI/EMC EN5 5011 Class B, FCC Part 15 Class B, EN 60601-1-2, EN 61000-3-(2,3) leakage current max units 5,656 Vdc 0.1 MTBF as per MIL-HDBK-217F, 115 Vac, 25 °C RoHS 2011/65/EU 200,000 mA hours ENVIRONMENTAL parameter conditions/description min operating temperature storage temperature humidity non-condensing cui.com typ max units 0 50 °C -20 85 °C 93 % Additional Resources: Product Page CUI Inc │ SERIES: EMMA 15W │ DESCRIPTION: MEDICAL AC-DC POWER SUPPLY date 06/20/2017│ page 3 of 4 ø3.5 +0/-0.1 MECHANICAL parameter conditions/description dimensions 80.60 x 47.90 x 43.30 (3.173 x 1.886 x 1.705 inch) min input plug interchangeable blades (US, Europe, UK, Australia) typ max units mm weight 130 14±0.5 g MECHANICAL DRAWING *Tip positive units: mm [inches] tolerance: ±0.5[0.02] P1R 43.30 1.705 47.90 1.886 B A C 80.60 3.173 Right Angle PXR EMM-US EMM-AU EMM-EU B A EMM-UK DC OUTPUT PLUG OPTIONS / DC CORD C Right Angle PXXR D P6/P6R Ń ł Ń ł 25±5 9±2 Standard PX P5/P5R cord length ń ń Right Angle PXR A B C Unit MODEL NO. CABLE GAUGE CORD LENGTH 5.5 2.1 9.5 mm EMMA050200 18 AWG 1,800 mm ±50 mm EMMA120110 18 AWG 1,800 mm ±50 EMMA150100 18 AWG 1,800 mm ±50 EMMA240063 18 AWG 1,800 mm ±50 5.5 2.5 9.5 PXX X X Plug Type Plug Angle: “Blank” = Standard R = Right Angle act CUI for additional output plug options. Plug Polarity: “Blank” = N/A P = Center Positive N = Center Negative cui.com Additional Resources: Product Page CUI Inc │ SERIES: EMMA 15W │ DESCRIPTION: MEDICAL AC-DC POWER SUPPLY date 06/20/2017│ page 4 of 4 REVISION HISTORY rev. description date 1.0 initial release 12/16/2011 1.01 updated P7/P7R B dimension 03/23/2012 1.02 V-Infinity branding removed 08/21/2012 1.03 updated safety approvals 04/29/2013 1.04 updated datasheet 07/17/2015 1.05 updated to medical 60601-1 4th edition 06/20/2017 The revision history provided is for informational purposes only and is believed to be accurate. Headquarters 20050 SW 112th Ave. Tualatin, OR 97062 800.275.4899 Fax 503.612.2383 cui.com techsupport@cui.com This device complies with part 15 of the FCC Rules. Operation is subject to the following two conditions: (1) This device may not cause harmful interference, and (2) this device must accept any interference received, including interference that may cause undesired operation. CUI offers a one (1) year limited warranty. Complete warranty information is listed on our website. CUI reserves the right to make changes to the product at any time without notice. Information provided by CUI is believed to be accurate and reliable. However, no responsibility is assumed by CUI for its use, nor for any infringements of patents or other rights of third parties which may result from its use. CUI products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness.
EMMA150100-P6RP-IC 价格&库存
很抱歉,暂时无法提供与“EMMA150100-P6RP-IC”相匹配的价格&库存,您可以联系我们找货
