ETMA240125UD-P6RP-IC
    CUIDEVICES
    AC/DC DESKTOP ADAPTER 24V 30W
ETMA240125UD-P6RP-IC 数据手册
Additional Resources: Product Page | 3D Model date 07/10/2015 page 1 of 4 SERIES: ETMA 30W │ DESCRIPTION: MEDICAL AC-DC POWER SUPPLY FEATURES • • • • • • • up to 30 W power universal input (90~264 Vac) single regulated output from 5~24 Vdc over voltage and short circuit protections full medical safety approvals level V efficiency custom designs available MODEL output voltage output current output power ripple and noise1 (Vdc) max (A) max (W) max (mVp-p) 5 4 20 50 V ETMA050400UD efficiency level ETMA090300UD 9 3 27 90 V ETMA120250UD 12 2.5 30 120 V ETMA150200UD 15 2 30 150 V ETMA180165UD 18 1.65 30 180 V ETMA240125UD 24 1.25 30 240 V 1. at full load, 100 ~ 240 Vac input, 20 MHz bandwidth oscilloscope, each output terminated with a 10 µF aluminum electrolytic and 0.1 µF ceramic capacitors. PART NUMBER KEY ETMA050400UD - XX - IC - CXX Base Number example of 5 Vdc, 4 A DC Plug Type: See output plug options on page 3 for more details cui.com Factory Designation Reserved for Custom Configurations Additional Resources: Product Page | 3D Model CUI Inc │ SERIES: ETMA 30W │ DESCRIPTION: MEDICAL AC-DC POWER SUPPLY date 07/10/2015 │ page 2 of 4 INPUT parameter conditions/description min voltage 90 frequency 47 typ input current inrush current at 240 Vac no load power consumption max units 264 Vac 63 Hz 0.6 A 50 A 0.3 W max units OUTPUT parameter conditions/description min line regulation1 load regulation2 5 Vdc output 9 Vdc output 12, 15 Vdc outputs 18, 24 Vdc outputs voltage accuracy hold-up time at 115 Vac switching frequency temperature coefficient Note: typ ±1 % ±6 ±4 ±3 ±2 % % % % ±2 % 16 ms 70 kHz ±0.05 %/°C 1. measured from 100 ~ 240 Vac, full load 2. measured from 60% to full load and from 60 ~ 20% load (60% ±40% load) PROTECTIONS parameter conditions/description over voltage protection TVS component to clamp short circuit protection continuous, auto restart SAFETY & COMPLIANCE parameter conditions/description isolation voltage input to output min safety approvals IEC 60601-1, EN 60601-1, UL 60601-1 EMI/EMC EN 55011, EN 60601-1-2, EN 61000-3-(2,3) MTBF as per MIL-HDBK-217F, 115 Vac, 25 °C RoHS 2011/65/EU typ max units 5,656 Vdc 300,000 hours ENVIRONMENTAL parameter conditions/description min operating temperature storage temperature humidity non-condensing cui.com max units 0 typ 40 °C -20 85 °C 93 % Additional Resources: Product Page | 3D Model CUI Inc │ SERIES: ETMA 30W │ DESCRIPTION: MEDICAL AC-DC POWER SUPPLY date 07/10/2015 │ page 3 of 4 MECHANICAL parameter conditions/description dimensions 110 x 50 x 30 (4.331 x 1.969 x 1.181 inch) min input plug IEC320 / C8 typ max units mm weight 220 g MECHANICAL DRAWING units: mm 50 0.5 30 0.5 110 0.5 LED DC OUTPUT PLUG OPTIONS / DC CORD ń Standard PX cord length Ń ł Ń ł ń Right Angle PXR A B C Unit P5/P5R 5.5 2.1 9.5 mm P6/P6R 5.5 2.5 9.5 mm cui.com MODEL NO. CABLE GAUGE CORD LENGTH ETMA050400UD 18 AWG 720 mm ±50 ETMA090300UD 18 AWG 1,220 mm ±50 ETMA120250UD 18 AWG 1,800 mm ±50 ETMA150200UD 18 AWG 1,800 mm ±50 ETMA180165UD 18 AWG 1,800 mm ±50 ETMA240125UD 18 AWG 1,800 mm ±50 Additional Resources: Product Page | 3D Model CUI Inc │ SERIES: ETMA 30W │ DESCRIPTION: MEDICAL AC-DC POWER SUPPLY date 07/10/2015 │ page 4 of 4 REVISION HISTORY rev. description date 1.0 initial release 12/02/2011 1.01 updated P7/P7R B dimension 03/23/2012 1.02 V-Infinity branding removed 08/21/2012 1.03 updated datasheet 07/10/2015 company logo update 07/09/2020 1.04 The revision history provided is for informational purposes only and is believed to be accurate. Headquarters 20050 SW 112th Ave. Tualatin, OR 97062 800.275.4899 Fax 503.612.2383 cui.com techsupport@cui.com This device complies with part 15 of the FCC Rules. Operation is subject to the following two conditions: (1) This device may not cause harmful interference, and (2) this device must accept any interference received, including interference that may cause undesired operation. CUI offers a one (1) year limited warranty. Complete warranty information is listed on our website. CUI reserves the right to make changes to the product at any time without notice. Information provided by CUI is believed to be accurate and reliable. However, no responsibility is assumed by CUI for its use, nor for any infringements of patents or other rights of third parties which may result from its use. CUI products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness.
ETMA240125UD-P6RP-IC 价格&库存
很抱歉,暂时无法提供与“ETMA240125UD-P6RP-IC”相匹配的价格&库存,您可以联系我们找货
