EMMA240125-P6RP-IC
EMMA240125-P6RP-IC
    CUIDEVICES
    AC/DC WALL MOUNT ADAPTER 24V 30W
EMMA240125-P6RP-IC 数据手册
Additional Resources: Product Page date 06/20/2017 page 1 of 4 SERIES: EMMA 30W │ DESCRIPTION: MEDICAL AC-DC POWER SUPPLY FEATURES • • • • • • • • up to 30 W power universal input (90~264 Vac) interchangeable AC blades single regulated output from 5~24 Vdc over voltage and short circuit protections medical 60601-1 4th edition safety approvals designed for 2 x MOPP applications level V efficiency ® MODEL EMMA050400 IEC 60601-1 EN 60601-1 output voltage output current output power ripple and noise1 efficiency level (Vdc) max (A) max (W) max (mVp-p) 5 4 20 50 V EMMA090300 9 3 27 90 V EMMA120250 12 2.5 30 120 V EMMA150200 15 2 30 150 V EMMA180167 18 1.67 30 180 V EMMA240125 24 1.25 30 240 V 1. at full load, 100 ~ 240 Vac input, 20 MHz bandwidth oscilloscope, each output terminated with a 10 µF aluminum electrolytic and 0.1 µF ceramic capacitors. PART NUMBER KEY EMMA120250 X - XX - IC - CXX Base Number example of 12 Vdc, 2.5 A DC Plug Type: Factory See output plug options Designation on page 3 for more details Blades: “blank” = North American, European, United Kingdom, Australian N = North American blade included E = European blade included B = United Kingdom blade included A = Australian blade included K = No blades included cui.com Reserved for Custom Configurations Additional Resources: Product Page CUI Inc │ SERIES: EMMA 30W │ DESCRIPTION: MEDICAL AC-DC POWER SUPPLY date 06/20/2017│ page 2 of 4 INPUT parameter conditions/description min voltage 90 frequency 47 typ input current inrush current at 240 V ac, cold start no load power consumption max units 264 Vac 63 Hz 0.8 A 100 A 0.3 W max units OUTPUT parameter conditions/description min line regulation1 load regulation2 5 Vdc output 9 Vdc output all other outputs voltage accuracy hold-up time at 115 Vac switching frequency temperature coefficient Note: typ ±1 % ±6 ±3 ±2 % % % ±2 % 10 ms 70 kHz ±0.05 %/°C 1. measured from 100 ~ 240 Vac, full load 2. measured from 60% to full load and from 60 ~ 20% load (60% ±40% load) PROTECTIONS parameter conditions/description over voltage protection TVS component to clamp short circuit protection continuous, auto restart SAFETY & COMPLIANCE parameter conditions/description min typ isolation voltage input to output safety approvals medical IEC 60601-1, EN 60601-1, UL 60601-1 4th edition EMI/EMC EN 55011 Class B, FCC CRF47 Part 18 Class B, EN 60601-1-2, EN 61000-3-(2,3), IEC 61000-4-(2,4,5,6,8,11) leakage current max units 5,656 Vdc 0.1 MTBF as per MIL-HDBK-217F, 115 Vac, 25 °C RoHS 2011/65/EU 200,000 mA hours ENVIRONMENTAL parameter conditions/description min operating temperature storage temperature humidity non-condensing cui.com typ max units 0 40 °C -20 85 °C 93 % Additional Resources: Product Page CUI Inc │ SERIES: EMMA 30W │ DESCRIPTION: MEDICAL AC-DC POWER SUPPLY date 06/20/2017│ page 3 of 4 ø3.5 +0/-0.1 MECHANICAL parameter conditions/description dimensions 108.67 x 61.98 x 36.70 (4.278 x 2.440 x 1.445 inch) min input plug interchangeable blades (US, Europe, UK, Australia) typ max units mm weight 300 g 14±0.5 *Tip positive MECHANICAL DRAWING units: mm [inches] tolerance: P1R ±0.5 [±0.02] 36.70 1.445 61.98 2.440 1.40 0.055 B A C EMM-US EMM-AU Right Angle PXR 4.278 108.67 EMM-EU B A EMM-UK DC OUTPUT PLUG OPTIONS / DC CORD C Right Angle PXXR D 25±5 9±2 Standard PX Ń ł Ń ł cord length ń ń Right Angle PXR A B C Unit P5/P5R 5.5 2.1 9.5 mm MODEL NO. CABLE GAUGE CORD LENGTH P6/P6R 5.5 2.5 9.5 mm EMMA050040 18 AWG 1,220 mm ±50 EMMA090300 18 AWG 1,220 mm ±50 EMMA120250 18 AWG 1,800 mm ±50 EMMA150200 18 AWG 1,800 mm ±50 EMMA180167 18 AWG 1,800 mm ±50 EMMA240125 18 AWG 1,800 mm ±50 PXX X X Plug Type Plug Angle: “Blank” = Standard R = Right Angle act CUI for additional output plug options. Plug Polarity: “Blank” = N/A P = Center Positive N = Center Negative cui.com Additional Resources: Product Page CUI Inc │ SERIES: EMMA 30W │ DESCRIPTION: MEDICAL AC-DC POWER SUPPLY date 06/20/2017│ page 4 of 4 REVISION HISTORY rev. description date 1.0 initial release 12/16/2011 1.01 updated P7/P7R B dimension 03/23/2012 1.02 V-Infinity branding removed 08/21/2012 1.03 updated datasheet 07/10/2015 updated to medical 60601-1 4th edition 06/20/2017 1.04 The revision history provided is for informational purposes only and is believed to be accurate. Headquarters 20050 SW 112th Ave. Tualatin, OR 97062 800.275.4899 Fax 503.612.2383 cui.com techsupport@cui.com This device complies with part 15 of the FCC Rules. Operation is subject to the following two conditions: (1) This device may not cause harmful interference, and (2) this device must accept any interference received, including interference that may cause undesired operation. CUI offers a one (1) year limited warranty. Complete warranty information is listed on our website. CUI reserves the right to make changes to the product at any time without notice. Information provided by CUI is believed to be accurate and reliable. However, no responsibility is assumed by CUI for its use, nor for any infringements of patents or other rights of third parties which may result from its use. CUI products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness.
EMMA240125-P6RP-IC 价格&库存
很抱歉,暂时无法提供与“EMMA240125-P6RP-IC”相匹配的价格&库存,您可以联系我们找货
