MENB1010A1202Q01
MENB1010A1202Q01
    SLPOWER
    AC/DC DESKTOP ADAPTER 12V 10W
MENB1010A1202Q01 数据手册
MENB1010 Universal 10 Watt Series Medical Switch-Mode Power Supply 3 Year Warranty •100-240Vac Universal Input Range •Meets EISA2007, CEC Efficiency Level V, EU (EC) No 278/2009 Phase II •Desktop & Wall Plug Styles •5V to 24V Single Output Models, up to 12W •Modified and Custom Designs Available •Regulated Output with Low Ripple •Impact-Resistant Polycarbonate Enclosure •No load Power Consumption 100,000 hours (calculated) Hold-up Time 18 mS min. @ 115Vac, 60 mS min. @ 230 Vac Overload Protection Hiccup Mode Short Circuit Protection Hiccup Mode Topology Switching – Fixed Frequency Flyback EN/IEC/CSA/UL60601-1, 3rd Edition Safety Standards EMC, Radiated & Conducted Dielectric Withstand Operating Temperature Storage Temperature Relative Humidity See Chart below Input-Output: 2 MOPP, Input-Ground: 1 MOPP, Output-Ground: 500Vac 0 to 40C, no derating -30 to +85C 5% to 95%, non-condensing Operating Altitude -500 to 10,000 ft Non-operating Altitude -500 to 40,000 ft Output Connector 2.5mm barrel type (Ault #3), center contact (+) Other options available, contact the factory for details EMC Specifications Conducted Emissions Radiated Emissions Line Frequency Harmonics Voltage Fluctuations/Flicker Static Discharge Immunity Radiated RF Immunity EFT/Burst Immunity Line Surge Immunity Conducted RF Immunity Power Frequency Magnetic Field Immunity Voltage Dip Immunity EN55011 Class B, FCC Part 15, Class B. EN55011 Class B, FCC Part 15, Class B. EN61000-3-2, Class A EN61000-3-3 EN61000-4-2, 6kV Contact Discharge, 8kV air discharge EN61000-4-3, 3V/m. EN61000-4-4, 2kV/5kHz. EN61000-4-5, 1kV differential, 2kV common-mode EN61000-4-6, 3Vrms EN61000-4-8, 3A/m EN61000-4-11, Criteria A ________________________________________________________________________________________________________________________________ 1 of 2 SL Power Electronics Corp  6050 King Drive Ventura, CA 93003  Phone 805.486.4565  Fax 858.712.2040  Email: info@slpower.com  www.slpower.com MENB1010 Universal 10 Watt Series Medical Switch-Mode Power Supply Model Number Volts (V) 3 Year Warranty Output Current (max) Max Watts Ripple (Vp-p max) MENB1010A0503F01 5V 2.00 A 10.0 W 50 mV MENB1010A0603F01 6V 2.00 A 12.0 W 60 mV MENB1010A0703F01 7.5 V 1.60 A 12.0 W 75 mV MENB1010A0903F01 9V 1.10 A 10.0 W 90 mV MENB1010A1203F01 12 V 1.00 A 12.0 W 120 mV MENB1010A1503F01 15 V 0.80 A 12.0 W 150 mV MENB1010A1603F01 16 V 0.75 A 12.0 W 160 mV MENB1010A1803F01 18 V 0.67 A 12.0 W 180 mV MENB1010A2403F01 24 V 0.50 A 12.0 W 240 mV MENB1010A4803F01 48 V 0.25 A 12.0 W 480 mV Notes: Part numbers above include #3 output connector and IEC320 C14 grounded input receptacle. See below for other options. Model Number Key MENB 1 010 A VV 03 F 01 Model Input Connector: Output Connector: Output Voltage: Model Output Pow er: # of Outputs Product Fam ily: "01" = Standard. "02" and higher indicates a m odified m odel. "F" = IEC320 C14 grounded, Other options available, see below "03" = 2.5mm Barrel Type Connector. Other options available, contact factory. "05" = 5Vdc, "12" = 12Vdc, "24" = 24Vdc, etc. "A" = Original Configuration "010" = 10 Watts "1" = Single Output "M" = Medical, "E" = External, "NB" = Model Series Designator AC Input Receptacle Options Desktop IEC320 - C14 Class I Grounded IEC320 - C18 Class II Ungro unded IEC320 - C8 Class II "Shaver" (F) (Q) (N) Notes: Output Connector Wall-Plug N. Am erica Japan N. Am erica Japan Int e rc ha nga ble Fixed (B) (C) Europe Fixed (M) United Kingdom Fixed (G) Australia Fixed (H) 1. For desktop options, choose applicable letter above. 2. For Wall-Plug options, choose the applicable letter above and the unit w ill be fitted w ith the receptacle chosen. The N. A. blade version (B) w ill be an interchangeable blade. The other options (C), (M), (G), and (H) w ill be fixed blades m olded in the case. 3. Blade Kit is available w hich w ill include one each of a EU, UK, and Australian blade. Kit part # is KT1027K. These can be used w ith the (B) version, to allow blades to be changed. Notes: 1. Ault #3 Connector, center contact (+). 2. Connector is Sw itchcraft 760 plug or equivalent. Mating connector is Sw itchcraft 712A or equivalent. 3. Other connector options are available. Contact your local SL Pow er Representative for details. Outline Drawings Desktop Style Wall-Plug Style (Option “B” Shown) Data Sheet © 2014 SL Power Electronics Corp. The information and specifications contained herein are believed to be correct at the time of publication. Rev. 4-11-2014 However, SL Power accepts no responsibility for consequences arising from reproduction errors or inaccuracies. Specifications are subject to change without notice. ________________________________________________________________________________________________________________________________ 2 of 2 SL Power Electronics Corp  6050 King Drive Ventura, CA 93003  Phone 805.486.4565  Fax 858.712.2040  Email: info@slpower.com  www.slpower.com
MENB1010A1202Q01
物料型号:MENB1010 SL系列
器件简介:这是一个通用的10瓦医疗开关电源,提供3年保修,适用于桌面和墙插式风格,有5V至24V的单输出型号,最大12W。
引脚分配:文档中未明确提供引脚分配信息,但提到了输出连接器为2.5mm筒型(Ault #3),中心接触(+)。
参数特性: - 交流输入:100-240Vac,47-63 Hz - 输出功率:根据型号不同,最大12W - 效率:满足EISA2007、CEC效率等级V、EU (EC) No 278/2009第二阶段 - 输出电压:见图表 - 纹波和噪声:最大1%峰-峰值,20MHz带宽 - 工作温度:0至40°C,无需降额 - 存储温度:-30至+85°C
功能详解: - 具有低纹波的稳压输出 - 抗冲击聚碳酸酯外壳 - 无负载功耗:<0.3W - 限电保护 - 认证:UL/EN/IEC60601-1,第三版,2xMOPP隔离
应用信息:适用于医疗设备,具有多种输出电压和电流选项。
封装信息: - 外壳材料:黑色94V-0聚碳酸酯 - 尺寸:84x47x32mm - 重量:110g - 输出电缆:#20AWG(UL2468),1500mm,2导体
EMC规格:包括传导发射、辐射发射、线路频率谐波、电压波动/闪烁、静电放电抗扰度等。
安全标准:EN/IEC/CSA/UL60601-1,第三版。
MENB1010A1202Q01 价格&库存
很抱歉,暂时无法提供与“MENB1010A1202Q01”相匹配的价格&库存,您可以联系我们找货
