ETMA120500UD-P5RP-IC 数据手册
Additional Resources:
Product Page
3D Model
date
06/20/2017
page
1 of 4
SERIES: ETMA 60W UD │ DESCRIPTION: MEDICAL AC-DC POWER SUPPLY
FEATURES
up to 60 W power
universal input (90~264 Vac)
single regulated output from 12~48 Vdc
over voltage and short circuit protections
medical 60601-1 4th edition safety approvals
designed for 2 x MOPP applications
level V efficiency
custom designs available
IEC
60601-1
EN
60601-1
MODEL
output
voltage
output
current
output
power
ripple
and noise1
(Vdc)
max
(A)
max
(W)
max
(mVp-p)
ETMA120500UD
12
5
60
120
V
ETMA150400UD
15
4
60
150
V
ETMA180333UD
18
3.33
60
180
V
ETMA240250UD
24
2.5
60
240
V
ETMA360166UD
36
1.66
60
360
V
ETMA480125UD
48
1.25
60
480
V
Notes:
efficiency
level
1. At full load, 100 ~ 240 Vac input, 20 MHz bandwidth oscilloscope, each output terminated with 10 µF aluminum electrolytic and 0.1 µF ceramic capacitors.
PART NUMBER KEY
ETMA120500UD - XX - IC - CXX
Base Number
example of 12 Vdc, 5 A
DC Plug Type:
See output plug options on
page 3 for more details
cui.com
Factory
Designation
Reserved for Custom
Configurations
Product Page
3D Model
CUI Inc │ SERIES: ETMA 60W UD│ DESCRIPTION: MEDICAL AC-DC POWER SUPPLY
date 06/20/2017 │ page 2 of 4
INPUT
parameter
conditions/description
min
voltage
frequency
inrush current
max
units
90
typ
264
Vac
47
63
Hz
80
A
0.3
W
max
units
at 240 Vac
no load power consumption
OUTPUT
parameter
min
line regulation
1
load regulation2
12 Vdc output
15 Vdc output
all other outputs
voltage accuracy
hold-up time
at 115 Vac
switching frequency
temperature coefficient
Note:
typ
±1
±5
±3
±2
±2
8
ms
100
kHz
±0.05
%/°C
1. measured from 100 ~ 240 Vac, full load
2. measured from 60% to full load and from 60 ~ 20% load (60% ±40% load)
PROTECTIONS
parameter
over voltage protection
TVS component to clamp
continuous, auto restart
min
typ
min
typ
max
units
max
units
5,656
Vdc
SAFETY & COMPLIANCE
parameter
isolation voltage
input to output
safety approvals
medical IEC 60601-1, EN 60601-1, UL 60601-1 4th edition
EMI/EMC
EN 55011, EN 60601-1-2, EN 61000-3-(2,3)
leakage current
0.1
MTBF
as per MIL-HDBK-217F, 115 Vac, 25 °C
RoHS
2011/65/EU
200,000
mA
hours
ENVIRONMENTAL
parameter
min
operating temperature
storage temperature
humidity
non-condensing
cui.com
typ
max
units
°C
-20
85
°C
93
Product Page
3D Model
date 06/20/2017 │ page 3 of 4
ø3.5 +0/-0.1
MECHANICAL
parameter
dimensions
132 x 58 x 30.5 (5.2 x 2.28 x 1.2 inch)
min
input plug
IEC320 / C8
typ
max
units
mm
weight
345
g
14±0.5
MECHANICAL DRAWING
*Tip positive
units: mm
58 0.5
P1R
B
A
C
30.5 0.5
Right Angle PXR
132 0.5
B
A
LED
DC OUTPUT PLUG OPTIONS / DC CORD
C
Right Angle PXXR
D
ń
25±5
9±2 Standard PX
cord length
Ń
ł
Ń
ł
ń
Right Angle PXR
A
B
C
Unit
P5/P5R
5.5
2.1
9.5
mm
P6/P6R
5.5
2.5
9.5
mm
PXX X X
Plug Type
Plug Angle:
“Blank” = Standard
R = Right Angle
act CUI for additional output plug options.
Plug Polarity:
“Blank” = N/A
P = Center Positive
N = Center Negative
cui.com
MODEL NO.
CABLE GAUGE
CORD LENGTH
ETMA120500UD
16 AWG
720 mm ±50
ETMA150400UD
16 AWG
1,220 mm ±50
ETMA180333UD
16 AWG
1,500 mm ±50
ETMA240250UD
16 AWG
1,800 mm ±50
ETMA360166UD
16 AWG
1,800 mm ±50
ETMA480125UD
16 AWG
1,800 mm ±50
Product Page
3D Model
date 06/20/2017 │ page 4 of 4
REVISION HISTORY
rev.
description
date
1.0
initial release
12/16/2011
1.01
updated P7/P7R B dimension
03/23/2012
1.02
V-Infinity branding removed
08/21/2012
1.03
updated datasheet
10/31/2012
1.04
corrected dc cord table
07/02/2013
1.05
updated datasheet
07/10/2015
1.06
updated to medical 60601-1 4th edition
06/20/2017
The revision history provided is for informational purposes only and is believed to be accurate.
Headquarters
20050 SW 112th Ave.
Tualatin, OR 97062
800.275.4899
Fax 503.612.2383
cui.com
techsupport@cui.com
This device complies with part 15 of the FCC Rules. Operation is subject to the following two conditions:
(1) This device may not cause harmful interference, and
(2) this device must accept any interference received, including interference that may cause undesired operation.
CUI offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI reserves the right to make changes to the product at any time without notice. Information provided by CUI is believed to be accurate and reliable. However, no responsibility is
assumed by CUI for its use, nor for any infringements of patents or other rights of third parties which may result from its use.
CUI products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical
component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to
affect its safety or effectiveness.
ETMA120500UD-P5RP-IC 价格&库存
很抱歉,暂时无法提供与“ETMA120500UD-P5RP-IC”相匹配的价格&库存,您可以联系我们找货
