ME90A1251F01
ME90A1251F01
    SLPOWER
    AC/DCDESKTOPADAPTER
ME90A1251F01 数据手册
90W Single Output External Power Medical Series ME90 Family FEATURES AND BENEFITS Medical Meets UL/EN/IEC60601-1-2, 4th edition for EMC* Approved to EN/IEC/UL60601-1, 3rd edition with isolation levels which satisfy the 2 MOPP requirements Meets DoE efficiency level VI requirements No load input power Average efficiency Desktop Style Package Meets EN55011/CISPR11, FCC Part 15.109 Class B conducted & radiated emissions, with 6db margin E-cap life of >7 years 3 years warranty IP22 rated enclosure Up to 90W of AC-DC power Note: * Professional equipment only. Consult factory for Table 9 compliance information. MODEL SELECTION Model Number Volts Output Current Output Power Ripple & Noise1 Line Regulation Load Regulation Output Connector ME90A1251F01 12.0V 7.50A 90W 120mV pk-pk ±1% ±5% ME90A1503F01 15.0V 6.00A 90W 150mV pk-pk ±1% ±5% 6 pin Molex Type2 ME90A1803F01 18.0V 5.00A 90W 180mV pk-pk ±1% ±5% ME90A2403F01 24.0V 3.75A 90W 240mV pk-pk ±1% ±5% 2.5 x 5.5 x 9.5mm Straight Barrel Type, center positive ME90A1251N01 12.0V 7.50A 90W 120mV pk-pk ±1% ±5% 6 pin Molex Type2 ME90A1503N01 15.0V 6.00A 90W 150mV pk-pk ±1% ±5% ME90A1803N01 18.0V 5.00A 90W 180mV pk-pk ±1% ±5% ME90A2403N01 24.0V 3.75A 90W 240mV pk-pk ±1% ±5% 2.5 x 5.5 x 9.5mm Straight Barrel Type, center positive ME90A1251Q01 12.0V 7.50A 90W 120mV pk-pk ±1% ±5% ME90A1503Q01 15.0V 6.00A 90W 150mV pk-pk ±1% ±5% 6 pin Molex Type2 ME90A1803Q01 18.0V 5.00A 90W 180mV pk-pk ±1% ±5% ME90A2403Q01 24.0V 3.75A 90W 240mV pk-pk ±1% ±5% Notes : 2.5 x 5.5 x 9.5mm Straight Barrel Type, center positive Overvoltage Trip Level Class I Desktop, IEC60320 C14 Receptacle Class II Desktop, IEC60320 C8 Receptacle Class II Desktop, IEC60320 C18 Receptacle 1. Measured at the output connector, with noise probe directly across output and load terminated with 0.1μF ceramic and 10μF low ESR capacitors. 2. Molex p/n 39-01-2060 or equivalent. See outline drawing for pinout information. 3. For Input Class I models: For AC GND connected to output common (-), insert a “B” in the part number where the “A” is located (ME90B1251F01). INPUT AC Input 100-240Vac, ±10%, 47-63Hz, 1ø Input Current 115Vac: 2.0A, 230Vac: 1.0A Inrush Current 264Vac, cold start: will not exceed 60A Input Fuses F1, F2: 3.15A, 250Vac fuses (line & neutral lines) provided on all models Earth Leakage Current (Input to Ground)
ME90A1251F01 价格&库存
很抱歉,暂时无法提供与“ME90A1251F01”相匹配的价格&库存,您可以联系我们找货
