MENB1090A1802F01
MENB1090A1802F01
    SLPOWER
    AC/DC DESKTOP ADAPTER 18V 90W
MENB1090A1802F01 数据手册
MENB1090 Universal Input 90 Watt Series Medical Switch-Mode Power Supply 3 Year Warranty •100-240VAC Universal Input •Meets EISA2007, CEC Efficiency Level V, EU (EC) No 278/2009 Phase II •Desktop Style •12V to 24V Single Output Models, up to 90W •Modified and Custom Designs Available •Regulated Output with Low Ripple •Impact-Resistant Polycarbonate Enclosure •No Load Power Consumption 100,000 hours (calculated) 18 ms min. @ 115Vac, 60 ms min. @ 230 Vac Operating Temperature Storage Temperature Relative Humidity Hiccup Mode Switching – Fixed Frequency Flyback EN/IEC/CSA/UL60601-1 EMC: See chart Input-Output: 5,656Vdc Input-GND: 1,500 Vac, Output-GND: 500Vdc 0° to 40°C, no derating -30 to +85°C 5% to 95%, non-condensing Altitude 0 to 10,000 ft Output Connections Cable: 18AWG, 1,500mm, 4 conductor Connector: Ault #3, 2.5mm barrel or #51, 6-pin Molex. See drawings. Weight 600g EMI/EMC Compliance Conducted Emissions FCC Part 15, Class B, EN55011 Class B, EN55024 Radiated Emissions FCC Part 15, Class B, EN55011 Class B, EN55024 Voltage Fluctuations EN61000-3-3, Line Flicker Static Discharge Immunity EN61000-4-2, 6kV Contact Discharge, 8kV air discharge Radiated RF Immunity EN61000-4-3, 3V/m. EFT/Burst Immunity EN61000-4-4, 2kV/5kHz.. Line Surge Immunity EN61000-4-5, 1kV differential, 2kV common-mode Conducted RF Immunity EN61000-4-6, 3Vrms Power Frequency Magnetic Field Immunity EN61000-4-8, 3A/m Voltage Dip Immunity EN61000-4-11 crit. A, 100Vac 60Hz, 40%/5 cycles with 70% full load. Line Frequency Harmonics EN61000-3-2, Class A ______________________________________________________________________________________________________________________________ 1 of 2 SL Power Electronics Corp • 6050 King Drive Ventura, CA 93003 • Phone 805.486.4565 • Fax 858.712.2040 • Email: info@slpower.com • www.slpower.com MENB1090 Universal Input 90 Watt Series Medical Switch-Mode Power Supply Model Number 3 Year Warranty Volts (V) Output Current (max) Max Watts Ripple (Vp-p max) MENB1090A1251F01 12 V 7.0 A 84.0 W 120mV MENB1090A1503F01 15 V 6.0 A 90.0 W 150mV MENB1090A1803F01 18 V 5.0 A 90.0 W 180mV MENB1090A2403F01 24 V 3.75 A 90.0 W 240mV Model Number Key MENB 1 090 A VV 03 F 01 Model Input Connector: Output Connector: Output Voltage: Model Output Pow er: # of Outputs Product Fam ily: Input Receptacle "01" = Standard. "02" and higher indicates a m odified m odel. "F" = IEC320 C14 grounded, Other options available, see below "03" = 2.5m m Barrel Type Connector, "51" = 6 pin Molex. Other options available. "05" = 5Vdc, "12" = 12Vdc, "24" = 24Vdc, etc. "A" = Original Configuration "090" = 90 Watts "1" = Single Output "M" = Medical, "E" = External, "NB" = Model Series Designator Output Connector Output Connector (12V models) “#3” Connector is 2.5mm barrel type, center (+) “#51” Connector is Molex 39-01-2060 or equivalent. IEC320 C14 - Class I Grounded (F) “51" Connector Pinout: Pins 1, 4: (+), Pins 3, 6: (-). Mate = Molex 39-01-2061 or equiv. Outline Drawing DIN connector shown. Standard connector is “#3” or “#51” connector. See above. Dimensions are in mm Data Sheet © 2011 SL Power Electronics Corp. The information and specifications contained herein are believed to be correct at the time of publication. Rev. 4-25-2011 However, SL Power accepts no responsibility for consequences arising from reproduction errors or inaccuracies. Specifications are subject to change without notice. ______________________________________________________________________________________________________________________________ 2 of 2 SL Power Electronics Corp • 6050 King Drive Ventura, CA 93003 • Phone 805.486.4565 • Fax 858.712.2040 • Email: info@slpower.com • www.slpower.com
MENB1090A1802F01
物料型号:MENB1090系列,包括MENB1090A1251F01(12V, 7.0A, 84.0W)、MENB1090A1503F01(15V, 6.0A, 90.0W)、MENB1090A1803F01(18V, 5.0A, 90.0W)和MENB1090A2403F01(24V, 3.75A, 90.0W)。
器件简介:这是一款通用输入90瓦的医疗开关电源,具有3年保修期,符合EISA2007、CEC效率等级V和EU (EC) No 278/2009第二阶段标准。
引脚分配:输出连接包括电缆和连接器,12V型号使用IEC320 C14接地型连接器。
参数特性:输入电压范围100-240VAC,效率满足国际效率等级V,具有低纹波的稳定输出,无负载功耗小于0.5W。
功能详解:具有过载保护和短路保护,瞬态响应时间最大500us,最小负载无要求。
应用信息:适用于医疗设备,符合UL/EN/IEC60601-1和RoHS标准。
封装信息:外壳材料为黑色94V0聚碳酸酯,尺寸为129x77x40mm,重量为600g。
EMI/EMC合规性:符合FCC Part 15、EN55011、EN55024等标准。
MENB1090A1802F01 价格&库存
很抱歉,暂时无法提供与“MENB1090A1802F01”相匹配的价格&库存,您可以联系我们找货
