FW1812-760
FW1812-760
    INVENTUSPOWER
    AC/DC DESKTOP ADAPTER 12V 18W
FW1812-760 数据手册
FW18 series 18 Watt AC Adapter 3.35 [85.0 mm] 1.97 [50.0 mm] 1.30 [33.0 mm] Features Electrical Specifications Wide range AC input Fully regulated output High efficiency 5 year warranty Input Voltage................................ 100 - 240 VAC Current................................ 0.5 Amp @ 100 VAC Frequency........................... 47 - 63 Hz AC cord.............................. Optional Input connector................... 3 Pin IEC 320 input receptacle Environmental Operating temperature.......... 0 C to 40 C Storage temperature............. -55 C to 85 C Weight = 0.7 lbs EMI Meets FCC class B, CISPR 22 class B Safety UL cUL Nemko CE UL1950 CSA 22.2 NO. 950 EN 60950 Marked Polarity COM Output Line regulation.................... TYP +/- 1% Load regulation................... TYP +/- 5% Set point.............................. +/- 3% at 60% load Hold up time........................ 20 ms min at full load, 115 VAC Over voltage protection....... Built-in Over current protection....... Built-in Short circuit protection........ Pulsing mode, auto recovery Efficiency............................. 80% nominal at full load and 115 VAC (12 VDC and higher) Transient response............. 2 ms for 50% load change typical Ripple/noise (Vp-p)............... +/- 1% (20 MHz bandwidth) Output connector................ Barrel type (5.5 x 2.5 x 9.5 mm) +V Model No. FW1805-760-NC Voltage Power Current 5V 15W 3.00A FW1812-760-NC 12V 18W 1.50A FW1818-760-NC 18V 18W 1.00A FW1824-760-NC 24V 18W 0.75A Rev 0404 Elpac Power Supplies 1562 Reynolds Ave. Irvine, CA 92614 USA TEL +1 949-476-6070 www.elpac.com info@elpac.com
FW1812-760 价格&库存
很抱歉,暂时无法提供与“FW1812-760”相匹配的价格&库存,您可以联系我们找货
