date 03/2012
page 1 of 6
POWER SUPPLY
DESCRIPTION: SWITCHING
SERIES:
18 W MULTI-BLADE
ED
FEATURES
MODEL
output voltage
output current
ripple*
max
(W)
max.
(mVp-p)
3.2
16
150
IV
1000 +150/-0
18
150
IV
1000 ±100
7
19.25
150
IV
1830 +150/-0
9
18
150
IV
1830 +150/-0
max
(A)
EMS050320
5
EMS060300
6
EMS070257
EMS090200
EMS180100
18
EMS200090
cord length
(mm)
18
150
IV
1830 +150/-0
18
150
V
1830 +150/-0
18
150
V
1830 +150/-0
18
150
IV
1830 +150/-0
0.75
18
240
V
1830 +150/-0
N
12
15
O
EMS120150
EMS150120
TI
min
(A)
efficiency level
RoHS
output wattage
nominal
(V dc)
EMS240075
N
U
•universal AC input
•regulated output voltage
•interchangeable input blade
•short circuit, over load protection
•meets EISA / efficiency level IV regulations
•custom designs available
IS
C
*at full load, 100 ~ 240 V ac input, measured at 20MHz bandwidth with a 10 uF electrolytic cap and a 0.1 uF ceramic cap on the output
PART NUMBER KEY
EMS050320 - XX - SZ - CXX
Base Number
Reserved for custom
configurations
D
example of 5 V dc, 3.2 A
DC Plug type:
see output plug options
on page 5
20050 SW 112th Ave. Tualatin, Oregon 97062
Factory
Designation
phone 503.612.2300
fax 503.612.2382 www.v-infinity.com
date 03/2012
page 2 of 6
INPUT
parameter
conditions/description
min
rated input voltage
100
input voltage range
90
rated frequency
50
frequency range
47
inrush current
115 V ac, full load, cold start, 25°C
230 V ac, full load, cold start, 25°C
no load power consumption
parameter
N
OUTPUT
min
line regulation
TI
load regulation
over voltage protection
output shut down
short circuit protection
output shut down and auto-restart
SAFETY & EMI
HI-POT
input to output at 10 mA for 1 minute
insulation resistance
input to output at 500 V dc
safety approvals
UL/cUL, CB (IEC60950-1), CE (GS/TUV EN60950-1)
units
240
V ac
264
V ac
60
Hz
63
Hz
0.6
A
30
60
A
A
0.3
W
max
units
±6
nom
140%
V dc
max
units
3000
4242
V ac
V dc
100
MW
FCC part 15 class B, CE (EN55022, EN55024)
0.25
mA
max
units
yes
yes
IS
C
LPS power supply
min
max
±1
O
RoHS compliant
N
leakage current
nom
110%
parameter
EMI standard
nom
U
rated input current
ED
POWER SUPPLY
SERIES:
18 W MULTI-BLADE
ENVIRONMENTAL
parameter
min
°C
operating humidity
storage temperature
-10
70
°C
storage humidity
10
90
D
operating temperature
nom
phone 503.612.2300
date 03/2012
page 3 of 6
MECHANICAL DRAWING
input plug
(UL, UK, VDE, SAA)
74 L x 43.5 W x 34 H mm
tolerance: ±1 mm
D
IS
C
O
N
TI
N
U
case size
ED
POWER SUPPLY
SERIES:
18 W MULTI-BLADE
phone 503.612.2300
date 03/2012
page 4 of 6
POWER SUPPLY
SERIES:
18 W MULTI-BLADE
20 AWG
20 AWG
20 AWG
20 AWG
20 AWG
EMS120150
EMS150120
EMS180100
EMS200090
EMS240075
Cable Gauge
18 AWG
EMS050320
18 AWG
EMS060300
18 AWG
EMS070257
18 AWG
EMS090200
D
IS
C
O
Cable Length: refer to page 1
N
TI
N
U
ED
DC CORD
phone 503.612.2300
date 03/2012
page 5 of 6
POWER SUPPLY
SERIES:
18 W MULTI-BLADE
ED
OUTPUT PLUG OPTIONS
ø3.5 +0/-0.1
14±0.5
14±0.5
*Tip positive
P1
U
ø3.5 +0/-0.1
3.5 mm Phono Plug
P1R
C
C
Unit
2.1
9.5
mm
P6/P6R
5.5
2.5
9.5
mm
P7/P7R
3.5
9.5
mm
P8/P8R
3.8
1.35
9.5
mm
P9/P9R
3.8
1.05
9.5
mm
A
B
C
Unit
P10
5.5
2.1
9.5
mm
P11
5.5
2.5
9.5
mm
N
A
O
B
IS
C
Standard PXX
B
B
A
C
A
B
5.5
1.35
Right Angle PXR
Locking DC Plug
C
A
P5/P5R
TI
Standard PX
EIAJ Plugs
B
A
B
A
C
N
Standard DC Plug
EIAJ
A
B
C
D
Unit
P12/P12R
EIAJ-1
2.35
0.7
9.5
NA
mm
P13/P13R
EIAJ-2
4.0
1.7
9.5
5.0
mm
P14/P14R
EIAJ-3
4.75
1.7
9.5
5.0
mm
C
Right Angle PXXR
D
D
Stripped and Tinned
25±5
9±2
DC PLUG TYPE
ST
PXX X X
Stripped and Tinned
Plug Type
Plug Angle:
“Blank” = Standard
R = Right Angle
*Contact CUI for additional output plug options.
Plug Polarity:
“Blank” = N/A
P = Center Positive
N = Center Negative
phone 503.612.2300
date 03/2012
page 6 of 6
POWER SUPPLY
SERIES:
18 W MULTI-BLADE
ED
INDIVIDUAL PACKAGING
± 1 mm
O
PACKAGING
N
TI
N
U
tolerance
+7 / -0 mm
D
IS
C
tolerance
phone 503.612.2300
很抱歉,暂时无法提供与“EMS240075-P5P-SZ”相匹配的价格&库存,您可以联系我们找货
