MWP9018-D8-NC-BK
MWP9018-D8-NC-BK
    INVENTUSPOWER
    AC/DC DESKTOP ADAPTER 18V 90W
MWP9018-D8-NC-BK 数据手册
MWP90 series 90 Watt Medical Grade AC Adapter Features Electrical Specifications Power factor correction Wide range AC input Fully regulated output High efficiency Medical grade approval Also available in white 5 year warranty Input Voltage................................ 90 - 264 VAC Current................................ 2.0 Amp @ 90 VAC Frequency........................... 47 - 63 Hz Earth leakage current.......... Test Voltage Environmental Operating temperature.......... 0 C to 40 C Storage temperature............. -55 C to 85 C Weight = 1.40 lbs Meets FCC class B, CISPR 11 class B EMC per EN60601-1-2 EN61000-3-2 and EN61000-3-3 Safety UL2601-1 EN60601-1-2:2001 Polarity 1 DIN-8 V1 2 3 4 V1 Com V1 Single-fault 190 uA 330 uA Output Line regulation.................... TYP +/- 1% Load regulation................... TYP +/- 5% Set point.............................. +/- 3% at 60% load Hold up time........................ 20 ms min at full load, 115 VAC Transient response............. 500 ms for 50% to 100% load change Over voltage protection....... Built-in Over current protection....... Built-in Short circuit protection........ Pulsing mode, auto recovery Efficiency............................ 90% typical Ripple/noise (Vp-p)............... +/- 1% pk-pk (20 MHz bandwidth) EMI/EMC UR/cUR CE Marked Normal 132 VAC 60 Hz 100 uA 264 VAC 50 Hz 190 uA 5 6 Com V1 7 8 Com Com Input and Output Connections DIN-8 Input connector (P1) = IEC 60320 inlet plug Output connector (P2) = DIN-8 pin circular connector Output cable length = 6 ft 6 8 7 1 Model No. Voltage Power Current MWP9012-D8-NC-BK 12V 90W 7.5A MWP9015-D8-NC-BK 15V 90W 6.0A MWP9018-D8-NC-BK 18V 90W 5.0A MWP9024-D8-NC-BK 24V 90W 3.75A 3 4 2 5 Rev 0905 Elpac Power Supplies 1562 Reynolds Ave. Irvine, CA 92614 USA TEL +1 949-476-6070 www.elpac.com info@elpac.com
MWP9018-D8-NC-BK 价格&库存
很抱歉,暂时无法提供与“MWP9018-D8-NC-BK”相匹配的价格&库存,您可以联系我们找货
