MWP90 series
90 Watt Medical Grade AC Adapter
Features
Electrical Specifications
Power factor correction
Wide range AC input
Fully regulated output
High efficiency
Medical grade approval
Also available in white
5 year warranty
Input
Voltage................................ 90 - 264 VAC
Current................................ 2.0 Amp @ 90 VAC
Frequency........................... 47 - 63 Hz
Earth leakage current..........
Test Voltage
Environmental
Operating temperature.......... 0 C to 40 C
Storage temperature............. -55 C to 85 C
Weight = 1.40 lbs
Meets FCC class B, CISPR 11 class B
EMC per EN60601-1-2
EN61000-3-2 and EN61000-3-3
Safety
UL2601-1
EN60601-1-2:2001
Polarity
1
DIN-8
V1
2
3
4
V1 Com V1
Single-fault
190 uA
330 uA
Output
Line regulation.................... TYP +/- 1%
Load regulation................... TYP +/- 5%
Set point.............................. +/- 3% at 60% load
Hold up time........................ 20 ms min at full load, 115 VAC
Transient response............. 500 ms for 50% to 100% load change
Over voltage protection....... Built-in
Over current protection....... Built-in
Short circuit protection........ Pulsing mode, auto recovery
Efficiency............................ 90% typical
Ripple/noise (Vp-p)............... +/- 1% pk-pk (20 MHz bandwidth)
EMI/EMC
UR/cUR
CE Marked
Normal
132 VAC 60 Hz 100 uA
264 VAC 50 Hz 190 uA
5
6
Com
V1
7
8
Com Com
Input and Output Connections
DIN-8
Input connector (P1) = IEC 60320 inlet plug
Output connector (P2) = DIN-8 pin
circular connector
Output cable length = 6 ft
6
8
7
1
Model No.
Voltage Power Current
MWP9012-D8-NC-BK
12V
90W
7.5A
MWP9015-D8-NC-BK
15V
90W
6.0A
MWP9018-D8-NC-BK
18V
90W
5.0A
MWP9024-D8-NC-BK
24V
90W
3.75A
3
4 2 5
Rev 0905
Elpac Power Supplies 1562 Reynolds Ave. Irvine, CA 92614 USA TEL +1 949-476-6070 www.elpac.com info@elpac.com
很抱歉,暂时无法提供与“MWP9024-D8-NC-BK”相匹配的价格&库存,您可以联系我们找货
