MW116KA1251F01
MW116KA1251F01
    SLPOWER
    AC/DCDESKTOPADAPTER12V80W
MW116KA1251F01 数据手册
MW116 MEDICAL 60-90 WATT SERIES #3 Connector pictured MW116 SWITCH-MODE P O W E R S U P P LY MW116 Ault Part No. Voltage DC Max Amps Max Watts • 100-240 VAC Universal Input MW116XA05XX_01 5V 12.0 60.0 • Desktop Style MW116XA06XX_01 6V 10.0 60.0 • Single Output to 90W MW116XA09XX_01 9V 7.80 70.0 • Regulated Output With Low Ripple MW116XA12XX_01 12V 6.67 80.0 • Meets Medical Safety Agency Requirements MW116XA14XX_01 13.5V 6.15 83.0 • Complies With EMI/RFI Regulations MW116XA15XX_01 15V 6.00 90.0 CE Compliant MW116XA16XX_01 16V 5.60 90.0 • MW116XA18XX_01 18V 5.00 90.0 • Impact Resistant Polycarbonate Enclosure MW116XA24XX_01 24V 3.75 90.0 • Private Label Marking Available MW116XA48XX_01 48V 1.87 90.0 • 3 Year Warranty • Modified and Custom Designs Also Available Ault Part No. Key MW116 X A 05 XX __ 01 Product Family Name Design Revision Changes Voltage DC Connector #51 - Standard 16V and under; #3 Standard 18V and over Input Configuration/ Model Type (see pg. 2) Denotes standard or custom requirements Manufacturing Location (volume dependent) A U LT I N C O R P O R AT E D 7105 Northland Terrace | Minneapolis, Minnesota 55428 | USATEL (1) 763-592-1900 FAX (1) 763-592-1911 | E-MAIL info@aultinc.com | WEB www.aultinc.com © Copyright 2005 Ault Inc. MW116 MEDICAL 60-90 WATT SERIES Input Electrical Voltage 100-240 VAC -10%, +10% Topology Switching - Fixed frequency 100KHz Line Frequency 47 - 63 Hz Efficiency Up to 89% Current 2.0A max. at 90 VAC input EMI Complies with EMC Directives Protection Internal primary current fuse, Inrush limiting CE CE Compliant MTBF 100,000 Calculated Hours Minimum Power Factor Correction Complies with EN61000-3-2 and EN61000-3-3 Environmental Output Combined Line and Load Voltage Regulation ±1% excluding cord Ripple 1% V p-p max Transient Response 0.5 msec. for 50% load change typical Holdup Time 16 msec min. over entire input range Protection Foldback overcurrent protection Short circuit protection Cord and Connector 5V and 6V: 6 ft, 6 conductor, 18 AWG, Ault #51 connector. Pinout: Pins 1, 2, 3 = +V; 4, 5 and 6 = common. 9V, 12V, 13.5V, 15V, 16V: 6 ft, 4 conductor, 18 AWG, Ault #51 connector. Pinout: Pins 1,4=+V; 3,6=common. All with overmolded Ferrite core. 18V, 24V, 48V,: 6 ft, 2 conductor, 18 AWG with overmolded Ferrite core, Ault #3 connector, center positive. Operating Temperature 0º to 40º C with no derating Storage Temperature -30º to +85º C Relative Humidity 5% to 95% non-condensing Altitude 0-10,000 feet Cooling Convectional - non vented case Mechanical Case and Dimensions 5.08L x 3.05W x 1.67H (in) 129L x 77W x 40H (mm) Case Material 94V0 polycarbonate; black is standard color; other colors available - extra charges may apply Weight 13 ounces, 370 grams (excluding cord) Safety Approvals Agency Listings TUV EN60601-1; cURus 2601; Australian, Japanese certification available - extra fees apply Input Configuration IEC320 w/ground C14 (F) Connector IEC320 w/o ground C18 (Q) In case IEC320 type: F=Class I C14 inlet Q=Class II C18 inlet Specify the Input Configuration Code in your order. A U LT I N C O R P O R AT E D 7105 Northland Terrace | Minneapolis, Minnesota 55428 | USATEL (1) 763-592-1900 FAX (1) 763-592-1911 | E-MAIL info@aultinc.com | WEB www.aultinc.com © Copyright 2005 Ault Inc.
MW116KA1251F01 价格&库存
很抱歉,暂时无法提供与“MW116KA1251F01”相匹配的价格&库存,您可以联系我们找货
