MW160RA1203F01
MW160RA1203F01
    SLPOWER
    AC/DCDESKTOPADAPTER12V42W
MW160RA1203F01 数据手册
MW160 MEDICAL 15-48 WATT SERIES MW160 SWITCH-MODE P O W E R S U P P LY MW160 Ault Part No. Voltage DC Max Amps Max Watts • 100-240 VAC Universal Input MW160XA0303F01 3V 5.00 15.0 • Desktop Style MW160XA0503F01 5V 5.00 25.0 • Single Output Up to 48W MW160XA0703F01 7V 5.00 35.0 • Regulated Output With Low Ripple MW160XA0903F01 9V 4.60 42.0 • Meets Medical Safety Agency Requirements MW160XA1203F01 12V 3.50 42.0 • Complies With EMI/RFI Regulations MW160XA1503F01 15V 3.00 45.0 CE Compliant MW160XA1603F01 16V 2.80 45.0 • MW160XA1803F01 18V 2.50 45.0 • Impact Resistant Polycarbonate Enclosure MW160XA2403F01 24V 2.00 48.0 • Private Label Marking Available • 3 Year Warranty • Modified and Custom Designs Also Available Ault AultPart PartNo. No.Key Key MW160 X Product Family Name A Manufacturing Design Location Revision (volume Changes dependent) A U LT I N C O R P O R AT E D 7105 Northland Terrace | Minneapolis, Minnesota 55428 | USATEL (1) 763-592-1900 FAX (1) 763-592-1911 | E-MAIL info@aultinc.com | WEB www.aultinc.com © Copyright 2002 Ault Inc. 05 03 __ 01 Voltage DC Connector Input Configuration/ Model Type (see pg. 2) Denotes standard or custom requirements MW160 MEDICAL 15-48 WATT SERIES Input Electrical Voltage 100-240 VAC +/-10% Topology Switching-fixed frequency flyback Line Frequency 47 - 63 Hz EMI Complies with EMC Directives Current 1.2 A max at 90VAC input MTBF 100,000 Calculated Hours Protection Internal primary current fuse, Inrush limiting Environmental Output Combined Line, Load and Cross Regulation +/-1% (excluding cord) Ripple 1% Vp-p max for output current of > 0.175A Transient Response 0.5msec. for 50% load change typical Holdup Time 18 msec min @ 120VAC Protection Overcurrent protection Short circuit Protection Cord and Connector (3V, 5V, and 7V model with 3.2 ft. cord, other models with 6 ft. cord) 2 conductor, 18 AWG, Ault #3 connector. Requires overmolded ferrite core. Other connectors are also available Operating Temperature 0º to 40º C with no derating Storage Temperature -30º to +85º C Relative Humidity 5% to 95% non-condensing Altitude 0-10,000 feet Cooling Convectional - non vented case Mechanical Case and Dimensions 4.20L x 2.60W x 1.46H (in) 107L x 66W x 37H (mm) Case Material 94V0 polycarbonate; black is standard color; other colors available - extra charges may apply Weight Max. 10 ounces, 285 grams (excluding cord) Safety Approvals Agency Listings TUV EN60601-1, cURus 2601, Austrailian, Japanese certification available – extra fees apply Input Configuration Connector IEC320 w/ground C14 (F) In Case IEC320 type with ground Pinout Code Center contact: positive Description Switchcraft 760 plug or equivalent Suggested Mating Switchcraft 712A jack or equivalent Other Connectors are available by special order A U LT I N C O R P O R AT E D 7105 Northland Terrace | Minneapolis, Minnesota 55428 | USATEL (1) 763-592-1900 FAX (1) 763-592-1911 | E-MAIL info@aultinc.com | WEB www.aultinc.com © Copyright 2002 Ault Inc.
MW160RA1203F01
PDF文档中包含了以下信息:
1. 物料型号:型号为STM32F103C8T6。
2. 器件简介:STM32F103C8T6是一款基于ARM Cortex-M3内核的32位微控制器,具有多种外设和接口。
3. 引脚分配:该芯片有48个引脚,包括电源、地、I/O、复位等。
4. 参数特性:工作电压范围为2.0V至3.6V,最大工作频率为72MHz。
5. 功能详解:包括GPIO、ADC、DAC、定时器、通信接口等。
6. 应用信息:适用于工业控制、消费电子、医疗设备等领域。
7. 封装信息:采用LQFP-48封装。
MW160RA1203F01 价格&库存
很抱歉,暂时无法提供与“MW160RA1203F01”相匹配的价格&库存,您可以联系我们找货
