PW122RA2403F01
PW122RA2403F01
    SLPOWER
    AC/DCDESKTOPADAPTER24V120W
PW122RA2403F01 数据手册
PW122 ITE 120 WATT SERIES PW122 SWITCH-MODE P O W E R S U P P LY PW122 Ault Part No. Voltage DC Max Amps Max Watts Ripple p-p Max • 100-240 VAC Universal Input PW122XA12XXF01 12V 10.00 120.0 120mV • Desktop Style PW122XA24XXF01 24V 5.00 120.0 240mV • Single Output to 120W PW122XA48XXF01 48V 2.50 120.0 480mV • Regulated Output With Low Ripple • Meets Safety Agency Requirements • Complies With EMI/RFI Regulations Ault AultPart PartNo. No.Key Key • CE Compliant PW122 X A 05 XX __ 01 Product Family Name Design Revision Changes Voltage DC Connector #51 - Standard 12V; #3 Standard 24V and 48V Input Configuration/ Model Type (see pg. 2) Standard (no modifications, special artwork or special packaging) • Impact Resistant Polycarbonate Enclosure • Private Label Marking Available • 3 Year Warranty • Modified and Custom Designs Also Available Manufacturing Location (volume dependent) A U LT I N C O R P O R AT E D 7105 Northland Terrace | Minneapolis, Minnesota 55428 | USATEL (1) 763-592-1900 FAX (1) 763-592-1911 | E-MAIL info@aultinc.com | WEB www.aultinc.com © Copyright 2002 Ault Inc. PW122 ITE 120 WATT SERIES Input Electrical Rated Voltage 100-240 VAC Operating Voltage 90-264 VAC Line Frequency 47-63 Hz Current 2A max.at 90 VAC input Protection Internal primary current fuse Power Factor Correction Complies with EN61000-3-2 and EN61000-3-3 (active) Earth Ground Leakage Current Less than 750 uA Efficiency 86%Typical EMI Complies with EMC Directives CE CE Compliant MTBF Min. 100,000 Hours Environmental Output Combined Line and Load Voltage Regulation ±1% excluding cord Ripple see table Transient Response 0.5 msec. for 50% load change typical Holdup Time 16.7 msec min.over entire input range Protection Overcurrent protection, Short circuit Protection Cord and Connector 12V: 6 ft, 4 conductor, 18 AWG, Ault #51 connector, Pinout: Pins 1-4=+V; 3, 6=common with overmolded Ferrite core. 24V & 48V: 5 ft, 2 conductor, 18 AWG, with overmolded Ferrite core, Ault #3 Connector, center positive. Operating Temperature 0º to 40º C with no derating Storage Temperature -30º to +85º C Relative Humidity 5% to 95% non-condensing Altitude 0-10,000 feet Cooling Convectional - non vented case Mechanical Case and Dimensions 9.0L x 2.9W x 2.0H (in) 229L x 74W x 51H (mm) Case Material 94V0 polycarbonate; black is standard color; other colors available - extra charges may apply Weight 24 ounces, 684 grams (excluding cord) Safety Approvals Agency Listings cULus60950, TUV/IEC EN60950, Australian, Japanese certification available - extra fees apply Input Configuration Connector IEC320 w/ground C14 (F) A U LT I N C O R P O R AT E D 7105 Northland Terrace | Minneapolis, Minnesota 55428 | USATEL (1) 763-592-1900 FAX (1) 763-592-1911 | E-MAIL info@aultinc.com | WEB www.aultinc.com © Copyright 2002 Ault Inc.
PW122RA2403F01 价格&库存
很抱歉,暂时无法提供与“PW122RA2403F01”相匹配的价格&库存,您可以联系我们找货
