date 09/2010
page 1 of 6
a division of CUI INC
SERIES:
DESCRIPTION:
6 W MULTI-BLADE
SWITCHING POWER SUPPLY
FEATURES
•universal AC input
•regulated output voltage
•interchangeable input blades
•short circuit, over load protection
•meets EISA / efficiency level IV regulations
•custom designs available
MODEL
output voltage
output current
ue
d
RoHS
output wattage
ripple*
max
(W)
max.
(mVp-p)
6
100
IV
1830 +150/-0
1
6
100
IV
1830 +150/-0
0.66
6
100
IV
1830 +150/-0
0.5
6
100
IV
1830 +150/-0
min
(A)
max
(A)
EMS050120
5
EMS060100
6
EMS090066
9
EMS120050
12
EMS150040
15
EMS180033
18
EMS240025
24
nt
in
nominal
(V dc)
cord length
(mm)
0.4
6
150
IV
1830 +150/-0
0.33
6
180
IV
1830 +150/-0
0.25
6
240
IV
1830 +150/-0
co
efficiency level
D
is
*at full load, 100 ~ 240 V ac input, measured at 20MHz bandwidth with a 10 uF electrolytic cap and a 0.1 uF ceramic cap on the output
PART NUMBER KEY
EMS050120 - PXXXX - SZ - CXX
Base Number
Reserved for custom
configurations
example of 5 V dc, 1.2 A
DC Plug type:
see output plug options
on page 5
20050 SW 112th Ave. Tualatin, Oregon 97062
Factory
Designation
phone 503.612.2300
fax 503.612.2382 www.v-infinity.com
date 09/2010
page 2 of 6
SERIES:
DESCRIPTION:
6 W MULTI-BLADE
INPUT
parameter
max
units
rated input voltage
conditions/description
min
100
nom
240
V ac
input voltage range
90
264
V ac
rated frequency
50
60
Hz
frequency range
47
rated input current
63
Hz
0.3
A
115 V ac, full load, cold start, 25°C
230 V ac, full load, cold start, 25°C
15
30
A
A
no load power consumption
0.3
W
max
units
ue
d
inrush current
OUTPUT
parameter
min
line regulation
load regulation
output shut down
short circuit protection
output shut down and auto-restart
HI-POT
input to output at 10 mA for 1 second
insulation resistance
input to output at 500 V dc
safety approvals
UL/cUL, CB (IEC60950-1), CE (GS/TUV EN60950-1)
EMI standard
co
parameter
is
nt
SAFETY & EMI
in
over voltage protection
±1
±5
140%
min
nom
200%
V dc
max
units
3000
4242
V ac
V ac
100
M
FCC part 15 class B, CE (EN55022, EN55024)
0.25
mA
max
units
yes
D
leakage current
RoHS compliant
nom
ENVIRONMENTAL
parameter
min
operating temperature
nom
°C
operating humidity
storage temperature
-10
70
°C
storage humidity
10
90
phone 503.612.2300
date 09/2010
page 3 of 6
SERIES:
DESCRIPTION:
6 W MULTI-BLADE
MECHANICAL DRAWING
interchangeable pin
(UL, UK, VDE, SAA)
case size
64 L x 40.5 W x 30 H mm
tolerance: ±1 mm
D
is
co
nt
in
ue
d
input plug
phone 503.612.2300
phone 503.612.2300
22 AWG
22 AWG
22 AWG
ue
d
DESCRIPTION:
EMS150040
EMS180033
EPS240025
Cable Gauge
20 AWG
EMS050120
20 AWG
EMS060100
22 AWG
EMS090066
22 AWG
EMS090166
22 AWG
EMS120050
6 W MULTI-BLADE
Black wire, white stripe: Positive
in
nt
SERIES:
co
is
D
Cable Length: refer to page 1
date 09/2010
page 4 of 6
DC CORD
date 09/2010
page 5 of 6
SERIES:
DESCRIPTION:
6 W MULTI-BLADE
OUTPUT PLUG OPTIONS
ˆˁˈʳʾ˃˂ˀ˃ˁ˄
˄ˇʳ̈́˃ˁˈ
˄ˇʳ̈́˃ˁˈ
*Tip positive
P1
P1R
Standard DC Plug
Right Angle PXR
nt
Locking DC Plug
Standard PXX
is
D
A
5.5
5.5
A
5.5
5.5
3.5
3.8
3.8
B
2.1
2.5
B
2.1
2.5
1.3
1.35
1.05
C
9.5
9.5
9.5
9.5
9.5
C
9.5
9.5
Unit
mm
mm
mm
mm
mm
Unit
mm
mm
EIAJ
A
B
P12/P12R EIAJ-1 2.35 0.7
P13/P13R EIAJ-2 4.0 1.7
P14/P14R EIAJ-3 4.75 1.7
EIAJ Plugs
P10
P11
co
P5/P5R
P6/P6R
P7/P7R
P8/P8R
P9/P9R
in
Standard PX
ue
d
ˆˁˈʳʾ˃˂ˀ˃ˁ˄
3.5 mm Phono Plug
C
9.5
9.5
9.5
D
NA
5.0
5.0
Unit
mm
mm
mm
Right Angle PXXR
Stripped and Tinned
˅ˈ̈́ˈ
DC PLUG TYPE
ST
PXX X X
stripped and tinned
Plug type
Plug angle:
“blank” = standard
R = right angle
*Contact CUI for additional output plug options.
phone 503.612.2300
Plug polarity:
“blank” = N/A
P = center positive
N = center negative
date 09/2010
page 6 of 6
SERIES:
DESCRIPTION:
6 W MULTI-BLADE
INDIVIDUAL PACKAGING
± 1 mm
tolerance
+7 / -0 mm
D
is
PACKAGING
co
nt
in
ue
d
tolerance
phone 503.612.2300
很抱歉,暂时无法提供与“EMS050120-P5RP-SZ”相匹配的价格&库存,您可以联系我们找货
