WM1012-760
WM1012-760
    INVENTUSPOWER
    AC/DC WALL MOUNT ADAPTER 12V 10W
WM1012-760 数据手册
10 Watt AC Adapter 3.0" [76.2mm] Features Electrical specifications Level B EMI filter Fully regulated output High efficiency Weight = 0.35 lbs. 5 year warranty Input Voltage...........................100-120 VAC Current ...........................0.25 Amp @ 115 VAC Frequency ......................50-60 Hz Input connector ............. 2 pin NEMA 5/15 (no Ground pin) Output Hold up time ..................20ms minimum at full load, 115 VAC Over voltage protection..Built-in Line regulation...............TYP +/- 1% Load regulation ..............TYP +/- 5% Set point .........................+/- 3% at 60% load Transient response .........Recovery within 1% of nominal output within 2ms for 50% to 100% load change. Max excursion of 6% from set point Over current protection ..150% of maximum load Short circuit protection ..Pulsing mode, auto recovery Efficiency.......................75% minimum at full load and 115 VAC Ripple/noise (VP-P) ........+/- 1% (20 MHz bandwidth) Output connector ........... Barrel connector (5.5 x 2.5 x 9.5mm) Environmental Operating temperature ......0°C to 40°C Storage temperature ..........-55°C to 85°C EMI Meets FCC class B, CISPR 22 class B Safety UL/cUL UL-60950 Output Electrical Specifications Polarity: COM 1.14" [29mm] 1.63" [41.4mm] WM10 series +V Model No. Voltage Power Current WM1005-760 WM1012-760 WM1024-760 5V 12V 10W 10W 10W 2A 0.8A 24V 0.4A ELPAC Power Systems, 1562 Reynolds Ave, Irvine CA 92614 Phone (949) 476-6070 Fax (949) 476-6075 Toll free # (888) ELPAC-80 E-mail: sales@elpac.com or engr@elpac.com
WM1012-760 价格&库存
很抱歉,暂时无法提供与“WM1012-760”相匹配的价格&库存,您可以联系我们找货
