Additional Resources:
Product Page
date
08/21/2012
page
1 of 5
SERIES: EMSA 40W │ DESCRIPTION: AC-DC POWER SUPPLY
up to 40 W power
interchangeable AC blades
universal input (90~264 Vac)
single regulated output from 12~24 V
over voltage and short circuit protection
UL/cUL, GS, RCM, CCC, PSE safety approvals
level V efficiency
custom designs available
U
ED
FEATURES
output
voltage
output
current
(Vdc)
max
(A)
EMSA120300
12
EMSA200200
EMSA240167
24
ripple
and noise1
max
(W)
max
(mVp-p)
3.0
36
300
efficiency
level
V
2.0
40
300
V
1.67
40
300
V
1. At full load, 100 ~ 240 Vac input, 20 MHz bandwidth oscilloscope, each output terminated with 10 μF aluminum electrolytic and 0.1 μF ceramic capacitors.
O
PART NUMBER KEY
N
Notes:
output
power
TI
MODEL
N
RoHS
D
IS
C
EMSA120300 X - XX - SZ - CXX
Base Number
example of 12 Vdc, 3 A
DC Plug Type
Blades:
“blank” = North American, European, United Kingdom,
Australian, and China blades included
N = North American blade included
E = European blade included
B = United Kingdom blade included
A = Australian blade included
C = China blade included
K = No blades included
cui.com
Factory
Designation
Reserved for Custom
Configurations
Product Page
CUI Inc │ SERIES: EMSA 40W │ DESCRIPTION: AC-DC POWER SUPPLY
date 08/21/2012 │ page 2 of 5
INPUT
conditions/description
min
voltage
90
frequency
47
current
no load power consumption
OUTPUT
parameter
min
line regulation
PROTECTIONS
over voltage protection
output voltage clamped by internal protection zener
output shut down and auto restart
Vac
63
TI
parameter
units
264
Hz
typ
1.0
A RMS
0.3
W
max
units
±1
±5
N
parameter
SAFETY & COMPLIANCE
max
U
load regulation
typ
ED
parameter
min
isolation voltage
input to output at 10 mA for 1 minute
isolation resistance
input to output at 500 V dc
typ
max
units
3,000
4,242
Vac
Vdc
100
MΩ
UL 60950-1, EN 60950-1/IEC 60950-1, RCM, CCC, PSE
EMI/EMC
FCC part 15B, CISPR 22 Class B, EN 61204-3, EN 55022 Class B, EN 55024, EN 61000-3-(2, 3), IEC
6100-3-(2, 3), IEC 6100-4-(2, 3, 4, 5, 6, 11), CE
leakage current
yes
O
RoHS compliant
N
safety approvals
0.25
mA
max
units
ENVIRONMENTAL
parameter
operating temperature
min
typ
°C
-10
70
°C
operating humidity
storage humidity
10
90
D
IS
C
storage temperature
cui.com
Product Page
date 08/21/2012 │ page 3 of 5
MECHANICAL
parameter
dimensions
2.913 x 1.713 x 1.390 (74 x 43.5 x 35.3 mm)
min
input plug
multi-blade (US, UK, Europe, Australia, China)
max
units
ED
inch
MECHANICAL DRAWING
units: mm
typ
43.5±1.0
U
35.3±1.0
O
N
TI
N
74±1.0
EMS-US
IS
C
DC CORD
EMS-UK
EMS-EU
10±3
D
cord length
Black wire, white stripe: Positive
EMS-CC
EMS-AU
2.8~4.0mm
50±10
S&T
48B
70±10
Ferrite core with one turns wire
12x20x7.3(018)
cui.com
MODEL NO.
CABLE GAUGE
CORD LENGTH
EMSA120300
18 AWG
1530 ± 100
EMSA200200
20 AWG
1530 ± 100
EMSA240167
20 AWG
1530 ± 100
Product Page
date 08/21/2012 │ page 4 of 5
OUTPUT PLUG OPTIONS
ED
14±0.5
14±0.5
*Tip positive
P1
P1R
C
C
Unit
9.5
mm
N
B
2.1
P6/P6R
5.5
2.5
9.5
mm
P7/P7R
3.5
1.35
9.5
mm
P8/P8R
3.8
1.35
9.5
mm
P9/P9R
3.8
1.05
9.5
mm
A
B
C
Unit
P10
5.5
2.1
9.5
mm
P11
5.5
2.5
9.5
mm
B
A
O
N
B
A
C
C
B
Right Angle PXR
Locking DC Plug
EIAJ Plugs
A
5.5
TI
Standard PX
P5/P5R
Standard PXX
B
A
B
A
C
A
U
Standard DC Plug
IS
C
D
ø3.5 +0/-0.1
ø3.5 +0/-0.1
3.5 mm Phono Plug
EIAJ
A
B
C
D
Unit
P12/P12R
EIAJ-1
2.35
0.7
9.5
NA
mm
P13/P13R
EIAJ-2
4.0
1.7
9.5
5.0
mm
P14/P14R
EIAJ-3
4.75
1.7
9.5
5.0
mm
C
Right Angle PXXR
D
Stripped and Tinned
25±5
9±2
DC PLUG TYPE
ST
Stripped and Tinned
PXX X X
Plug Type
Plug Angle:
“Blank” = Standard
R = Right Angle
Plug Polarity:
“Blank” = N/A
P = Center Positive
N = Center Negative
*Contact CUI for additional output plug options.
cui.com
Product Page
date 08/21/2012 │ page 5 of 5
REVISION HISTORY
description
date
06/21/2010
1.0
initial release
1.01
new template applied
1.02
PSE safety approval added
1.03
updated P7/P7R B dimension
1.04
ED
rev.
08/08/2011
09/07/2011
03/23/2012
V-Infinity branding removed, safety and EMI/EMC data updated
08/21/2012
D
IS
C
O
N
TI
N
U
The revision history provided is for informational purposes only and is believed to be accurate.
Headquarters
20050 SW 112th Ave.
Tualatin, OR 97062
800.275.4899
Fax 503.612.2383
cui.com
techsupport@cui.com
This device complies with part 15 of the FCC Rules. Operation is subject to the following two conditions:
(1) This device may not cause harmful interference, and
(2) this device must accept any interference received, including interference that may cause undesired operation.
CUI offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI reserves the right to make changes to the product at any time without notice. Information provided by CUI is believed to be accurate and reliable. However, no responsibility is
assumed by CUI for its use, nor for any infringements of patents or other rights of third parties which may result from its use.
CUI products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical
component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to
affect its safety or effectiveness.
很抱歉,暂时无法提供与“EMSA240167K-P5P-SZ”相匹配的价格&库存,您可以联系我们找货
