CENB1040A0503F01
CENB1040A0503F01
    SLPOWER
    PS EXT 25W @ 5A DESKPLUG E-STAR
CENB1040A0503F01 数据手册
CENB1040 Universal 40 Watt Series ITE Switch-Mode Power Supply 3 Year Warranty •100-240VAC Universal Input •Meets EISA2007, CEC Efficiency Level V, EU (EC) No 278/2009 Phase II •Desktop Style •Limited Power Source •Certified to UL/EN60950-1, 2nd Edition •5V to 48V Single Output Models, up to 40W •Modified and Custom Designs Available •Regulated Output with Low Ripple •No Load Power Consumption 100,000 hours (calculated) 18 ms min. @ 115Vac, 60 ms @ 230 Vac Overload Protection Hiccup Mode Short Circuit Protection Hiccup Mode Topology Safety Standards Switching – Fixed Frequency Flyback EN/IEC/CSA/UL60950-1, 2nd Edition, LPS EMC Dielectric Withstand Operating Temperature See chart below Input-Output: 4,242Vdc Input-GND: 1,500 Vac, Output-GND: 500Vdc 0° to 40°C, no derating Storage Temperature Relative Humidity -30 to +85°C 5% to 95%, non-condensing Altitude Output Cable Output Connector 0 to 10,000 ft #18AWG (UL1185), 1,500mm, 2 conductor 2.5mm barrel type (Ault #3), center positive (+) EMC Specifications Conducted Emissions Radiated Emissions Line Frequency Harmonics Voltage Fluctuations/Flicker Static Discharge Immunity Radiated RF Immunity EFT/Burst Immunity Line Surge Immunity Conducted RF Immunity Power Frequency Magnetic Field Immunity Voltage Dip Immunity EN55022 Class B, FCC Part 15, Class B. EN55022 Class B, FCC Part 15, Class B. EN61000-3-2, Class A EN61000-3-3 EN61000-4-2, 6kV Contact Discharge, 8kV air discharge EN61000-4-3, 3V/m. EN61000-4-4, 2kV/5kHz. EN61000-4-5, 1kV differential, 2kV common-mode EN61000-4-6, 3Vrms EN61000-4-8, 3A/m EN61000-4-11, Criteria B ______________________________________________________________________________________________________________________________ 1 of 2 SL Power Electronics Corp • 6050 King Drive Ventura, CA 93003 • Phone 805.486.4565 • Fax 858.712.2040 • Email: info@slpower.com • www.slpower.com CENB1040 Universal 40 Watt Series ITE Switch Mode Power Supply Model Number 3 Year Warranty Volts (V) Output Current (max) Max Watts Ripple (Vp-p max) CENB1040A0503F01 5V 5.00 A 25.0 W 50mV CENB1040A0903F01 9V 4.00 A 36.0 W 90mV CENB1040A1203F01 12 V 3.40 A 40.8 W 120mV CENB1040A1503F01 15 V 2.76 A 40.5 W 150mV CENB1040A1803F01 18 V 2.20 A 39.6 W 180mV CENB1040A2403F01 24 V 1.70 A 40.8 W 240mV CENB1040A4803F01 48 V 0.83 A 39.8 W 480mV Notes: Part numbers above include #3 output connector and IEC320 C14 grounded input receptacle. See below for other options. Model Number Key CENB 1 040 A VV 03 F 01 Model Input Connector: Output Connector: Output Voltage: Model Output Pow er: # of Outputs Product Fam ily: Input Receptacle Options IEC320 - C14 IEC320 - C18 Class I Class II Grounded (F) Ungro unde d ( Q ) "01" = Standard. "02" and higher indicates a m odified m odel. "F" = IEC320 C14 grounded, Other options available, see next page. "03" = 2.5m m Barrel Type Connector. Other options available, contact factory. "05" = 5Vdc, "12" = 12Vdc, "24" = 24Vdc, etc. "A" = Original Configuration "040" = 40 Watts "1" = Single Output "C" = Com m ercial/ITE/Industrial, "E" = External, "NB" = Model Series Designator Output Connector IEC320 - C8 Class II "Shaver" (N) Outline Drawing 60 31.5 102 1200 +/-25 Dimensions are in mm Data Sheet © 2014 SL Power Electronics Corp. The information and specifications contained herein are believed to be correct at the time of publication. Rev. 10-30-2014 However, SL Power accepts no responsibility for consequences arising from reproduction errors or inaccuracies. Specifications are subject to change without notice. ______________________________________________________________________________________________________________________________ 2 of 2 SL Power Electronics Corp • 6050 King Drive Ventura, CA 93003 • Phone 805.486.4565 • Fax 858.712.2040 • Email: info@slpower.com • www.slpower.com
CENB1040A0503F01 价格&库存
很抱歉,暂时无法提供与“CENB1040A0503F01”相匹配的价格&库存,您可以联系我们找货
