FWA020012A-10B
FWA020012A-10B
    INVENTUSPOWER
    AC/DC DESKTOP ADAPTER 12V 20W
FWA020012A-10B 数据手册
20 Watt Power Supply | Elpac FWA020 ITE Class I Power Supply Page 1 of 3 FWA020 Class I 20 Watt ITE Desktop Power Supply • High Efficiency • Fully Regulated DC Output • 5-Year Limited Warranty • Hold-up Time>18ms at full load • Safety Approval-EN60950-1 Class I • Level V, EuP Directive Compliant • LED Indicator Overview Over the later part of 2015, we will be changing the way we sell ITE power supplies thru distribution to no longer include AC cords with the units. During this time of transition you find both versions available for sale. They can be distinguished by the part number, parts ending in -10B will include a cord in the box, parts ending in -10A will not include a cord. If you distributor has not already made a recommendation on a cord, please do not hesitate to ask us for assistance. Elpac Part Number Output Voltage Output Current Peak Current Total Regulation Typical Efficiency FWA020005A-10B 5.0V 4.0A 4.8A +/-5% 80% FWA020005A-10A 5.0V 4.0A 4.8A +/-5% 80% FWA020009A-10B 9.0V 2.22A 2.6A +/-5% 83% FWA020009A-10A 9.0V 2.22A 2.6A +/-5% 83% FWA020012A-10B 12.0V 1.67A 2.0A +/-5% 84% FWA020012A-10A 12.0V 1.67A 2.0A +/-5% 84% FWA020024A-10B 24.0V 0.84A 1,0A +/-5% 86% FWA020024A-10A 24.0V 0.84A 1,0A +/-5% 86% Input Input Voltage 85-264VAC; 100-240VAC Nominal Input Frequency 47-63Hz Input Current
FWA020012A-10B
物料型号:FWA020005A-10B, FWA020005A-10A, FWA020009A-108, FWA020009A-10A, FWA020012A-10B, FWA020012A-10A, FWA020024A-10B, FWA020024A-10A
器件简介:Elpac FWA020是一款20瓦的ITE桌面电源供应器,具有高效率、全调节直流输出、5年有限保修、18毫秒的保持时间、符合EN60950-1 Class I安全认证和欧盟第五级能源使用效率指令。
引脚分配:输出端子配置为中心正电压,外围为返回。
参数特性: - 输入电压:85-264VAC;典型值100-240VAC - 输入频率:47-63Hz - 输入电流:<0.5Arms - 启动延迟:<1.5秒 - 保持时间:>18ms - 纹波和噪声:<1%峰-峰值 - 过压保护:112-135% - 过温保护:主动-可恢复,被动-不可恢复 - 过流保护:108%-180% - 短路保护:关闭,自动重启(hiccup模式)
功能详解:电源供应器提供全调节直流输出,具有高效率和多种保护功能,如过压、过温和短路保护。
应用信息:适用于ITE设备,如桌面计算机和其他需要稳定电源的设备。
封装信息:尺寸为3.45(87.7mm)x2.04(5.18mm)x1.30(33.0mm),重量分别为5V 0.4磅(0.2Kg)和24V 0.3磅(0.16Kg)。
FWA020012A-10B 价格&库存
很抱歉,暂时无法提供与“FWA020012A-10B”相匹配的价格&库存,您可以联系我们找货
