EMSA050120-P6P-SZ
EMSA050120-P6P-SZ
    CUIDEVICES
    AC/DCWALLMOUNTADAPTER5V6W
EMSA050120-P6P-SZ 数据手册
Additional Resources: Product Page date 08/21/2012 page 1 of 5 SERIES: EMSA 6W │ DESCRIPTION: AC-DC POWER SUPPLY up to 6 W power interchangeable AC blades universal input (90~264 Vac) single regulated output from 5~15 V over voltage and short circuit protections UL/cUL, GS, RCM, CCC, PSE safety approvals level V efficiency custom designs available U • • • • • • • • ED FEATURES EMSA050120 output voltage output current output power ripple and noise1 (Vdc) max (A) max (W) max (mVp-p) 1.2 6 150 V 0.67 6 150 V 0.50 6 120 V 0.40 6 150 V 5 9 EMSA120050 12 EMSA150040 15 Notes: N EMSA090067 TI MODEL N RoHS efficiency level 1. At full load, 100 ~ 240 Vac input, 20 MHz bandwidth oscilloscope, each output terminated with 10 μF aluminum electrolytic and 0.1 μF ceramic capacitors. O PART NUMBER KEY D IS C EMSA120050 X - XX - SZ - CXX Base Number example of 12 Vdc, 0.5 A DC Plug Type Blades: “blank” = North American, European, United Kingdom, Australian, and China blades included N = North American blade included E = European blade included B = United Kingdom blade included A = Australian blade included C = China blade included K = No blades included cui.com Factory Designation Reserved for Custom Configurations Additional Resources: Product Page CUI Inc │ SERIES: EMSA 6W │ DESCRIPTION: AC-DC POWER SUPPLY date 08/21/2012 │ page 2 of 5 INPUT parameter conditions/description min 90 frequency 47 current 9 V output at 115 V ac, cold start 9 V output at 230 V ac, cold start all other outputs: 115 V ac, cold start all other outputs: 230 V ac, cold start inrush current no load power consumption conditions/description min line regulation PROTECTIONS parameter conditions/description protect through primary circuit IC short circuit protection output shut down and auto restart TI over voltage protection SAFETY & COMPLIANCE parameter conditions/description min input to output at 10 mA for 1 minute isolation resistance input to output at 500 V dc N isolation voltage UL 60950-1, EN 60950-1/IEC 60950-1, RCM, CCC, PSE EMI/EMC FCC Part 15B, EN 55022B, CE leakage current 9 V output all other outputs O safety approvals RoHS compliant units 264 Vac Hz typ 0.3 A RMS 15 30 30 60 A A A A 0.3 W max units ±3 % ±5 % N load regulation max 63 U OUTPUT parameter typ ED voltage typ max units 3,000 4,242 Vac Vdc 100 MΩ 0.25 0.1 mA mA max units yes ENVIRONMENTAL conditions/description min IS C parameter 0 40 °C storage temperature -10 70 °C operating humidity 20 80 % storage humidity 10 90 % D operating temperature typ cui.com Additional Resources: Product Page CUI Inc │ SERIES: EMSA 6W │ DESCRIPTION: AC-DC POWER SUPPLY date 08/21/2012 │ page 3 of 5 MECHANICAL conditions/description dimensions 2.520 x 1.594 x 1.181 (64 x 40.5 x 30 mm) min input plug multi-blade (US, UK, Europe, Australia, China) typ max units inch ED parameter MECHANICAL DRAWING units: mm 30±1.0 U 40.5±1 62±1.0 O N TI N 64±1.0 IS C EMS-US EMS-UK EMS-EU EMS-AU EMS-CC D DC CORD 21±3 cord length 100±20 2.8~4.0mm 100±20 S&T 35B 70±10 Black wire, white stripe: Positive cui.com MODEL NO. CABLE GAUGE CORD LENGTH EMSA050120 20 AWG 1530 ± 100 EMSA090067 22 AWG 1530 ± 100 EMSA120050 22 AWG 1530 ± 100 EMSA150040 22 AWG 1530 ± 100 Additional Resources: Product Page CUI Inc │ SERIES: EMSA 6W │ DESCRIPTION: AC-DC POWER SUPPLY date 08/21/2012 │ page 4 of 5 OUTPUT PLUG OPTIONS 14±0.5 ED ø3.5 +0/-0.1 ø3.5 +0/-0.1 3.5 mm Phono Plug 14±0.5 *Tip positive P1 P1R C A B C Unit 5.5 2.1 9.5 mm P6/P6R 5.5 2.5 9.5 mm P7/P7R 3.5 1.35 9.5 mm P8/P8R 3.8 1.35 9.5 mm P9/P9R 3.8 1.05 9.5 mm N O B N B A C C B Right Angle PXR Locking DC Plug EIAJ Plugs A TI Standard PX P5/P5R B A B A C A U Standard DC Plug A B C Unit P10 5.5 2.1 9.5 mm P11 5.5 2.5 9.5 mm EIAJ A P12/P12R EIAJ-1 2.35 0.7 9.5 NA mm P13/P13R EIAJ-2 4.0 1.7 9.5 5.0 mm P14/P14R EIAJ-3 4.75 1.7 9.5 5.0 mm IS C C Standard PXX Right Angle PXXR D Stripped and Tinned 25±5 9±2 D DC PLUG TYPE ST Stripped and Tinned PXX X X Plug Type Plug Angle: “Blank” = Standard R = Right Angle Plug Polarity: “Blank” = N/A P = Center Positive N = Center Negative *Contact CUI for additional output plug options. cui.com B C D Unit Additional Resources: Product Page CUI Inc │ SERIES: EMSA 6W │ DESCRIPTION: AC-DC POWER SUPPLY date 08/21/2012 │ page 5 of 5 REVISION HISTORY description date 07/28/2010 1.0 initial release 1.01 new template applied 1.02 PSE safety approval added 1.03 updated P7/P7R B dimension 1.04 ED rev. 08/08/2011 09/07/2011 03/23/2012 V-Infinity branding removed, safety data updated 08/21/2012 D IS C O N TI N U The revision history provided is for informational purposes only and is believed to be accurate. Headquarters 20050 SW 112th Ave. Tualatin, OR 97062 800.275.4899 Fax 503.612.2383 cui.com techsupport@cui.com This device complies with part 15 of the FCC Rules. Operation is subject to the following two conditions: (1) This device may not cause harmful interference, and (2) this device must accept any interference received, including interference that may cause undesired operation. CUI offers a one (1) year limited warranty. Complete warranty information is listed on our website. CUI reserves the right to make changes to the product at any time without notice. Information provided by CUI is believed to be accurate and reliable. However, no responsibility is assumed by CUI for its use, nor for any infringements of patents or other rights of third parties which may result from its use. CUI products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness.
EMSA050120-P6P-SZ 价格&库存
很抱歉,暂时无法提供与“EMSA050120-P6P-SZ”相匹配的价格&库存,您可以联系我们找货
