EPSA120100UB-P6RP-EJ 数据手册
Additional Resources:
Product Page
date
08/21/2012
page
1 of 5
SERIES: 12 W WALL PLUG - UK BLADE │ DESCRIPTION: AC-DC POWER SUPPLY
up to 12 W power
universal input (90~264 Vac)
single regulated output from 5~12 V
over voltage, over current, and short circuit protections
TUV safety approvals
level V efficiency
custom designs available
U
ED
FEATURES
output
voltage
output
current
output
power
ripple
and noise1
(Vdc)
max
(A)
max
(W)
max
(mVp-p)
2.5
12
50
V
1
12
120
V
EPSA050250UB
5
EPSA120100UB
12
efficiency
level
1. At full load, 100 ~ 240 Vac input, 20 MHz bandwidth oscilloscope, each output terminated with 10 μF aluminum electrolytic and 0.1 μF ceramic capacitors.
O
PART NUMBER KEY
N
Notes:
TI
MODEL
N
RoHS
IS
C
EPSA050250UB - XX - EJ - CXX
Base Number
DC Plug Type
Factory
Designation
D
example of 5 Vdc, 2.5 A
cui.com
Reserved for Custom
Configurations
Product Page
CUI Inc │ SERIES: 12 W WALL PLUG - UK BLADE │ DESCRIPTION: AC-DC POWER SUPPLY
date 08/21/2012 │ page 2 of 5
INPUT
conditions/description
min
voltage
90
frequency
47
current
nom
max
units
264
Vac
63
Hz
ED
parameter
0.4
inrush current
at 115 Vac, full load, cold start
30
OUTPUT
parameter
min
line regulation
start-up
parameter
over voltage protection
output shut down
over current protection
output shut down and auto restart
SAFETY & COMPLIANCE
2
200
max
units
3,000
Vac
input to output at 10 mA for 2 seconds
isolation resistance
input to output at 500 Vdc
safety approvals
EN 60950-1, CE
EMI/EMC
EN 55022 Class B, AS/NZS CISPR 22 Class B, EN 61000-3-(2,3), IEC 61000-4-(2,3,4,5,6,8,11)
yes
O
MTBF
N
isolation voltage
RoHS compliant
nom
s
ms
parameter
leakage current
min
units
±5
10
TI
max
±5
N
at 110 Vac, 50 Hz, 80% max. load
PROTECTIONS
nom
U
load regulation
hold-up
A
10
MΩ
at full load, 25°C, Telcordia SR-332, Issue 2
0.25
mA
300,000
hours
ENVIRONMENTAL
min
max
units
°C
storage temperature
-25
85
°C
operating humidity
10
95
storage humidity
10
95
IS
C
parameter
D
operating temperature
cui.com
nom
Product Page
date 08/21/2012 │ page 3 of 5
MECHANICAL
dimensions
2.953 x 1.969 x 1.850 (75 x 50 x 47 mm)
min
input plug
fixed UK
max
units
inch
MECHANICAL DRAWING
units: mm[inch]
50.0 1.969
1.0
typ
N
U
47.0 1.850
1.0
ED
parameter
IS
C
DC CORD
O
N
TI
75.0 2.953
1.0
D
cord length
cui.com
MODEL NO.
CABLE GAUGE
CORD LENGTH
EPSA050250UB
18 AWG
1,500 mm ±30
EPSA120100UB
22 AWG
1,500 mm +50/-30
Product Page
date 08/21/2012 │ page 4 of 5
OUTPUT PLUG OPTIONS
14±0.5
ED
ø3.5 +0/-0.1
ø3.5 +0/-0.1
3.5 mm Phono Plug
14±0.5
*Tip positive
P1
P1R
C
A
B
C
Unit
2.1
9.5
mm
N
O
B
N
B
A
C
C
B
Right Angle PXR
Locking DC Plug
EIAJ Plugs
A
5.5
P6/P6R
5.5
2.5
9.5
mm
P7/P7R
3.5
1.35
9.5
mm
P8/P8R
3.8
1.35
9.5
mm
P9/P9R
3.8
1.05
9.5
mm
A
B
C
Unit
P10
5.5
2.1
9.5
mm
P11
5.5
2.5
9.5
mm
TI
Standard PX
P5/P5R
B
A
B
A
C
A
U
Standard DC Plug
EIAJ
A
B
C
D
Unit
P12/P12R
EIAJ-1
2.35
0.7
9.5
NA
mm
P13/P13R
EIAJ-2
4.0
1.7
9.5
5.0
mm
P14/P14R
EIAJ-3
4.75
1.7
9.5
5.0
mm
IS
C
C
Standard PXX
Right Angle PXXR
D
Stripped and Tinned
25±5
9±2
D
DC PLUG TYPE
ST
Stripped and Tinned
PXX X X
Plug Type
Plug Angle:
“Blank” = Standard
R = Right Angle
Plug Polarity:
“Blank” = N/A
P = Center Positive
N = Center Negative
*Contact CUI for additional output plug options.
cui.com
Product Page
date 08/21/2012 │ page 5 of 5
REVISION HISTORY
rev.
description
date
03/08/2010
initial release
updated output plug options
1.02
new template applied
1.03
V-Infinity branding removed, P7/P7R B dimension updated, safety and
EMI/EMC data updated
ED
1.0
1.01
11/11/2010
01/24/2012
08/21/2012
D
IS
C
O
N
TI
N
U
The revision history provided is for informational purposes only and is believed to be accurate.
Headquarters
20050 SW 112th Ave.
Tualatin, OR 97062
800.275.4899
Fax 503.612.2383
cui.com
techsupport@cui.com
CUI offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI reserves the right to make changes to the product at any time without notice. Information provided by CUI is believed to be accurate and reliable. However, no responsibility is
assumed by CUI for its use, nor for any infringements of patents or other rights of third parties which may result from its use.
CUI products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical
component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to
affect its safety or effectiveness.
EPSA120100UB-P6RP-EJ 价格&库存
很抱歉,暂时无法提供与“EPSA120100UB-P6RP-EJ”相匹配的价格&库存,您可以联系我们找货
