CENB1010A1249F01
CENB1010A1249F01
    SLPOWER
    12V 10W AC/DC External Desktop (Class I) Adapter Cord (Sold Separately) Input
CENB1010A1249F01 数据手册
CENB1010 Universal 10 Watt Series ITE Switch-Mode Power Supply 3 Year Warranty •100-240VAC Universal Input Range •Meets EISA2007, CEC Efficiency Level V, EU (EC) No 278/2009 Phase II •Desktop & Wall Plug Styles •5V to 48V Single Output Models, up to 12W •Modified and Custom Designs Available •Regulated Output with Low Ripple •Impact-Resistant Polycarbonate Enclosure •No load Power Consumption 250,000 hours (calculated) Hold-up Time 18 ms min. @ 115Vac, 60 ms min. @ 230 Vac Overload Protection Hiccup Mode Short Circuit Protection Topology Hiccup Mode Switching – Fixed Frequency Flyback EN/IEC/CSA/UL60950-1, 2nd Edition, LPS Safety Standards EMC, Radiated & Conducted See Chart below Dielectric Withstand Input-Output: 4,242Vdc, Input-Ground: 1,500 Vac, Output-Ground: 500 Vdc Operating Temperature 0° to 40°C, no derating (0 to 55°C for 5V model, see derating chart) Storage Temperature -30 to +85°C Relative Humidity 5% to 95%, non-condensing Altitude Output Cable Output Connector 0 to 10,000 ft #20AWG (UL2468), 1500mm, 2 conductor 2.5mm barrel type (Ault #3), center contact (+) Other options available, contact the factory for details EMC Specifications Conducted Emissions Radiated Emissions Line Frequency Harmonics Voltage Fluctuations/Flicker Static Discharge Immunity Radiated RF Immunity EFT/Burst Immunity Line Surge Immunity Conducted RF Immunity Power Frequency Magnetic Field Immunity Voltage Dip Immunity EN55022 Class B, FCC Part 15, Class B. EN55022 Class B, FCC Part 15, Class B. EN61000-3-2, Class A EN61000-3-3 EN61000-4-2, 6kV Contact Discharge, 8kV air discharge EN61000-4-3, 3V/m. EN61000-4-4, 2kV/5kHz. EN61000-4-5, 1kV differential, 2kV common-mode EN61000-4-6, 3Vrms EN61000-4-8, 3A/m EN61000-4-11, Criteria B ________________________________________________________________________________________________________________________________ 1 of 3 SL Power Electronics Corp • 6050 King Drive Ventura, CA 93003 • Phone 805.486.4565 • Fax 858.712.2040 • Email: info@slpower.com • www.slpower.com CENB1010 Universal 10 Watt Series ITE Switch-Mode Power Supply Model Number Volts (V) 3 Year Warranty Output Current (max) Max Watts Ripple (Vp-p max) CENB1010A0503F01 5V 2.00 A 10.0 W 50 mV CENB1010A0603F01 6V 2.00 A 12.0 W 60 mV CENB1010A0703F01 7.5 V 1.60 A 12.0 W 75 mV CENB1010A0903F01 9V 1.10 A 10.0 W 90 mV CENB1010A1203F01 12 V 1.00 A 12.0 W 120 mV CENB1010A1503F01 15 V 0.80 A 12.0 W 150 mV CENB1010A1603F01 16 V 0.75 A 12.0 W 160 mV CENB1010A1803F01 18 V 0.67 A 12.0 W 180 mV CENB1010A2403F01 24 V 0.50 A 12.0 W 240 mV CENB1010A4803F01 48 V 0.25 A 12.0 W 480 mV Notes: Part numbers above include #3 output connector and IEC320 C14 grounded input receptacle. See below for other options. Model Number Key CENB 1 010 A VV 03 F 01 Model Input Connector: Output Connector: Output Voltage: Model Output Pow er: # of Outputs Product Family: "01" = Standard. "02" and higher indicates a modified m odel. "F" = IEC320 C14 grounded, Other options available, see below "03" = 2.5m m Barrel Type Connector. Other options available, contact factory. "05" = 5Vdc, "12" = 12Vdc, "24" = 24Vdc, etc. "A" = Original Configuration "010" = 10 Watts "1" = Single Output "C" = Com m ercial/ITE/Industrial, "E" = External, "NB" = Model Series Designator AC Input Receptacle Options Desktop IEC320 - C14 Class I Grounded IEC320 - C18 Class II Ungro unded IEC320 - C8 Class II "Shaver" (F) (Q) (N) Notes: Output Connector Wall-Plug N. Am erica Japan N. Am erica Japan Fixed Int e rc ha nga ble (B) (C) Europe Australia Fixed United Kingdom Fixed (M) (G) (H) Fixed 1. For desktop options, choose applicable letter above. 2. For Wall-Plug options, choose the applicable letter above and the unit w ill be fitted w ith the receptacle chosen. The N. A. blade version (B) w ill be an interchangeable blade. The other options (C), (M), (G), and (H) w ill be fixed blades m olded in the case. 3. Blade Kit is available w hich w ill include one each of a EU, UK, and Australian blade. Kit part # is KT1027K. These can be used w ith the (B) version, to allow blades to be changed. Notes: 1. Ault #3 Connector, center contact (+). 2. Connector is Sw itchcraft 760 plug or equivalent. Mating connector is Sw itchcraft 712A or equivalent. 3. Other connector options are available. Contact your local SL Pow er Representative for details. Outline Drawings Desktop Style Wall-Plug Style (Option “B” Shown) ________________________________________________________________________________________________________________________________ 2 of 3 SL Power Electronics Corp • 6050 King Drive Ventura, CA 93003 • Phone 805.486.4565 • Fax 858.712.2040 • Email: info@slpower.com • www.slpower.com CENB1010 Universal 10 Watt Series ITE Switch-Mode Power Supply 3 Year Warranty Output Derating Chart (5V Model, 90-264Vac input range) Data Sheet © 2014 SL Power Electronics Corp. The information and specifications contained herein are believed to be correct at the time of publication. Rev. 9-23-2014 However, SL Power accepts no responsibility for consequences arising from reproduction errors or inaccuracies. Specifications are subject to change without notice. ________________________________________________________________________________________________________________________________ 3 of 3 SL Power Electronics Corp • 6050 King Drive Ventura, CA 93003 • Phone 805.486.4565 • Fax 858.712.2040 • Email: info@slpower.com • www.slpower.com
CENB1010A1249F01
物料型号:CENB1010系列
器件简介:这是一款通用的10瓦开关电源,具有100-240VAC的全球通用输入范围,满足EISA2007、CEC效率等级V和EU (EC) No 278/2009第二阶段的能效标准。
引脚分配:文档中没有提供具体的引脚分配图,但提到了输出连接器为2.5mm桶型(Ault #3),中心接触点为正极。
参数特性: - 交流输入:100-240VAC,频率47-63Hz - 输入电流:100Vac时为0.27A - 效率:满足EISA2007、CEC效率等级V和EU标准 - 输出电压和功率:有多款型号,输出电压从5V到48V,最大输出电流从0.25A到2.00A,输出功率最高12W - 纹波和噪声:最大1%峰-峰值,20MHz带宽 - 工作温度:0到40°C,无降额(5V型号0到55°C,见降额图表)
功能详解:电源提供稳定的输出电压,具有低纹波和抗冲击的聚碳酸酯外壳。空载功耗小于0.3W,具有过载保护和短路保护。
应用信息:适用于桌面和墙插式风格,可提供定制和修改设计。
封装信息:外壳材料为黑色94V-0聚碳酸酯,尺寸为84x47x32mm,重量为110g。
CENB1010A1249F01 价格&库存
很抱歉,暂时无法提供与“CENB1010A1249F01”相匹配的价格&库存,您可以联系我们找货
