CENB1030A1802C01
CENB1030A1802C01
    SLPOWER
    AC/DC DESKTOP ADAPTER 18V
CENB1030A1802C01 数据手册
CENB1030 Universal 30 Watt Series ITE Switch-Mode Power Supply 3 Year Warranty •100-240VAC Universal Input •Meets EISA2007, CEC Efficiency Level V, EU (EC) No 278/2009 Phase II nd •Certified to UL/EN60950-1, 2 Edition •5Vto 48V outputs, up to 32W •Modified and Custom Designs Available •Regulated Output with Low Ripple •Impact-Resistant Polycarbonate Enclosure •No load Power Consumption 100,000 hours calculated Hold-up Time 18 ms min. @ 115VAC, 60 msec @ 230VAC Turn-on Time 2 seconds, max. Topology Switching – Fixed Frequency Flyback Overload Protection Hiccup Mode Short Circuit Protection Hiccup Mode EMC See chart below Safety Standards Dielectric Withstand Operating Temperature Storage Temperature Relative Humidity EN/IEC/CSA/UL60950-1, 2nd Edition, LPS Input-Output: 4,242VDC, Input-GND: 1,500 Vac, Output-GND: 500Vdc 0° to 40°C, no derating -40° to +85°C 5% to 95%, non-condensing Altitude Output Cable: 0 to 10,000 ft 5V – 9V models: #18AWG (SPT-1), 1,500mm, 2 conductor 12V – 48V models: #18AWG (UL1185), 1,500mm, 2 conductor EMC Specifications Conducted Emissions Radiated Emissions Line Frequency Harmonics Voltage Fluctuations/Flicker Static Discharge Immunity Radiated RF Immunity EFT/Burst Immunity Line Surge Immunity Conducted RF Immunity Power Frequency Magnetic Field Immunity Voltage Dip Immunity EN55022 Class B, FCC Part 15, Class B. EN55022 Class B, FCC Part 15, Class B. EN61000-3-2, Class A EN61000-3-3 EN61000-4-2, 6kV Contact Discharge, 8kV air discharge EN61000-4-3, 3V/m. EN61000-4-4, 2kV/5kHz. EN61000-4-5, 1kV differential, 2kV common-mode EN61000-4-6, 3Vrms EN61000-4-8, 3A/m EN61000-4-11, Criteria B ______________________________________________________________________________________________________________________________ SL Power Electronics Corp • 6050 King Drive Ventura, CA 93003 • Phone 805.486.4565 • Fax 858.712.2040 • Email: info@slpower.com • www.slpower.com 1 of 2 CENB1030 Universal 30 Watt Series ITE Switch Mode Power Supply 3 Year Warranty Model Number Volts (V) Output Current (max) Max Watts Ripple (Vp-p max) CENB1030A0503F01 CENB1030A0703F01 CENB1030A0903F01 CENB1030A1203F01 CENB1030A1403F01 CENB1030A1503F01 CENB1030A1803F01 CENB1030A2403F01 CENB1030A4803F01 5V 7.5 V 9V 12 V 14 V 15 V 18 V 24 V 48 V 4.00 A 3.00 A 3.00 A 2.50 A 2.10 A 2.00 A 1.67 A 1.33 A 0.67 A 20.0 W 22.5 W 27.0 W 30.0 W 29.4 W 30.0 W 30.0 W 31.9 W 32.1 W 50 mV 75 mV 90 mV 120 mV 140 mV 150 mV 180 mV 240 mV 480 mV Notes: Part numbers above include #3 output connector and IEC320 C14 grounded input receptacle. See below for other options. Model Number Key CENB 1 030 A VV 03 F 01 Model Input Connector: Output Connector: Output Voltage: Model Output Pow er: # of Outputs Product Fam ily: "01" = Standard. "02" and higher indicates a m odified m odel. "F" = IEC320 C14 grounded, Other options available, see below "03" = 2.5m m Barrel Type Connector. Other options available, contact factory. "05" = 5Vdc, "12" = 12Vdc, "24" = 24Vdc, etc. "A" = Original Configuration "030" = 30 Watts "1" = Single Output "C" = Comm ercial/ITE/Industrial, "E" = External, "NB" = Model Series Designator AC Input Receptacle Options Desktop IEC320 - C14 Class I Grounded IEC320 - C18 Class II Ungro unde d IEC320 - C8 Class II "Shaver" (F) (Q) (N) Notes: Output Connector Wall-Plug N. Am erica Japan N. Am erica Japan Int erc ha ngable Fixed (C) (B) Europe Australia Fixed United Kingdom Fixed (M) (G) (H) Fixed 1. For desktop options, choose applicable letter above. Notes: 2. For Wall-Plug options, choose the applicable letter above and the unit w ill be fitted w ith the receptacle chosen. The N. A. blade version (C) w ill be an interchangeable blade. The other options (B), (M), (G), and (H) w ill be fixed blades m olded in the case. 3. Blade Kit is available w hich w ill include one each of a EU, UK, and Australian blade. Kit part # is KT1027K. These can be used w ith the (C) version, to allow blades to be changed. 1. Ault #3 Connector, center contact (+). 2. Connector is Sw itchcraft 760 plug or equivalent. Mating connector is Sw itchcraft 712A or equivalent. 3. Other connector options are available. Contact your local SL Pow er Representative for details. Outline Drawings DATE CODE Desktop Style Wall-plug Style “C” Option Shown (with KT1027K interchangeable blade kit) Data Sheet © 2014 SL Power Electronics Corp. The information and specifications contained herein are believed to be correct at the time of publication. Rev. 9-22-14 However, SL Power accepts no responsibility for consequences arising from reproduction errors or inaccuracies. Specifications are subject to change without notice. ______________________________________________________________________________________________________________________________ 2 of 2 SL Power Electronics Corp • 6050 King Drive Ventura, CA 93003 • Phone 805.486.4565 • Fax 858.712.2040 • Email: info@slpower.com • www.slpower.com
CENB1030A1802C01
物料型号:CENB1030系列,包括不同输出电压和最大输出电流的型号,如CENB1030A0503F01(5V, 4A)、CENB1030A1203F01(12V, 2.5A)等。
器件简介:这是一款通用的30瓦开关式电源适配器,具有3年保修期,适用于桌面和壁插式风格,符合多种安全和效率标准。
引脚分配:文档中未明确提供引脚分配信息,但提到了输出连接器为2.5mm桶型(Ault #3),中心接触点为正极。
参数特性:输入电压范围为100-240VAC,频率47-63Hz。输出电压范围从5V到48V,最大输出功率32W。空载功耗小于0.3W,具有低纹波的稳定输出。
功能详解:该电源适配器具有过载保护、短路保护和EMC(电磁兼容性)特性。效率符合EISA2007、CEC效率等级V和EU (EC) No 278/2009第二阶段的要求。
应用信息:适用于商业、ITE/工业环境,提供多种AC输入插座选项,以适应不同地区的标准。
封装信息:采用抗冲击聚碳酸酯外壳,尺寸为95 x 54 x 31mm,重量为200g。
CENB1030A1802C01 价格&库存
很抱歉,暂时无法提供与“CENB1030A1802C01”相匹配的价格&库存,您可以联系我们找货
