CENB1060A1802F01
CENB1060A1802F01
    SLPOWER
    AC/DC DESKTOP ADAPTER 18V
CENB1060A1802F01 数据手册
CENB1060 Universal Input 60 Watt Series I.T.E Switch-Mode Power Supply 3 Year Warranty •100-240VAC Universal Input •Meets EISA2007, CEC Efficiency Level V, EU (EC) No 278/2009 Phase II nd •Certified to UL/EN60950-1, 2 Edition, LPS •Desktop Style •5V to 48V Single Output Models, up to 60W •Modified and Custom Designs Available •Regulated Output with Low Ripple •Impact-Resistant Polycarbonate Enclosure •No Load Power Consumption 100,000 hours (calculated) 18 ms min. @ 115Vac, 60 ms min. @ 240 Vac Overload Protection Hiccup Mode Short Circuit Protection Hiccup Mode Topology Switching – Fixed Frequency Flyback Safety Standards EN/IEC/CSA/UL60950-1, 2nd Edition LPS (9V thru 48V Models) See chart on page 2 EMC Dielectric Withstand Operating Temperature Input-Output: 5,656Vdc, Input-GND: 1,500 Vac, Output-GND: 500Vdc 0° to 40°C, no derating Storage Temperature Relative Humidity -30 to +85°C 5% to 95%, non-condensing Altitude 0 to 10,000 ft Output Cable 5V – 9V models: #18AWG (UL2464), 1,200mm, 4 conductor 12V – 15V models: #18AWG (UL2464), 1,500mm, 4 conductor 18V – 48V models: #18AWG (UL2464), 1,500mm, 2 conductor Output Connector 5V model: Molex 39-01-2060 or equiv. (Ault #51) Other models: 2.5mm barrel type (Ault #3), center contact positive (+) EMC Specifications Conducted Emissions Radiated Emissions Line Frequency Harmonics Voltage Fluctuations/Flicker Static Discharge Immunity Radiated RF Immunity EFT/Burst Immunity Line Surge Immunity Conducted RF Immunity Power Frequency Magnetic Field Immunity Voltage Dip Immunity EN55022 Class B, FCC Part 15, Class B. EN55022 Class B, FCC Part 15, Class B. EN61000-3-2, Class A EN61000-3-3 EN61000-4-2, 6kV Contact Discharge, 8kV air discharge EN61000-4-3, 3V/m. EN61000-4-4, 2kV/5kHz. EN61000-4-5, 1kV differential, 2kV common-mode EN61000-4-6, 3Vrms EN61000-4-8, 3A/m EN61000-4-11, Criteria B ______________________________________________________________________________________________________________________________ 1 of 2 SL Power Electronics Corp • 6050 King Drive Ventura, CA 93003 • Phone 805.486.4565 • Fax 858.712.2040 • Email: info@slpower.com • www.slpower.com CENB1060 Universal 60 Watt Series I.T.E Switch Mode Power Supply 3 Year Warranty Model Number Volts (V) Output Current (max) Max Watts Ripple (Vp-p max) CENB1060A0551F01 5V 7.00 A 35.0 W 50mV CENB1060A0903F01 9V 6.00 A 54.0 W 90mV CENB1060A1203F01 12 V 5.00 A 60.0 W 120mV CENB1060A1503F01 15 V 4.00 A 60.0 W 150mV CENB1060A1803F01 18 V 3.40 A 61.2 W 180mV CENB1060A2403F01 24 V 2.70 A 64.8 W 240mV CENB1060A4803F01 48 V 1.30 A 62.4 W 480mV Model Number Key CENB 1 060 A VV 03 F 01 Model Input Connector: Output Connector: Output Voltage: Model Output Pow er: # of Outputs Product Fam ily: Input Receptacle Options IEC320 C14 IEC320 C18 Grounded Ungrounded (F) (Q) "01" = Standard. "02" and higher indicates a m odified m odel. "F" = IEC320 C14 grounded, Other options available, see next page. "03" = 2.5m m Barrel Type Connector. Other options available, contact factory. "05" = 5Vdc, "12" = 12Vdc, "24" = 24Vdc, etc. "A" = Original Configuration "060" = 60 Watts "1" = Single Output "C" = Com m ercial/ITE/Industrial, "E" = External, "NB" = Model Series Designator Output Connector Output Connector (5V Model) IEC320 C8 "Shaver" (N) Pins 1,4 = (+), Pins 3,6 = (-) Outline Drawing DATE CODE Dimensions are in mm (Cable length is 1200mm on 5V thru 12V models) Data Sheet © 2010 SL Power Electronics Corp. The information and specifications contained herein are believed to be correct at the time of publication. Rev. 12-22-2010 However, SL Power accepts no responsibility for consequences arising from reproduction errors or inaccuracies. Specifications are subject to change without notice. ______________________________________________________________________________________________________________________________ 2 of 2 SL Power Electronics Corp • 6050 King Drive Ventura, CA 93003 • Phone 805.486.4565 • Fax 858.712.2040 • Email: info@slpower.com • www.slpower.com
CENB1060A1802F01
- 物料型号:CENB1060系列,包括多种输出电压和电流规格的型号。 - 器件简介:这是一款通用输入60瓦特系列的开关式电源模块,具有3年保修期。 - 引脚分配:文档中提到了输入和输出连接器的引脚分配,例如IEC320 C14和IEC320 C18。 - 参数特性:包括输入电压范围(100-240Vac)、效率(满足EISA2007、CEC效率等级V等)、输出功率(见图表)、纹波和噪声(1%峰峰值最大)等。 - 功能详解:文档描述了电源模块的多种保护功能,如过载保护、短路保护等,以及瞬态响应和最小负载要求。 - 应用信息:适用于桌面式应用,提供5V至48V的单输出模型,最高60W。 - 封装信息:包括外壳材料(黑色94V0聚碳酸酯)、尺寸、重量以及输出电缆规格。
CENB1060A1802F01 价格&库存
很抱歉,暂时无法提供与“CENB1060A1802F01”相匹配的价格&库存,您可以联系我们找货
